Works for me but anyway ZenMod posted an updated one (the original had a capacitor reversed) with voltages / currents, here it is. It's a general one, I haven't seen one specific for TDA1541 and some diyers stated that it works as it is.
Hmm, thanks i will look into it, but the +/- 30V are a problem for me. I can only go up to +/- 18V with my psu...
Just getting ready to power up the DAC. I've got adjustable, floating Pos. and Neg. Vregs . Does input at Header 2 get 26vdc, or 13vdc per input pin?? Meaning 26 across the two input pins or 52vdc?
Thanks,
Greg
Thanks,
Greg
It's 26V across the input pins.
Ben Mah,
I've been sitting here this whole time waiting for an answer...and you arrived!!! 😀
Thanks, that's what I thought.
Greg
Everything powered up, output offset zeroed! But, my I2s to Simultaneous board is not powering up. I'm measuring ~5v at D1, ~3.3 at C3, and all across the board the caps are measuring at ~3.3. But D1 is not illuminated.
Any ideas?
Thanks,
Greg
Any ideas?
Thanks,
Greg
Hi Greg,
It may just be that the LED is around the wrong way.
Yes, I had the polarity backwards. Everything working, but my XMOS adapter is not driving the i2s card.
Ryan,
Everything is powered but I’m not getting any audio, only digital noise. I’m running an XMOS USB to I2S -> I2S to Simultaneous board -> Distinction.
I’m using a tube output stage, so R35, R36 not populated. Those pads are not shunted when unpopulated, correct?
Like I said earlier, I was able to trim the offset out.
Greg
Greg
I would suggest you try to determine which board is causing your problem. Have you tried your D3 with I2S input? If not, change the D3 board to I2S and connect your USB to I2S board to the D3. If that is successful, then you know that the issue is with the Simultaneous board. If I2S input does not work, then you have an issue with your D3.
How do I change the D3 for I2s?
On the back of the board, there is J1, J2,and J3. Put solder on J1 for I2S, or solder on J2 for Simultaneous. That is shown on the back of the board. For Simultaneous, did you solder J2?
If you are changing inputs, you have to desolder the input that you are changing from.
Yes, but I am in another great city right now. I'm in San Francisco for Burning Amp.
I'm debating whether to come.....I can make it for Sunday. Just haven't decided.
Ryan,
Greg
Hi Greg,
You can leave R35 and R36 unpopulated, they are an option for an IV resistor.
If your getting digital noise check whether you have the outputs connected to the correct inputs, and if you haven't already make sure you put a solder blob on J2 when running in simultaneous mode.
Hi Greg,
Ryan / Ben,
I put a shunted J2, still the same. Can you guys look at my USB to I2S converter?
Singxer C-1 XMOS Digital Interface XU208 U8 Upgraded Femtosecond TCXO Audio | eBay
I'm next going to try I2s in lieu of Simul. With I2S I go directly from the converter to the D3, correct?
Greg
Hi Greg,
I don't have a Singer C-1 but after searching and reading about the Singer on the net, the Singer outputs I2S. This page shows the I2S output pins and power supply connection and Ground pins:
Singxer C1 (NDK/EPSON)- USB Digital Interface Board – XU208 chip | Kitsune HiFi - HoloAudio USA
Yes, for I2S, connect the Singer directly to the D3.
Ben
Ps: The Singer ground needs to be connected to the D3 if in I2S or connected to the Simultaneous board if using Simultaneous. From Simultaneous to D3, if you are using the connectors, Ground is already included in the cables.
Ben
Hi Greg,
Ben
Ben,
I never connected ground from the Singxer to the simultaneous, I checked the ground pinout and discovered a solid ground all the way to the D3. However, I will do as you say and add a ground from the Singxer to the Simultaneous board.
It looks like my tube I/V has a an approximately 600R input impedance. This is the Abbass audio I/V which I know has been used with this dac board before. What should input the input impedance be? Approaching zero?
Thanks,
Greg
- Group Buys
- DIY TDA1541A PCB "D3"
