Teal Thiel SS10f mid/tweets
Couldn’t pass up the great deal on these at Madisound. Identical to the Regular Scanspeak 10/f-8424. Running them from 500hz and up. Super flat response up to 15khz
Ran them in with a 90hz sine wave for four hours, and now I’m listening critically for the first time. Soundstaging(different from imaging, which can happen without “depth”)is staggeringly good. I’m assuming this is due to the lack of any crossover anywhere near the ear’s sensitive range between 1 and 5khz.
The 10F/8424 in a front horn is excellent. %THD is well under 1% at 250Hz and drops to only 0.10% from 500Hz-3kHz. Subjectively it has a very balanced sound that is both lively and smooth...with no breakup until around 18kHz. In a non horn configuration (direct radiating) the best the 10F/8424 can do is 0.8% through the midrange. %THD is well above 1% at anything below 500Hz with direct radiating.
Zaph and Hifi Compass both measured no more than about .5% thd above 500hz. All depends on the reference volume level relative to mic distance
Just a thought..
If The $90,000 B&O Beolab 90 Is world’s most expensive Digitally processed Scanspeak/IcePower based loudspeaker, this project is probably the worlds least expensive digitally processed Scanspeak/IcePower combination. With no bass to speak of, of course
