Are there any budget tweeters (€ 30-50) that can rivalise against the expensive ones such as scanspeak lluminator, seas excel, etc?
You still have to make a solid box with rounded edges, and you need a router to do a flush mount. Perfect phase alignement at crossover frequencies and tons of power to digest. Why would you choose for a poor tweeter😕🙄😛
There are some not so expensive, yet very, very nice tweeters. Have an educative and illustrative look at Measurements and compare | HiFiCompass and dig yourself a little bit into comparative search. Chances are good that you will find your match.
Without the geometry, form of the tweeter in ambient and without the necessary filter, it's difficult to judge from those numbers. I see some magnificient tweeters ( there's a thread nowadays with a 300$ Morel ) so the area for improvement is lightness of membrane, voice coil, I see that +-1mm excursion is possible, as a,low ( 6-800 Hz) resonant frequency too. Plus you put the CAD studied motor assembly and the low-friction assembly
and voilà, high-end tweeter. On the other side, plastic shells and high Fs tweeters.
The SB Acoustics 26adc/cdc and 29rdc seem to get high praise on here for providing high quality for the price also seem to be fairly easy to work with. However as already said it is all in the execution and what you are pairing them with and how low the crossover and what order crossover.
For example the NAO Note II RS open baffle uses a £17 tweeter but it is crossed over 4th order at 6khz iirc so working well with it’s means.
I am associating with 6 1/2inch mid driver either on of Peerless HDS 830833 , 830875 midbass or discovery scanspeak 18W/8434G00-8 or 18W/4424G00. Haven't chosen yet.
Assuming all of what you mentioned is accomplished:
"You still have to make a solid box with rounded edges, and you need a router to do a flush mount. Perfect phase alignment at crossover frequencies and tons of power to digest. Why would you choose for a poor tweeter"
Can anyone name some budget tweeters which are very highly appraised as regards sound quality as I am particularly sensible to real sounding cymbals, hyats and lifelike sound of acoustic guitar being myself a guitarist
You can get a Dayton DC28F-8 for €27,45.
Inexpensive drivers can never equal the best, though you can mitigate the differences somewhat in the crossover design.
Reading the OP, he doesn't want to choose a poor tweeter, he wants to choose an inexpensive tweeter, hence the question as to whether there are some that are inexpensive but also good. But everything's relative - what's the definition of "inexpensive", are you looking for something for £20 or £200? And what other drivers will it need to be working with?
Since I prefer 3 way speakers, they give more freedom in design and I rely on the midrange driver which is difficult to find. Aurasound Whisper 2" is quite good, associated with a Dayton Mini-8. A small faceplate is a must with little drivers and 3 ways. I have another design with a nameless midrange and a little Sica, this >Altoparlanti LP 38x50.18/N5 TWI am associating with 6 1/2inch mid driver either on of Peerless HDS 830833 , 830875 midbass or discovery scanspeak 18W/8434G00-8 or 18W/4424G00. Haven't chosen yet.
"You still have to make a solid box with rounded edges, and you need a router to do a flush mount. Perfect phase alignment at crossover frequencies and tons of power to digest. Why would you choose for a poor tweeter" I was joking!
which has ferrofluid.
See that those play at frequencies > 5 kHz
That's right not a ppor one , but a very good sounding tweeter for a price tag of around Euros 50
max
max
#6 . For a 2 way
I am associating with 6 1/2inch mid driver. Most probably peerless HDS 830875 midbass or discovery scanspeak 18W/8434G00-8 . Approx 20L enclosure.
worth a look - done with the the peerless and a Seas 27TFFC - $47
SEAS Prestige 27TFFC (H0881) Textile Dome Tweeter
Another Peerless 830875 Execution
or this one from Troels which is open source for the 18W with discovery R2604/8320000 - $55.
ScanSpeak Discovery R2604/8320 1" Tweeter Ring Radiator
18W-8434G00
18W-8434G00
I have good experience with Visaton G20SC tweeter.
It doesnt have a particularly low Fs, but is a good performer, IMO.
I think it may be just one side or the other of your budget. Some SB tweeters may have some performance or value advantages, being more modern drivers.
On the other hand,
I saw these the other day
Monacor RBT-56 Magnetostatic Ribbon Tweeter
£22.05
€24.95
But possibly this isnt useful for a 2 way?
There are several Monacor tweeters, which may fit your budget and look worth consideration (but I have no personal experience with them)
On the other hand,
£22.05
€24.95
I did a 2 way with the Peerless 830883 (documented here on diyaudio), paired with a Seas 27TBFC/G, which will fit into your definition of budget tweeter. I could also have built the speakers with the TDFC, but found a deal on the metal tweeters. Both are right enough tweeter that can be paired successfully (i.e. crossed low enough) to a 6.5" mid-woofer, and the build quality is good.
Beware of low cost tweeters where the performance is at the expense of consistency.
Ralf
Ralf
The ScanSpeak D2608/913000 (Peerless 810921) springs to mind.
Highly recommended by HiFi Compass and Zaph but probably a little bit over budget.
Low moving mass and decent Fs.
Closer to your budget the ScanSpeak R2604/833000, twin magnet version of the already mentioned R2604/832000 with higher efficiency and lower distortion for only a few € more.
With Scanspeak discovery you should have very good speakers for a good price.
If you don't have tools to design the loudspeakers go to a kit, perhaps you want to learn design loudspeakers.
See Troëls designs :
18W-8434G00
Other design :
Prima - JustDIYIt !
It is a suggestion. I think like others have suggested, SB acoustics has made very good drivers for a very good price.
For good tweeters, the Seas 27TBFC/G is a serious candidate 😉
🙂Thank to all. I shall list all your proposals and start a shortlist to enable the final choice.
I can vouch for the high quality to cost ratio of the Monacor tweeters. Available in both dome and ribbon varieties.There are several Monacor tweeters, which may fit your budget
Dome
- budget vs expensive tweeters
