Low power 2 W @ 8 ohm, 4 - 16 ohm usable simple, class A SE - any recommendations?
You have up to 3V out of your DSP. You need 4V to make 2W in 8r.
So gain should be barely above unity.
How do you feel about heat? Push-pull or choke-loaded A is 50% efficient, CCS-loaded is 25%, resistor-loaded is 8%. So for 2W out this leads to 4W, 8W, or 24W dissipation. (Allow another 20% for losses and bias.)
The 24W competes with a 5W SE tube amp, but in Silicon will be quite large heatsinks and resistors. (We can't run a heatsink as hot as a tube, and we don't like resistors too very hot.)
An inexpensive 24V 40VA (1.6A) furnace transformer may be an adequate choke, especially for mid-high audio band. It's not made for DC, but worked well below rating and not aiming for 40Hz, it may be fine.
Let’s not reinvent the wheel. Just go with a MOFO and microwave oven transformer. It’s all worked out in this thread.
Build This MoFo!
649046d1512253002-build-mofo-mofo-67mh-uwave-choke-jpg
Superb harmonic profile:
649041d1512252857-build-mofo-mofo-67mh-1-7amp-2-83vrms-8ohms-fft-png
With a 24v 5A SMPS you can get about 11w rms. Will need a preamp with lots of swing though.
But 2w is something in the realm of maybe a headphone amplifier output from your sound interface.
A simple powerbuffer with low distortion and very low noise due to the lack of voltage gain. Can be powered from a cheap 13,8 volt 150 watt Meanwell SMPS.
I would add a 1 mH air core coil and a 10000 mF filtering capacitor to each channel to lower the switching noise from the SMPS.
C1 and C2 does not need to be that large in real life. If you are using the amp to drive a high frequency compression driver then C2 can be 22 - 47 mF or so.
I would use at least a 1000 mF capacitor for C1.
With a simple power resistor instead of the SRPP modulated current source you get more distortion and less voltage swing, but the amp is very cheap and easy to build with point to point soldering of the components. R1 can be a TO-247 thin film 100 watt power resistor.
The slightly increased THD is mostly a positive going second harmonic making the amp sound more like a nice tube amp with a more forward and vivid presentation of music.
Since my power requirements are low, I decided to try a follower powered from 12 V. It will work with a 5 mH inductor or a resistor and a relatively small heat sink.
What gain stage would be recommended when I will need more Watts?
cumbb, I meant that the gain stage would be inside the same box and powered from the same supply as the follower.
Actually I built this hybrid ECC88 (for gain) + Mosfet Follower amplifier a long time ago (as a school project, designing the PCB and building a prototype), I need to dig it out, it never made it to a final product - especially due to the crazy cooling and power supply requirements.
I meant too;-)
The school project is too complex to get a clean tone, sound. And never a complementary-transes-pp and not "complementary-psu's". My mind.
A valve for gain is a good idea.
You could use an ECC182, 13P1S, ECC86, EF98 ... driven by 12 Volt.
Should be possible.
