Revisiting some "old" ideas from 1970's - IPS, OPS
I put Valery’s Tribute 3000 driver board on a Sansui AU-9500 plug-in driver board, changed Sansui’s original T03 output transistors to NJW1308G and NJW3281G changed the emitter resistors to .22 ohm as in Valery’s Tribute OPS but only 2 output pairs instead of 3.
The Sansui has separate transformer windings of 49v for the left and right outputs and a regulated 60V supply for the driver boards.
All the supplies still have the original 45 year old capacitors and components when I did the testing.
Measuring the voltage @ the load I calculate 99.4W per channel before clipping. Definitely worth changing out the old components.
Very good job man! Cool layout of the driver boards :up:
stonehome, nice job on your "new" AU-9500. The sound should be excellent, you also saw a power increase to 99.4w. Mine went from 45w to 72w RMS before clipping. I hiked the regulated supply to 44v rails to get there. SX-780 has 40v output rails which sag to 36v under load.
Sansui AU-9500/Tribute 3000
Well I finished replacing all the electrolytic capacitors in the power supply and throughout the amp. I am pleased with the outcome. Well worth the effort.
Now, does anyone have an idea of the cause of the spike on the square wave.
That's very nice. What PSU are you using? Are you using the 21st Century controller as well? I think I have those boards. You have inspired me to finish them.
Hi Terry, my power supply is a hybrid ha ha ha.
A bridge, some electrolytics, 75000uf/rail, a second cap bank(jeff's pcb, another board for cap. multiplier and +/-15v regulators..
this on the heatshink)
No, i haven't a protection other than crowbar...
Unfortunately up to now is unprotected.
I have some pcb for 21 century protection but not the microprossesor.
