Simple PCL805 push-pull amplifier
Your dummy load resistor seems to be a 3W type, and it will be on flame with 20W across it. Your subjective loudness comparation with the class-D amplifier is revealing. Class D amplifier clipping sound nasty, so you notice even the smallest bit of it. Clipping on most tube amplifiers (and especially the one you have built) is less noticeable so you can turn the volume level up more; how much also depends from the type of music you are listening and from the speakers.
As side note, I have a China-sourced multimeter identical to the one I see in your picture across the high voltage power supply, but I use it only for low voltages because the class type stamped on the panel and on the probes is bogus (just open it and check for yourself). Do not even attempt to measure anything near the 1000V listed on the range selector, it will be dangerous. I suggest to use better probes and meters if you want to work on tube amplifiers. I would be not at ease using that instrument on a typical 250-300V small tube amp.
You are right. The 91Hz sine was created using my phone at it's highest volume (~2V P-P). With music coming out of it and using this amp with the phone volume at it's highest, the distortion created is clearly noticeable. I usually lower it by 2 steps and then the distortion becomes unnoticeable. I think the last 2 steps are software amplification.
I have tried folk, rock, hip-hop and even MIDI on it and it still sounds fine.
About the multimeter, don't worry. I know these are awful, but I can't afford anything good like a Fluke or something. I have owned a few cheap but definitely better than this multimeters and I've fried them all because of high voltage. Note that this has been half-dead; the amps range and transistor gain tester part have been fried. I have made that Arduino based multimeter which has a 16 bit ADC with 0.25% resistors which have been calibrated. I use that for voltages less than 50V.
As you might have noticed, I'm a bit of a noob when it comes to tubes. I have bought 2 PCL805s and a PY88 as my first tubes and have started experimenting. Most of the class A amps with this tube on the internet don't work LOL.
Yeah. I just this cheapy does it accurately at 91Hz.
One more question
This class A amplifier I've built has this weird feedback-like thing when it doesn't have input audio or is not connect to a device. I have added a "mute" switch which shorts out the gate of the pentode to eliminate the ear piercing noise. How can I remove this feeback thingy?
Please show the schematic.
The schematic of my crude class A PCL805 amplifier.
Hey guys
I'm looking for a simple-ish PCL805 push-pull amplifier which has been proven to work.
I have 2 PCL805s, a 170V power supply, and a transformer.
I have made a class A amplifier using one of those tubes and it sounds great with about 20W of power at a 3Ohms speaker ( 2 x 6Ohms ).
I would like it to have only 2 PCL805s and no solid state devices except diodes.
Thanks, guys!
I think you can not get 20W with PCL85, but 12W (max) can be obtained very lightly, and at 10W THD <1%. So the diagram is the one below, the voltage amplifier and the defazor (Cathodina) are inspired by the colleague @ Davorin, a very inspired scheme. Maybe this configuration will help you.
Hello
As the other fellow members showed me, my calculations were wrong.
Thank you for the schematic!
I've built several amps with the ECL/PCL805/6GV8/6F5P. Here's one:
https://www.diyaudio.com/forums/ins...undred-buck-amp-challenge-43.html#post5962424
Just ignore everything to the left of R7 and substitute the second triode for the MOSFET. It uses a garter bias and triode strapping on the output pentodes. The garter bias can be eliminated by getting rid of (shorting over) R21, R26, and R28. Also C10 is probably not necessary unless your source is very weak.
