Chip Amp Photo Gallery
Here's my 6 channel small box amp, a four channel TDA7850 car amp chip and two TDA8932 Class D boards for the bass end. I use it with my Behringer crossover and cobbled together multiway speakers.
The TDA7850 is on a TDA7388 PCB (only a pound! Power amplifiers TDA7388 four channel 4x41W audio DC 12V BTL PC car AMP PCB JP | eBay). You can find complete TDA7850 amps on Ebay but I thought that buying a known good chip from RS components and decent caps would be a better route. I found some 1uF polypropylene input caps for a good price but they were too big really. I made 'em fit but it left no room for proper terminals for the inputs. Initially I had no terminals for the power and outputs, I soon regretted that and added them.
JohnAudioTech tested a completed Ebay board and found it has distortion problems, probably due to a bad layout. YouTube. The chip should do about 13W per channel into 8 ohms according to this http://www.diybudgetaudio.com/TDA7850.htm I had it on a small ATX PSU heatsink that got warm and would not fit in the box so I mounted it to this one. I can barely feel any heat at all now. It's running on a 15V switch mode laptop supply.
The TDA8932s do get warm though, even at the low 12V they're running on now. I might change those for something beefier in future. I think they can do about 20W into 8 ohm at 19V. Overall I'm pretty happy with it. I tried multiple TPA3116 boards before but had problems with hot inductors and high frequency whistles.
Here is my just finished Modulus 86. I used the SMPS-86 for power and some Modushop heat sinks to keep it cool. Thanks to Tom and this forum for being a resource to help me through the build. It sounds great!
the tda2002 needs a "stiff" psu (transformer 20VA or better, electrolytic cap 10000uF or more).......with a weak psu (10VA transformer and 2200uF or sowhat) Pout shrinks to 2.....3W.
or a regulated psu, with a 15Vdc psu i got around 4,5W at 3,9ohm/1kHz.
the sound is relaxed, for long term listening.........
tda2002 datasheet circuit modification......(Cout not in the feedback loop):
with 2200uF cap at the output i got 20Hz (-3dB) @ 4ohm load.
upper freq. limit is around 200kHz (-3dB).
15Vdc......16Vdc unregulated power supply.
I started this build toward the end of 2018, with the aim of downsizing my previous 2.1 setup (a 2-channel Gainclone + a Samson 120a bridged for sub + a dbx 223XL crossover) to a single enclosure. I got side-tracked a lot, but with the COVID-19 lockdown & getting furloughed from my job I've finally finished it - all except finding a nice knob for the rotary power switch!
As seems to be the trend for my audio projects nothing went quite as originally planned - in particular I had multiple issues with the various KMTech boards I bought from eBay. As a result I've ended up keeping the external crossover, going with a single power supply rather than multiple & using completely different amp boards. So I know it's far from perfect, but it's a big improvement over my original 2011 build!
Enclosure is a 2U Dissipante from Hi-Fi2000/Modushop in Italy, audio transformer for bridging the sub amps is a Vigortronix VTX-101-007, amp boards are the open source LM3886 design from this forum's own 00940 which I had made at JLCPCB.
Many thanks to all the help I've had in various threads on the forum over the last 18 months or so!
