USB Audio interface for measurement
I agree that USB interfaces are my preference, but in my case this will probably end up stationary at a test bench.
One other PCIe option that looks interesting is the EVGA Nu Audio card. It uses the AK5572 ADC, which looks pretty enticing from a THD standpoint. Anyone played with this at all? Assuming they did their analog design well and didn't limit the bandwidth to 20kHz (and that's a big assumption), the AK5572 looks like it should be about the best ADC available for measurement usage.
Motu M4
I bought this a week ago, listened to headphone out while binging
ran RMAA just now, TRS balanced line in/out 3' cables, win 10 Laptop
RightMark Audio Analyzer test report
Testing device [ASIO] MOTU M Series
Sampling mode 24-bit, 96 kHz
Interface ASIO
Testing chain External loopback (line-out - line-in)
RMAA Version 6.4.5
20 Hz - 20 kHz filter ON
Normalize amplitude ON
Level change -2.5 dB / -2.5 dB
Mono mode OFF
Calibration singal, Hz 1000
Polarity correct/correct
Summary
Frequency response (from 40 Hz to 15 kHz), dB
+0.04, -0.03
Excellent
Noise level, dB (A)
-115.6
Excellent
Dynamic range, dB (A)
115.5
Excellent
THD, %
0.00034
Excellent
THD + Noise, dB (A)
-101.0
Excellent
IMD + Noise, %
0.00139
Excellent
Stereo crosstalk, dB
-110.9
Excellent
IMD at 10 kHz, %
0.00128
Excellent
General performance
Very good
Thank you very much for sharing the results.
The M4 seems to be the successor to the Audio Express model which I've been using for the past five years or so. Two years ago I exchanged all op-amps in it for a presumably better stock, and THD improved by 6-7dB.
Comparing now the M4 results with the Audio Express ones I obtained with the same S/W and under almost the same conditions (my signal cables are twice as long, and my interface to the laptop is FW400), I see that the principal difference is the much improved noise floor of the M4. This of course pulls all (xxx + N) results in the right direction (s. attachment).
Braca
  • RightMark Audio Analyzer test _ MOTU Audio Express FW400.pdf
Joined 2016
Hi Jcx,
I just downloaded a 21 trial of RMAA and wanted to test my scarlett 2i4 as you have done in your previous post.
Would you mind giving me a run down on how to set RMAA up to preform this test the same as you. I will then post my results.
I done playing with the m2 analyzer. It works great, its a major upgrade now back to the projects.
Here is screen pics my old software using the M2 on Osx/wine and w10.
Made a couple of RCA to 1/4" mono plugs.
