ELEKIT TU-8800 SET AMP
can anyone recommend a low gain/output tube for a tu8800?
for turning up a bit more yet listening at lower volumes.
6F6 or 6V6.
All recent Elekit amps use SS rectification with an additional FET based ripple filter, the bigger ones also have a second filter stage for driver tubes.
Gain can be calculated from the specs. 360mV is required for 12.5 Watts, which is about 29 dB at 8 Ohms, and 26 dB at 4 Ohms.
Headphone output level is adjustable.
