What? You don't do analog? only CDs and other digital media?Hi Scott, I can confirm this. I spoke with Czar after his presentation AES San Francisco 2008: Tutorial T13
Meanwhile I don’t have any records
AND
There was a fellow DIYAudio guy here who either posted a pic
or someone else posted a pic of them with himself...Maybe it was
Ed?
I think it also had to do with a discussion about the presentation
and a solution that was proprietary etc. At some point in some
thread here in DIYAudio the solution to the problem was posted
on an attached schematic. Then I think the guy got pissed that
what was posted wat the correct solution too, and the cat was
outta the bag, therefore it was publicly disclosed through no
fault of the guy, yadda...yadda...yadda... legal mumbo jumbo, et al,
and so it could be discussed openly.
Then it was.
I still don't know which thread or with whom and the specific topic
and Sorry Dimitri i get it now, finally, I don't have any documention
or citation.
(snipage)
Now, I'm letting all my techniques for good sound out here, so you should respect me (and that includes you Syn08).
Now they will respect you, and in the morning,
they will respect you even more.
The correct solution is a Ayrton-Perry wire-wound resistor (see here Ayrton& - Wikipedia ). Mills do the best ones (great resistors for CFA feedback networks BTW - I measured the L on the 1k 10W that I use at 36nH which is about the 3x a straight copper track on a PCB).
Details here Vishay Mills - Vishay Brands - and they are available from mouser and DK.
Bonsai, can we cut to the chase?
I can't afford to make any more mistakes buying the "wrong" resistors, etc.
Would you be kind enough to let me know which series is best, please?
And if you don't want to disclose it for public consumption please feel
free to send me a PM.
Yes, thank you for sharing Richard, my memory isn't that bad 🙂 No, I haven't tried it yet and as a test for accuracy, the principle seems perfect?I suggested a process to learn how accurate your system is. Have you tried it yet? BTW I think open tests are fine to detect differences but not for accuracy until you know from practice and experience what it ought to sound like. So, the suggested process can be used as practice also.
Perfect for "they are here" not so good necessarily for "I am there"
Wherever there is...........
The you are here or you are there will not change. That is in the way the recording is mic'ed and your own speaker/room acoustics. That doesnt change. To sound just like the familiar voice uses the same room/acoustics.
THx-RNMarsh
That's what I mean, the room acoustics are still there, obviously listening nearfield makes a difference. This is a test for how similar the speaker's interaction with the room is to that of the sound source in the room, among other things
You’ve heard of making the speakers disappear (transparency) right?
Do you think it’s possible to make the room disappear at a normal lp (8’-10’ let’s say) in a normal home setting?
Close mic recording will eliminate most of the problem (on the tape).That's what I mean, the room acoustics are still there, obviously listening nearfield makes a difference.
Of course, a real voice will not excite the room resonances the same way than a speaker. But I think our brains are pretty good at eliminating-it.
The real problem I see with the RNM tip is the mike used. They can sound very different.
So, if your system sound very accurate in this comparison, it means it compensate nicely the drawbacks of the mike ;-)
Yes almost.Do you think it’s possible to make the room disappear at a normal lp (8’-10’ let’s say) in a normal home setting?
Tip: Acoustic damping (carpets, curtains etc.) + Near field listening + Horns.
For accuracy I think that would be an aim? In practice it may not be necessary depending on the speaker/room/listening position interaction and psychoacoustics (re. Linkwitz etc)You’ve heard of making the speakers disappear (transparency) right?
+1 😀The real problem I see with the RNM tip is the mike used. They can sound very different.
Once upon a time, there was this LEDE (live End Dead End) thing in the recording studio design.
Prof. T., can you confirm they still do this? If yes, you can do something similar in your listening room if you really want to hear what the musicians/engineers/producers heard.
I use a matched pair of rode NT3 for live stereo field and/or ambience on multitrack. I find them the most accurate/well priced mic for this job.....I’m sure there’s better but I can’t afford it!
I’m glad you didn’t say no!
I’m finding geometry, active/passive phase manipulation, may be just as/more important than room treatment.
I’ll know more as I set up my new room......I’m hoping my last success wasn’t just a one off!
If it makes you feel better to be condescending go for it.
It might happen from time to time that my response adopts the tone of the post I'm responding to; so, if you don't like the mirror image, methinks the remedy could be quite easy......
To clarify, even subjectively, people heard a difference, to say better implies more accurate.
Isn't that just your personal definition of the term "better" in this context?
Cyril Bateman demonstrated that there is a high correlation between dielectric absorption (and voltage across the caps) and harmonic distorsion.The distortion due to DA (Dielectric Absorption) will not show in sine wave tests. The symmetrical waveform will always average to zero in a THD instrument. IMO. Asymmetrical tests are needed and then you see the affect. A fast sample-hold instrument of transient waveforms (music) shows difference and how the differences are correlated to the sound.THx-RNMarsh
For exemple, he found the ceramic COG caps are among the best for low harmonic distortion. Samuel Groner confirmed how good and reliable they are :
https://www.diyaudio.com/forums/equ...omatic-distortion-analyzer-9.html#post4549551.
It seems that since Cyril's articles, COG caps are use more often used.
No. Was it their's?Isn't that just your personal definition of the term "better" in this context?
And get hold of whatever speakers they were listening to.Once upon a time, there was this LEDE (live End Dead End) thing in the recording studio design.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
