ARC PH5 help
I ran through B2 Spice as well, specs look nice for the 2SK170 JFET.
THD is 0.002% for a 5mV Input, output is 27mV p-p
Output noise at 20K measured 70nV/sq.rt.Hz.
Just so I understand, 4 matched 2SK170BL for the difamp and one for the CCS?
Maybe I should invest and learn LT SPICE/ B2 SPICE. Where can I get a copy?
LTSpice is a free download, but you will have to acquire Most tube models, and a majority of discrete SS components yourself.
B2 Spice is a John Broskie product, that was put together several years ago, I got in on the ground floor, before the price was marked up. It will run close to $600.00, but it is loaded 1000’s of components, including ALL the popular tubes, OPT’s are another story, I haven’t been able to get any OPT model to work properly. I’ve asked for technical help but didn’t get very far.
But so far as accuracy, it’s been at least 90%. Which saves a lot of breadboarding, I’ve designed phono stages that have been better than 95% accurate with B2 Spice.
Hi All,
It's been a little while since we talked. If I wanted to add passive RIAA to this design, where should I add it? I'm thinking after Q5? Am I correct that there is a RIAA filter already there...just not the complete network? The second network (bass?) is the feedback loop...which I want to remove. I plan to use something like the passive RIAA network from the PASS or Salas designs.
The Salas folded Simplistic and the Pass Pearl (1 & 2) have it between the input stage and second stage? Not that I need to copy them, just a question. I could put the second filter after the tube stage. Trying to remove the feedback...but maybe I should just trust ARC.
I know they are not the know all/end all in design. The changes I made to the power supply were a dramatic improvement over the stock design.
Since I'm now talking "analog source" should I move this question to that section?
I don't think I can make comment without simulation. Just to say I find if you want the lowest distortion as with an op-amp have lots of gain and apply negative feedback. The circuit does look like an op-amp.
Since this is a phono stage and a fet/tube hybrid, I would ask if a moderator could move, or link, all of this over to the correct section (analog source)?
I don't know how to move all of these posts?
I would like to continue the discussion over there, but I do thank all of you for your help and input.
