900W H-class PA Amp with Limiter
No *.lay files, gerber in ZIP file. Sprint Layout import gerber.
Roger
Roger
lm324 , thank you very much for your answer !
I downloaded zip file and import files to SprintLayout 6 but i have some problem with drill file ....
For NMOS,
I think the Labgruppen auto-oscillator is the best.It's more complicated, but it's much more efficient and it works for sure.
The rest of the scheme exists on the net (right here on the forum).A little mistake PWMNATD=PNP,PWMNPATD=NPN transistor.You can also try the downconverter from yamaha, it's much simpler.
hi sir, did you manage to make the modifications? please post the results and the schematic diagram you used.
class TD more photos
here are some more photos of class TD from Electronics Handbook
