Acoustic Horn Design – The Easy Way (Ath4)
A few pictures will tell more than a thousand words, I only have to code it first. Then I will show better what I mean.
Don't the two curves have to match slope, not curvature? With slope only A works.
Actually it is easy to match both. The slope is allways matched by simply rotating the clothoid - it doesn't matter where it starts. Curvature increases linearly along its length so it's all about finding the right point.
Mabat,
In post 212, you show a poorly terminated os (your pic below).
Is that poorly terminated because of the last bend to the mouth (baffle) ?
If so, what would a good os look like ?
I though os was conical, but with a rounded throat, then a round over at the mouth.
Couldn't tell you how fast it opens, just better dispersion for a wider mouth to distance to throat.
How to Reduce Diffraction on Your Conical Horn
Yes, it's too small, too abrupt.
OS is not a cone with a rounded throat. It's hyperbola from the throat to infinity. Mouth termination is not part of OS and should be as smooth/gradual as possible - at least this is obvious from the calculations so far. It's a continuum, there's no dividing line between right and wrong, however.
I've finally managed to figure out the one-describe-it-all equation, from throat to mouth.
Not there yet, but close... 🙂
(Black line is an OS connected to a clothoid, orange line is the new equation.)
Ahhhhhh, thank you.
That makes sense.
Many os ive seen seem to have that last soft corner (mouth break ?).
I'd figured it was a place that could be improved.
Tricky where to deviate from conical, and how fast to do it.
Even my 2384 has a bit of bend in the path before the last mouth round over.
I bet it helps (conical slight bending).
Again, thank you.
Yep, I know, thanks. I only have no idea how to calculate all the parameters based on desired horn dimensions. Right now it's only fitted to a particular sample - just a quick excercise. I also felt there must be an equation like this, maybe this is not even the best one...
Oh, and it actually should go like this -
The second term is almost zero near the throat - it makes no real difference and can be allways added, so one part equation like this is well possible.
What I meant is to how to make the shape copy a clothoid, based on throat diameter, coverage angle and the length of the horn (which must be a parameter). It's not at all obvoius to me. Maybe someone could try...
(In the presented example clothoid begins at half of the length. This could be fixed or be a parameter as well.)
It may be that it is not really necessary to follow a clothoid, who knows...
