Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
Apparently, MRII 594As are quite rare.
For the sake of completeness:
Personally, I'd (like to) try this one... on the MRII 594 and many other horns.
Changes are, it would work well. At least, it's also got a radial phase plug.
The specified 700Hz minimum XO freq. (for PA) translates in 500Hz, probably even lower, at home.
I 'grew up' with 350, 500 Hz and the M19's 1200 Hz sound like mush mids to me, but is the most popular Altec by far, so what do I know. :(
I mean seriously; listen to one with the horn disconnected, to me it's kind of like listening to an old upright washing machine sloshing with a max load.
GM
No, these were once ordered by a local audio engineer/entrepreneur and inherited by his business partner/friend who builds custom cabs.
So far I haven't been able to ID the manufacturer.
These are well made fiberglass horns, somewhat similar to Community.
They look similar, but identical, to some of the bigger EAW horns.
About 30% bigger than the horn on top of the stack in the first image and probably closer in size to the mid/high horn of the MQV 1394e in the 2nd and 3rd pic.
Yes, circa 2003 IIRC and guess I look that way because I 'are' one since age 12, though never in a club/gang/whatever nor can actually ride unless it was a three wheeler [gag] and much balder and pretty much 'dirty' white beard nowadays.
Apparently my looks haven't changed much though, I was at a birthday party for a 95 yr old friend the other day and a couple I haven't seen in 22 yrs were openly shocked that I didn't look much different WRT skin, etc., wise.
Summers here are so freaking hot/miserable due to high humidity [heat index was 102 degF today] that I wear a Van Dyke half the year.
GM
