Plasmatweeter
Lampie 519, i was TIG welder with automatic machines.They use HF for starting the arc.
Other point :with TIG process (for steel welding)rod is at the négatif pôle and pièce is at the positif pôle, current walk from pièce to rod and electrons are walking from rod to piece.
In plasma speakers case it is the opposite...
Any view on this ?
Hello,
Here is my starter device.No more screwdriver is needed.I silver brazzed à little ceramic pipe tought the Faraday cage.The little rod is fully insulated.
It's works well.Just push the ceramic connector.
Even it's possible to play with the flame.
Hello Marco, the 6L6 can be used for a ESL headphone amp but not for full range ESL's. You need tubes that can handle the power supply voltage without any issues. And a 6L6 can handle only 500V max. You need tubes that can handle 5KV.
But i think there is a thread dedicated to DD amplifiers here somewhere.
Best Regards, Frank
Hello,
I received 2 Visaton Tr84 transformers for modulation.
I wirered them on 6W and 8Ohms pins.
It works fine,the sound is very good.
This plasma speakers projet is now almost finish:
Perhaps 1 or 2 things to review.
Thanks Lampie 519 for your help
Hello,
Parasitic Suppressor.
I don't realy understand how it works.
See picture please : Is it wrong or right ?
If it's right,i notices that the impédance stays Low.
Which capacitance should i choose to design à parasitic suppressor ? Anode-cathode ?Anode-grid?
