Ok, you can try remove this cap from the board first, it is safe to run your amp without this cap.
Please prepare a Dim Bulb Tester to test your amp, don't connect speaker first, connect multi-meter to the speaker terminals for the problem channel and fire up the amp to see output voltage any change.
Tried that. Spikes up to 10-12 volts then drops to under 200MV
Before anything else I would change the electrolytes. And check R15, R16 as well.
They measured around 68 Ohms which is correct
C19 part removed
Pls measure V1 to V5
maybe try exchange the two big power supply caps with each other to see if the output voltage will shift to -V when startup
What a weird malfunction.
Looks like the 12V is unable to shift TR1 and open TR8.
Can be low current TR3, so check R6 also.
Or R9 to high? Or faulty c5?
And it last far too long, I suspect ELKOs, it tend to make such problems.
OK, I measured across the components.:
V1 - 0.69v
V2 - 0.7v and increasing
V3 - 0.7v and dropping
V4 - 0.12v and rising
V5 - 0.2v and dropping
R6 measured 17.97K out of circuit original value 18K
I also swapped the main smoothing caps and it seemed to go to minus but then quickly dropped to around 150MV and dropping
do you have good spare smoothing caps to replace both of them, like take it form another amp
V1-V5 voltages seems normal
Had some used caps but same result, it was 8200uf. original 6800uf
That increasing and dropping is unlogical.
Can you check all grounds for possible potential between them?
Solder joints?
Solder joints?
How can I do that? Thanks
How measures collector TR8 to signal ground?
I connected the probe to ground of audio input and it jumped a bit but then went to 0.91V and rising slowly
Ok, and now TR8 collector to speaker ground?
Same thing. Had the leads in the wrong way round. Connecting the black probe to speaker out gave me -0.9V and slowly rising
ok, collector TR8 to spk output?
1.12v and increasing slowly
It looks we have 0.25V offset right now. You said that there is 10V and more?1.12v and increasing slowly
It spikes very quickly and my meter cant keep up. But it looks like on startup when all capacitors are discharged it goes as high as 20v and then drops with 1 sec to 1v and slowly decreasing from 1v... I haven't left it on for more than 1 minute to see how far it drops.
It is quite normal transient in turn on state. That´s why we use protection circuits with turn on delay.
- Musical Fidelity X-A50 monoblock amp Circuit
