The Black Hole......
0db on my system is where I do most of my critical listening/testing.
I’m not sure of the input voltage at that volume setting (it’s a integrated/direct Ethernet amp) I’m assuming 0db is straight up no attenuation. 1.4v - 2v input ?
There was no distortion I could detect which tells me it’s a good recording, I didn’t mean there was no difference at lower levels just that it became obvious @ 0db.
And Hans I wouldn’t call it a ‘substantial’ difference.....I had to work at it, and what I call obvious (once I catch it) could be undetectable for some. At least that’s my impression so far
Leather should stop a small pin hole, but a larger leak would pentrate even leather.
Let's look at this again.
A small pinhole would have a much wider dispersion pattern than a focused nozzle. It would likely be a misty spray at that pressure. Very little power a short distance after exiting the pinhole.
A larger leak would have a narrower pattern but when talking about a human limb, it would tend to knock the arm out of the way rather than penetrate the leather.
I'd be interested in trying the cymbal listening test, but my setup resamples everything to 96K via HW ASRC, wouldn't that skew the results? Also - and I hesitate to even bring this up, but - this kind of thing really needs a proper DBT to be worthwhile, no?
And yes, in the case where the brickwall filter removes the upper sideband, the waveforms will certainly change. But not the frequency. As far as I can see, removing an inaudible upper sideband would probably make no difference to audibility.
We have been talking about Fs near CD sampling frequency. While humans seem to have a nominal frequency upper limit of about 20k, but Kuchnur’s (sp?) research shows that the temporal response goes higher in frequency than that Fs.
Information for prospective students
dave
Thanks, I was thinking of the top 2 scenarios in your post #109.
20k modulated with and without the upper sideband...
But as continuous tones - so they can be examined more easily...
Just a thought...
Here You are.
I made 3 new versions, resp 18/3.6, 20/4 and 22/4.4.
All files are also in 20Khz Brick Wall filtered version.
They are now 192Khz, 32bit float, instead of the previous 16 bit versions.
And all .wav files are 35msec long, with 10msec lead in and 10msec lead out, because of the Gibbs ringing added to the time domain signal.
Dropbox - Spectra - Simplify your life
Hans
dave
Sorry, that was a big mistake that I extensively communicated and agreed with Kunchur, but this info keeps popping up all the time.
There was a serious error in his calculation, that effectively made his test members to hear a difference in loudness of 0.7dB instead of hearing a temporal resolution of 5usec.
And 0.7dB is indeed the smallest step in level change we can hear.
A second remark is that temporal resolution is absolutely not the same as the highest frequency we can hear.
It is the smallest noticeable difference in time between two successive wave fronts.
Hans
Indeed. But the ear/brain can discern that time difference, in the frequency domain it is up there. Take out the information the human hearing mechanism uses and a (trained listener at least) will hear the difference.
dave
