Next thing to sus out is the gain. Way too high. I think that would make it susceptible to picking up its own noise. Gain issue mentioned here -> Ebay amp - is 500W believable?
I found the gain on my eBay modules was way too high and it would actually oscillate. I reset mine back to the reference design and it works great now.
See this thread for details of what I did:
Fixing [and preventing] a fried Zobel network
Now that you mention it, at full output at 1kHz I did notice the carrier frequency was quite visible. Probably lower again than 175kHz. I'll just run and check.
Okay - At just on clipping the ripple voltage touches 65V peak and you can definitely see the frequency change as the voltage rises toward the peak. Minimum frequency at the top of the waveform is 74kHz...
I did see that post the other day but couldn't find it again.I found the gain on my eBay modules was way too high and it would actually oscillate. I reset mine back to the reference design and it works great now.
Thanks! 🙂
Edit -> I just realised that seeing the other end of that resistor goes to a virtual ground, the input impedance of the amplifier would depend greatly on the value of that resistor. Increasing its value would reduce the need for a larger value input capacitor. Probably the cause of poor tone burst response as per here -> Lousy 30Hz tone burst.
Thanks! 🙂
Yes, correct. You should see _much_ better LF performance with higher input impedance.
Here we go. Two of those boards driving a 24 volt 3-phase induction motor at 450Hz. 13,000 rpm anybody?
YouTube
YouTube
YouTube
That's an interesting use for those modules!
This time driving a 380V 3-phase 6 pole 1000rpm motor at 860Hz and 16,800 rpm.
Link to EEVblog posting
what is the undervoltage shutdown with this board?Yes there is often an undervoltage lock-out which disables the amp when the rails are too low
If I like to use this board with ±50V (±45..±55V), which parts must be changed?
What is possibly fried after applying too high voltage? +-77V, now dead. The XL7005 SW pin is 1.3ohm to GND.
To answer my own question above, the 10 ohm resistor was cracked in half.., the three 16V zeners were broken and the buck converter too.
I repaired the amplifier by biasing +-12V auxiliary output from my power supply to -Vcc on the amplifier.
What can be done about a hot output inductor? Is the trim-pot at the input side of any use? Can the switching frequency be measured with a multimeter and adjusted?
I got 2 new boards
I got 2 new boards form bangod. I had 2 already an I replaced the R13 from100Ohm to 4.1k due the Zobel network.
But the new boards have the R13 and R14 0 ohms. Is this correct ?
I've been spending half a year struggling with getting rid of power supply ripple noise in my car. You have a couple of things to try. Do the easiest thing first: lift ground from the RCA inputs, i.e. disconnect the black. Try this at both ends of the line audio cable.
Others things to try is to isolate the power supply with a isolation transformer (expensive). Or put a ground loop isolator ($5 ea.) in each channel.
What would be a good minimum power supply to go along with this?
I chose dual 65 V, 10 A supplies for bridged pair of amps at 8 ohms. Dual 65 V 5 A supplies would work for a single amp at 4 ohms. Slightly higher voltage would be better for higher impedance loads.
Here is a schematic for the board along with a couple of mods. The gain issue due to R13 has been documented above. I also found the negative current limit kicked in way too soon, positive being fine, and so suggest a change to R11, see attached pdf.
The inductor and heatsink are not up to job of continuous full power output but when testing with music via a limiter that just went to clipping, the temperature of the heatsink was low enough that I could touch it for quite a few seconds and the inductor was cooler. I don't see that as a problem. No problem getting clean 380W into 4 ohms.
I used 8AT HRC fuses in the power supply lines and 5AT in the speaker as an average maximum power of limit 100W to the speaker seemed reasonable for music to me.
- Class D
- eBay amp - is 500W believable?
