The YARRA Preamplifier/HPA for Melbourne DB Group Buy
Wayne’s BA-18 preamp board re-visited, now with output coupling caps. Since I had to install output and input coupling caps on the Yarra mainboard, I thought I would give the WBA-18 another try. It had some pretty bad DC offset drift due to the steep temp dependence of the the transistors. Just wafting your hand over the boards would make it wander 15mV.
Installing it back into mainboard - now WBA-18 also fitted with some serrated fin stamped heatsinks on the output BJTs:
attachment.php
The preamp measures very clean now. The huge sub 1000Hz DC drift hump/hill in the old FFT is gone. Preamp displays natural second order distortion and lower third harmonic. Overall very low levels in the 0.0017% THD range for circa 700mVpp output into 50k load.
787813d1571074713-waynes-ba-2018-linestage-c7a27f37-d38c-456a-ae2b-181d3be34b5e-png
MDOT Reference, this is what it looked like before coupling caps:
762898d1560517273-yarra-preamplifier-hpa-melbourne-db-buy-wba18-2vpp-52kohm-fft-jpg
Ok, here is the Korg 6P1 preamp data in one place.
Setup Instructions: Adjust pot to set voltage = 12.00v at the plate of the 6P1 (same as left leg of R121 or pin 7 or 10 on the 6P1). This achieves the design performance of dominant H2 and monononitcally decreasing higher order harmonics while keeping overall THD low.
Very important: you MUST use AC-coupling caps on the Yarra mainboard for both the input and output or the Korg 6P1 preamp board will not work.
778463d1567193097-yarra-preamplifier-hpa-melbourne-db-buy-korg-6p1-yarra-3d-render-pcb-02-jpg
778461d1567193097-yarra-preamplifier-hpa-melbourne-db-buy-korg-6p1-yarra-schematic-v0-jpg
778464d1567193097-yarra-preamplifier-hpa-melbourne-db-buy-korg-6p1-yarra-top-stuffing-guide-v0-jpg
787418d1570917320-yarra-preamplifier-hpa-melbourne-db-buy-korg-6p1-yarra-test-build-01-jpg
787419d1570917320-yarra-preamplifier-hpa-melbourne-db-buy-korg-6p1-yarra-test-build-02-jpg
BOM in txt file below or same info in the .xls file zipped as attachment:
Code:
Part	Value	Package	Description
C101	470µ	E5-10,5	POLARIZED CAPACITOR, European symbol
C106	0µ1	C5B2.5	CAPACITOR
C111	10µ0	C5B11
C113	10µ0	E2,5-5	POLARIZED CAPACITOR, European symbol
C115	10µ0	E2,5-5	POLARIZED CAPACITOR, European symbol
C116	10µ0	E2,5-5	POLARIZED CAPACITOR, European symbol
C117	10µ0	E2,5-5	POLARIZED CAPACITOR, European symbol
C118	10µ0	E2,5-5	POLARIZED CAPACITOR, European symbol
C122	0µ1	C5B2.5	CAPACITOR
C131	470µ	E5-10,5	POLARIZED CAPACITOR, European symbol
C132	10µ0	E2,5-5	POLARIZED CAPACITOR, European symbol
N131	LP2950-33LPRE3	TO92-123
R101	40R2	CMF55-2V
R102	475k	CMF55-2V
R103	475k	CMF55-2V
R104	1k0	CMF55-2V
R105	1k0	CMF55-2V
R112	1k0	RTRIM74W	Trimm resistor
R113	33k2	CMF55-2V
R115	150R	CMF55-2V
R117	150R	CMF55-2V
R118	270k	CMF55-2V
R121	10k0	CMF-55
R122	1k0	CMF55-2V
V104	2N7000	TO92-SGD
V111	6P1	6P1	KORG 6P1
V121	2N7000	TO92-SGD
X101	M3	M3_VIAS_NEU
X102	22-27-2021-02	6410-02	CONNECTOR
X121	M3	M3_VIAS_NEU
X131	M3	M3_VIAS_NEU
X132	M3	M3_VIAS_NEU
Hello all,
I don't know much about electronic design, but all my builds have been successful (knock knock) primarily because I am careful and can follow directions. I've finally procured enough parts to at least start building the Yarra. I will be running it into M2 (not M2X) and Aleph J builds. Both of these amps have enough gain for my habits to not need much gain from the preamp. I ordered 15 volt transformers, and the WB18, Melbourne and Korg daughter boards. I am going to start with either the Melbourne or the WB18 because I don't have a solid state preamp.
Are both of these boards fine with 15 volt transformers?
Might one of these boards be better suited to the M2 and Aleph J?
My Yarra/Melbourne is using 12+12Vac trafos, and it can drive the M2X Edcor line auto transformer directly without any daughter cards effortlessly, vol knob at 9~10 o'clock position.
I also did bypass the edcor(removed from pcb) and drive the output stages, its around 1~2 o'clock position, thinking to upgrade to 15+15Vac trafos for more ooomph!
For Mofo, think i need 22+22Vac trafo. So happy that this Yarra is so versatile.
First of all, i believe in keeping it simple ...
The Yarra/Melb DB combination actually sound very good driving the Edcor autoTrafo directly, bypassing all the buffer daughter boards. Soundstage is very much lively, a tinge of warmth, good details but not being bright. Basically nothing is lost here.
However, when Edcor is bypassed, i hear slightly more details in the high, a little bright and pretty flat in the bass dept or lower frequencies. Liveliness is gone, music sounds dead to me.
Next for total hums elimination, i will remove the Edcor from the main pcbs and make a interconnect cables with the Edcor along in them. This is to allow me to physically place the Edcor anywhere i like it to be away from any trafos.
Those who have the Yarra and M2/M2x may try the above experiment, hope you like it too.
