INVERTED REGULATOR CORRECTION INFO
In post #136 I discovered that the LTP CCS emitter degeneration resistors were missing on the inverted regulators.
In post #139 I put up corrected schematics.
In post #149 you can see how drmaftoon's neatly added through-hole resistors between the transistor leg and its hole.
I thought I'd try using SMD resistors:
While it looks quite neat, I can't really recommend it. I have pretty good soldering skills and this still turned out to be beyond fussy.
If you do want to try it, it might be easier with a very fine tip on your soldering iron. But I'd recommend drmaftoon's method instead.
Here are the Kicad files.
Notes:
1) The missing CCS emitter resistors on the Inverted Regulator board have been fixed.
2) The files were written with a development version of Kicad. If you have trouble opening them reply here and we'll figure out how to back-date them.
Jeff
Notes:
Jeff
Nice! Thanks for making those available Jeff.
FWIW I got a couple quotes for the non-current transistors from NJ Semi.
US$7.50 per unit on BYD58. That's for a quantity of 10 figuring 8 required and handy to have some spares. They seem to have plenty in stock.
They also have BC239C on hand US$1 each. "$10 line min. / $50 PO min."
If anyone knows them to be not a legit source, let me know. I'm inclined to place an order soon. (Looking back through the thread, seems like Jeff got his BYD58 there to build this very amp, so I'm convinced.)
I think all of the other transistors were in stock at Mouser, except MJE243 which is stocked but backordered.
any suggestions about speaker protection and soft start boards
should I use them or not a good idea? Naim do not use them so there must be a reason?
I've never used soft start but my transformers are 350VA each it your using 500VA then you may need them.Always used output protection boards (Vallman kits) saved my speaker's more than once.They use replays in the speaker lines but can't hear a problem.Am moving to a solid state design, there is a group buy on this forum for them.Naim used the on-board current limiter on the NAP boards which can be heard working so a lot of people removed the parts.
Thank you for your help. I will order the boards from group buy.
Cheers
Sajjad
I too plan to use a speaker protection circuit using a relay at the outputs. I noticed that when one of the rail voltages goes dead, the offset of the amp climbs to rail voltage.
I have question: what is the rated current of the fuses do you use?
What fuses are you talking about?
Fuses in the lines that feed the power supplies or in the lines between the power supplies and the amp-boards.
I have not seen Naim using these, but for me it feels better to have them in.
Ok I don't use any either though I did on an earlier amplifier using an cap multiplier to supply the VAS stage they were 3A fast blow.
Even the output transistors in case the speaker terminals are shorted? (I agree that the chance to that happening is small) The BUV20 you are using are pretty powerfull.Most transistors will blow faster than even a fast-blow fuse....
You might be right though that we can do without it, but I think that in the test phase it can save me a lot of trouble.
Hi Jeff, I just joined the group. First of all, sorry for my elementary EnglishYeah, I also got a bunch of NOS Harris IRFP9240s from them. They're legit.
I am very interested in the construction of the nap250. It is still possible to buy both the amp and alimentarore cards. Thank you and congratulations
After listening to it daily for a month, I find it has too much treble.
Can I substitute a component to "numb" the sound a bit , if yes should it be input capacitor or output capacitor?
Thanks in advance.
Thanks in advance.
If memory serves me well: C7 is a tantalic capacitor, and it has a big influence on the sound character. You could replace it with a bipolar electrolytic to get a "smoother sound"
First a disclaimer: we're well out of my knowledge bubble here. But:
The input low pass capacitor (C2) is going to give a fairly steep roll-off, so I don't think changing it will give you what you want.
The input DC-decoupling capacitor (C1) doesn't do any filtering, but it's also a tant and may affect the sound. You could try bipolar electrolytic or polypropylene there. But we're in to capacitor "sound" here, which I know nothing about.
I think @dre is referring to a schematic with different part numbering. C7 on my schematics is a bypass for the bias splitter, which I can't imagine having any effect. I *think* the corresponding number on my schematic would be C3/C4, which are known to affect the sound (although most people comment on the bass with respect to them).
It could also be room acoustics. What source are you using? If it's something like Roon or Audirvana you could do a low-pass filter digitally (I have to do that for my room, but it's in the opposite direction).
Jeff.
Jeff.
Thank you dre and Jeff for your prompt answers.
My source is Pioneer N70 network player. When used with other amplifiers it sounds "fine" to me. But using this particular amplifier, I get tired after 30 minutes or so.
I will tinker with C3/C4 and report back my findings.
- Group Buys
- NAP250 amp boards & regulator boards
