Shanti Dual LPS 5V/3A , 5V/1.5A
I'm using a usbridge sig for its usb output. I made a 5v PS with a couple ultracaps and a 78s05 to power it. Running dietpi for naa in a hqplayer setup. It upsamples everything to dsd256. DAC is a diy job made from a diyinhk usb adapter to an ian fifopi and an ian dac.
With the usbridge, I get pops/clicks, almost reminds me of vinyl but pops are same volume but happen at random times. Same setup, running from a highly tweaked pc is fine. I had tried "tweaking" dietpi, but it was worse that way. So I remade the sd card with the image from allo.com, running that image with no changes now.
Connections to usbridge are ethernet cable to a switch, usb cable to dac and +5VDC from my diy PS. Note the +5 is very stable, at 5.02V or something like that. I didn't tie ground point to anything.
I also used to use usb power to power the diyinhk adapter and the 5v part of the fifopi, but I put this stuff on it's own supply and it made no difference.
Suggestions?
Randy
We have sent the OS images with 4.14 kernel (only for those DACs that don't support native DSD on linux, like Chord). That will fix "vinyl like pops"
Rest of DACs are not affected and you can use latest images from Moode. PCP , DietPI , Ropiee .
Thx you for the patience .
You sent it to whom?
Where can I download it?
If you go here
USBridge Sig - Ultra low noise RPI
Click on Supported OS, then the DietPi directory, I see a DietPi version with today's date.
I expect that is the corrected version for the "pops" problem, but will wait for confirmation.
I didn't see anything else that was updated in a quick look at the files.
