Amount of hornloading in a Synergy horn
As the title suggests: how much hornloading can we expect a synergy to have for the sub 500hz frequencies? I guess it depends on the horn used?
I will be using a large biradial horn, with a 108x75cm (42,5"x29,5") mouth. I will be converting it into a 2-way with a 500hz crossover point, so off axis ports at 17cm (6,7"). I was planning on using 2x 15" drivers.
Question is:
- is there a ballpark estimation / rule of thumb to knowing how much hornloading this wooferpair will be able to get. Lets say over a 80-500hz range.
- Or should I model this? I'm not at home in all this software (like hornresp) so I dont really know how to do this.
- also, would this be a good range to use 18" drivers for? Or is this counterproductive?
To give you an idea of the raw response of a Danley SH-50, dual 12" woofers (blue trace) vs. the K-402-MEH dual 15" woofers (green trace):
Reactions: 1 user
The K-402 horn has mouth dimensions at the transition to the flange of 36" x 21".
Question is:
- is there a ballpark estimation / rule of thumb to knowing how much horn loading this woofer pair will be able to get. Lets say over a 80-500hz range.
- Or should I model this? I'm not at home in all this software (like hornresp) so I don't really know how to do this.
Now is a very good time to figure out Hornresp and its "Multiple Entry Horn Wizard" to do the off-axis port locations (but not the port sizes) and woofer sizing/TS parameter selections. While the user interface to Hornresp is a little frustrating at times, i.e., if you know how to do what you're trying to achieve it's easy to use, otherwise it can be a little frustrating to understand the exact sequence of screens and "record activation", etc. to get the MEH Wizard to turn on and give relevant results.
You can use 18" drivers, but my experience with 15" drivers having about the same T/S parameters as the Klipsch K-33 woofer (I actually used two 15" Crites cast frame woofers) usually will give you a very good starting point to try out your initial ideas.
I've found that the information that Hornresp gives you actually very limited, i.e., it does the off-axis port location simulations pretty well, but it really won't tell you the SPL on-axis--which is really non-flat response, as you can see from the raw response I posted above--or really what the effects of off-axis port area does. BTW: I recommend staying with two elongated 2.4-2.6 inch diameter off-axis ports for your 15" woofers, figuring a compression ratio of about 10 as a rule-of-thumb maximum in order to get good efficiency (woofer piston area to off-axis port area). Using undersized woofer ports is something that I don't recommend right off the bat.
So 18" woofers would provide even more low end than two 15" woofers, but note that I already get sub-20 Hz performance out of the prototype K-402-MEH with very little EQ (~5 dB below 40 Hz when in elevated mid-wall loading). The response of the MEH will be subject to room placement much more strongly than even a "W"-shaped corner horn bass bin, so you need to place the MEHs against a wall, and corner placement will give you a great deal more low end response without EQ boosts...about 6-8 dB more SPL below 40 Hz. If midrange early reflections are an issue around the MEH/wall location in quarter space or eighth space loading, simply add one or two (stacked vertically) 2'x2'x1" absorption pad at the horn mouth exit on the adjacent walls.
I wouldn't try to do the crossover with anything but a good DSP crossover unit. You might be able to use something as inexpensive as a miniDSP 2x4HD (but not the 2x4), but note that its unbalanced connections will be more difficult to shield from line noise (50/100 or 60/120 Hz) which will be somewhat audible using the miniDSP 2x4HD unless special precautions are made.
Chris
Reactions: 1 user
I'll definitely be looking into the software, but I was hoping to use the calculated 17cm for the ports, and the 1:10 ratio for the port size. The advantage would be to be able to model woofers.
I will only be using Xilica for this horn.
As I will be using active crossovers, I do think it wont matter too much what the exact sensitivity is, but I do want to know this to match the woofers to the driver.
I know you initially matched your compression driver with 2x15" Crites woofers, but I was wondering what the woofer matching would end up to be when using a more powerfull driver like the BMS 4594 (a driver you also ended up testing). The TAD 4002 or Radian 951 drivers would only achieve a 125-130db output @RMS, while the BMS would achieve almost 140db.
I would love to be able to use my high-end sound prioritized synergy horn, as a kind of PA speaker like Danley Sounds use theirs. I dont think I would really be compromizing quality by using the BMS coaxials, ánd it would give me a much more potent PA speaker. It would however require more lower end power.
Without hornloading an Eminence Kappa 15A driver pair would have 130db at RMS, so maybe x4 with hornloading could get close to this 140db of the BMS.
When using in my home I would love to have a good lower end from the synergy itself, which is already confirmed by your measurements Chris. Down to 20hz is amazing! When using for PA like situations, I would never cross this low, and I would rather use horn loaded subs to supplement. Crossing at 100hz or higher could maybe help push the synergy its woofer output without distorting.
...I was wondering what the woofer matching would end up to be when using a more powerful driver like the BMS 4594 (a driver you also ended up testing). The TAD 4002 or Radian 951 drivers would only achieve a 125-130db output @RMS, while the BMS would achieve almost 140db.
Wow! This isn't home hi-fi...for sure. I'm not really your guy if you're talking about very high SPL. Even the SH-50 doesn't go that loud (140 dB)...
I'm actually using the BMS 4592ND, not the 4594.
Note that the measurements above were done in quarter space loading--as you would likely see in a home hi-fi environment. If you're talking about full space operation, like is common in PA environments, subtract about ~12 dB below ~100 Hz.
Chris
Reactions: 1 user
Oh yes, my mistake. I'm gonna be using a 4594 though. Same driver. Also to be very clear, I'm still 99% focussed on home hi-fi use. It's just that I see the potential to also use it for PA use, without really compromising hifi quality. Ofcourse I could spend the money better, more focused on hifi use. On the other hand, more lower end potential can only mean an improvement for hifi use too.
Chris
The 140db is a more theoretical value ofcourse (no wall involvement, @1meter). However, I think it's even higher. 118db 1W for the mid-driver (150W AES) and HF-driver (80W). So 139,8 and 137db which comes down to 144,5db total if I'm correct.
In any case, way more than the TAD, Radian or JBL 2446 drivers. So it would make more sense to use more/more powerfull woofers right?
Hi Droco,
I'm a little confused as to whether you are working on a synergy with the 4594 and woofers in the same horn, or working on two separate horns. It sounds like a synergy, given you mentioned a 17cm port distance for crossing at 500Hz...but just want to make sure I understand you.
I've also been considering the 4594(HE) for a synergy using the same 500Hz crossover point. I thought i was good-to-go with 17cm of room to the apex, ....until I measured the acoustic path length of the driver.
It's a huge 11cm from the driver mounting face to the acoustic source!! Which seems to make it pretty much impossible to use larger drivers, without crossing substantially lower.
I'm new to synergy calculations though..hope I'm making a mistake. And maybe the non-HE 4594 has less acoustic depth??
...So it would make more sense to use more/more powerful woofers right?
If you look at the Danley SH-96, it's got four 15" woofers and claims a low frequency cut-off of 50 Hz (apparently in full space) and is rated to 139 dB program power output into 90 x 60 degree coverage, which would mean that its low frequency cutoff could be significantly extended by at least one octave (25 Hz at its -3 dB point) if in quarter space, and even lower in eighth space (corner) loading.
If you're really serious about very high SPL operation, I'd recommend following suit in the woofer section. They also claim 101 dB sensitivity using passive crossovers, so you should be quite efficient using DSP crossover in quarter or eighth space loading.
EDIT: Sorry, I forgot about the reflex ports in the SH-96, which limit its LF output to above 40 Hz (recommended HP frequency). However, in sealed box configuration, the LF performance that I mentioned above would still hold.
Chris
Hi Droco,
Yes, a synergy horn.
Didnt actually think about that! I just figured it would work out fine, as Chris used the BMS succesfully on his synergy.
Chris
I didnt think about using ports, as I thought it to be too complex for me to estimate/calculate the effects. Also, doesnt bringing porting vents outside the 1/4th wave induce incoherence etc?
Very interesting design though! Good inspiration for off axis port placement etc.
I wouldnt try to boost the synergy down to as low as they do I think. It's nice if its capable to do so (for hifi use), but for PA use I'd rather couple the synergy with something like an Othorn and a 100hz crossover. The othorn can do 100hz perfectly, and it would give a 85cm 1/4th wavelength distance, which is close enough to place them together. If I really want to go over budget and floorspace, I can maybe do double othorn with a mega synergy on top for the "ultimate" PA setup.
I'm currently using 0.5 ms delay on the woofer channel with the BMS 4592ND and Danley-style crossover filters (i.e., "fractional order")--no phase shifts through the crossovers. My woofer ports are about 4.5" in front of the horn throat. Crossover frequencies come out to 600 Hz and 5720 Hz.
Chris
See A K-402-Based Full-Range Multiple-Entry Horn - Technical/Modifications - The Klipsch Audio Community
The crossover filters I'm using changed about a month ago. I switched to the BMS 4592ND about a year ago.
Chris
Thx Chris, Great build, super thread. :D
I'm more puzzled than ever now, though, about the 1/4 WL woofer port to horn apex distance.
.....particularly with regard to the acoustic path length of the bms coax drivers.
As mentioned to Droco, I measure a 11cm fight time from the 4594's face to acoustic origin. And estimating the 4592's path length is likely a bit longer.
Because the 4594 driver is 7.9cm (3.1") deep,
and the 4592 is 11.3cm (4.5") deep.
Both use the exact same mid and high diaphragms.....
So I'm left thinking the 4592's acoustic path has to be at least 4.5" from the mounting flange.
I saw your woofer ports are 4.5" in front of the horn throat. Is that 4.5" in front of the 4592's mounting flange? Seems like it has to be.
If so, is your full port-to-horn apex length is at least 9" (22cm) ?
Which according to the 1/4 WL rule would need a crossover down a little below 400Hz?
I must be missing something, since it's working well for you at 600Hz.
Like I said earlier, I haven't been at this synergy math for very long..:eek:
A half millisecond delay equates to 6.8 inches (17.25 cm) of misalignment. Subtracting 4.5 inches distance to the beginning of the off-axis ports in the horn leaves 2.3 inches (5.8 cm) from the 4592's mounting flange to its acoustic center at 600 Hz (room temperature)--instead of the 4.5 inches path length to some feature inside the driver. I surmise that mechanical path length to an internal feature of the driver isn't an accurate predictor of acoustic center.
Chris
Hi Chris, the 11cm measurement is a timed acoustic measurement from the 4594's mid section to the mounting flange, not simply a mechanical path length estimate. It seems to me it is a very real addition to the 1/4WL path length ???? You might want to measure your 4592....my bet is the path length will surprise you...it sure did me ! Had to triple check..
(The HF section has about 0.06ms less acoustical path depth.)
AES E-Library >> Effects of Acoustic Center Position in Subwoofers
While this paper is pertaining to subwoofers, the same concept applies. The actual acoustic center position is not an arbitrary location ( like the voice coil ) or diaphragm. Only acoustic measurement along with a full duplex sound card will accurately reveal the acoustic center in the far field.
Surprisingly in the paper, all of the methods used ( BEM simulation, spreadsheet prediction, near field scanning of the transducer, and an actual 2 microphone measurement ) placed the acoustic center almost a foot in front of the cabinet.
This can lead to errors in loudspeaker polar measurements if the center of rotation is not the actual acoustic center.
Another good read:
AES E-Library >> On the Movement of a Horn's Acoustic Center
Reactions: 1 user
At 600 Hz?
Consider the group delay measurement (total, min phase, excess phase). There is a 450 µs excess GD growth from 600 Hz to 20 kHz:
Chris
MIND BLOWN
Up until two years ago, I measured at a distance of one meter. I doubled that to two, because Bill Waslo mentioned that was better. (IIRC, he didn't explain WHY.)
soon, I noticed that the beamwidth of my measurements was wider, even with the same waveguide.
Your link explains that then.
