I have custom pcbs for sale, see the link in my signature.
PM sent. Thanks.
PM sent. Thanks.
Mr. Roender's gerbers are here: post 42
I think, for successful build you must read a lot 🙂
There is other themes for this excellent amp FC-100.
Roender's FC-100 prototype and builder's thread
Roender'S FC-100 - Group Buy
LT3062 based PSU
RMI-FC100 MKII, single ended folded cascode VAS
GB For RMI-FC100 Parts
ZDR custom project seem also looking very good!
Kudos how will sound FC-100 on High Sensitivity loudspeakers with 15"woofer and front loaded horn.... 🙂
Anybody?
Anybody?
Thanks for the links. Need to look for Excellon file viewer now.
RMI-FC-100
Hello everybody!
I have a question ref. the Idss clsifiction of 2SK170 fets.-
Of course they have to be in the same Idss GR, BL or V classification and matched.
Q. - can I use any classification for input stage of RMI-FC-100 without any changes?
Q. - I understand the BJT Hfe. Is the Idss the same?
Thank all of you!
Hello everybody!
Thank all of you!
It's been many years since this thread has started, and I am still waiting to hear anything better than this amp. If you have heard it, please let me know what to upgrade to (DIY or not🙂
Hello!
I would like to build this amplifier, bit I want to redesign the pcb so it will fit in my case. I want to use smd components where it is possible and I also want to use active components that are still in production. I think that the most problematic parts are the input fets, 2k170. Can you tellme, please what available parts can substitute 2sk170 in this design? 2sk209 wold be a goo choice?
Thank you!
Thank you!
Hello!
Thank you!
SMD fets have been used as a replacement already, you just need to search this thread (not working for me at the moment)
If you want to try something different look here, CFA with VMOSFET not laterals.
https://www.diyaudio.com/forums/solid-state/243481-200w-mosfet-cfa-amp-92.html#post4580555
I don’t want something different, I want something better🙂
I just tried it against musical fidelity m3si, and MF is going back to the shop.
ITCO:
since I do not know how to add a .pdf-file to the answer of a PM, I will add the drill-template of my FC-100 PCB into this post.
Please compare your version of my FC-100 PCBs with the image attached:
Best regards - Rudi
Best regards - Rudi
@zdr
Great build🙂
Where did you get the PCBs?
I have plenty, see the link in my signature 🙂
hello all
i just ordered a set of pcbs from Rudi, in my quest to find matched transistors..i came across this seller at ebay...'i know' ebay may not be the best place to source these things but check this place out. what do you think....https://www.ebay.com/itm/Toshiba-2SJ74-2SK170-LAB-MATCHED-PAIR-0-1mA-7-8ma-Idss-B-BL-Range-/253046095299
Idss must be over 9ma.
thanks for chiming in with that info......how do these look?.....
Toshiba 2SK170 LAB MATCHED QUAD to 0.03mA / 4mV "B" "BL" Idss 10mA range | eBay
Wow, at $50 a matched quad, they had better be real!
-Chris
yeah ...im kind of weary of sourcing from ebay of all places. do you know if the fets from the diy store here can be used in place of the 2sk170s
- RMI-FC100, a single stage audio power amplifier
