Construction a 20W Jean Hiraga class A amplifier advice needed
Hi, all,
I constructed several Class AB amps before but never construct a real Class A amp, it is because Class A amp needed big heatsinks and high volume of power supply caps stop me.
Now I start planning to construct a 20W Class A amp, I want to use a pair of TO-3 power transistor 15023/15024(I have stock) per channel.
The reference Amp are Musical Fidelity A1 and Jean Hiraga 20W, I prefer Jean Hiraga amp more.
The Class-A Amplifier Site - Hiraga 20W Class-A
I want the amp with temp stable and balance in performance. For the Jean Hiraga schematic, I changed the 9v zener diodes to a transistor current source, I think it is more easy to matching 2 channels difference than using zener diodes, I changed the thermal resistor control to a Vbe multiplier and install it near the power transistor to compensate the temp.
I don't know how to use those simulation software, please help me and advice if the above change is suitable or having good ideas to construct the amp.
Thanks,
Patrick
The VBE multipliers is a very bad idea. You are reducing the open loop gain heavily without really gaining something.
Ok, I got your meaning. I will remove the VBE multiplier and change back to resistors.
I saw there is a thermal resistor in the schematic and I saw one Class A amp project which attach a thermal resistor to the output MOSFET, I though this a kind of thermo control, so that raise this idea of using a Class AB amp VBE multiplier here.
Thanks,
Patrick
