IGBT Class D amplifier
Hi members.
Sharing this new proto of amplifier made with...............IGBTs. Lot of people will say "cannot works! Mosfets are better" Yes, but, why not try.
Structure used is build around TL494 working for PWM generation and high current opto drivers (TLP358) driving high speed IGBTs (GW30NC60)
At this step, with 110Vdc supply, it reach 550W (29Veff) into 1.5ohms load.
Will try to increase little more output power (to reach IGBT maximum rating).
Sound is quite good, better than some chinese amplifiers 😀
Feel free to try it.
Ok, guy, but respectfully, we are speaking of different thinks. Linear amps do not need the large and continuous voltages changes that a well designed class D (PWM or switching amps) needs. A medium power class D amp need to switch, say, 200V in nanoseconds or still better, picoseconds. A linear class A or AB doesn't.
Class D are switching at ultrasound frequencies still with no signal, while a linear, only a small DC current flows.
On full power the amplifier is switching very quickly.
> 270 khz is required for clear natural High Quality audio 20 - 20khz
otherwise Class D amp sound poor like compressed, metallic.....
IGBT is for high power Class D Subbass ok
IGBT in N-Channel analog PA amo (not Class D) is a BEAST and workhorse,
will outperform any bipolar amp if have good circuit design
With 160V Class AB + Class TD you can outperform Class D
You need to know the Limits fpr Class D
The Limits for Class D are between 90 to 120 V DC Rail.
you need to bridge > 120V DC Rail
Class AB + Class TD no need to bridge 180 V DC no problem
Class TD Rail switcher work with about 50 khz. easy for most IGBT and Mosfet at high Voltage,
and most of 600V IGBTs will working in Class AB Section with High audio quality and without secondary beakdown problems v/s bipolar
fun thread it seems xD
.. maybe some measurments of said amplifier?
Of course!
Pic1 : supply voltage
Pic2 : Sinus rendering
Pic3 : Triangle rendering
Pic4 : Square rendering
Pic5: FFT sinus 5kHz
Pic6: FFT sinus 10kHz
Pic7: Load DC resistance
Pic8; Output voltage before LC filter (thanks to the snubbers 🙄)
So quite good result; just to much 3rd harmonic, but sounds (very) good.
I'm aware that is not SuperHyperMegaPro HiFi of the dead, it's just a simple experience to show that we can build amplifier from parts used in washing machines...
For Fullrange you will need >270 Khz otherwise amp will sound poor
Nyquist-Shannon sampling theorem => minimum switching frequency : 40kHz. I still want to know how you calculate 270kHz.
Try to find 500 V Mosfet to handle ?
Got it, 20N50 & IRFP460 but don't want to use them.
Extract of 20N50 datasheet
RDS(on) < 0.27 @ VGS=10V, ID=10A
So @ 20A, Conduction losses = 20Ax20Ax0.27 = 108W
Now 30NC60 :
VCE(sat) Collector-emitter saturation voltage VGE= 15 V, IC= 20 A VGE= 15 V, Typ 2.1V, Max 2.7V
Same idea : 20x2.1=42W, in worst case 20x2.7=54W
Switching loss and idle power consumption 160 V DC ?
Good question, to be honest I don't know and I don't care. Seriously, they should be 5 to 6W switching losses (50mA), but I repeat : I don't care, not my goal to made the best efficient amp.
Class D very inefficient at low output power with 160 V DC Rail
See end of previous answer.
One more time, I'm not "purist", I made electronics for fun.
