Nichicon KA 3300uf and nichicon PW 220 uf and silver mica capacitors. Really good sound , very nice,
thanks Shaan
Ps: I did listen this YouTube 20 times already
Great! Don't forget to post pics of your complete amp too.
Shaan now i have problem with second pcb.Left led is off and the other lights up on very bright.I have checked all the transistors and seems ok.I'm using the same PS DC41v but left mosfet has 60+v and the other 21v.Any ideas please?
I changed the led and lights up but the other is very very bright and the voltage on mosfet is 70v.The other mosfet with the new led has 15v.
Check the two 22k resistors. Are these soldered to correct places?
What is the two LED's voltage rating?
Yes both connected.Why the voltage has such different between two rails? 13v-71v?
Do check continuity from the three legs of output MOSFETs. It looks like one leg which shouldn't be shorted to ground is grounded.
Output?do you mean speaker out or what?
The output terminal on the module and ground terminal on psu.
- Group Buys
- PeeCeeBee V4 GB!
