Class A board DOA33. PSU Help!
Nope had to shut it down quick making a crazy buzzing / humming sound.
Might have to call it a day. These late nights can make you do crazy things lol
When I put the meter on the - and + of the bridge rectifier I get 56V
Just the bare transformer I get 62V or 2 x 31v. The transformer is only suppose to be 25V.
The transformer is 25V-0V-25V or 50V CT.
UN-loaded, 31V instead of 25V is 24V regulation which is a little poor.
31V AC, withOUT large filter caps, will be a PULSATING wave with "DC" of ideally 0.9 the AC Volts, 28V, which agrees with your 56V both sides.
With large caps it will be 1.414*VAC or, no-load, 44V each side, far past the 35V rating and potentially damaging.
Can you trade for a 20V-0V-20V transformer?
You need to learn how to construct a DC power supply using a transformer. Best thing to do is read some good articles on it, such as these:
Linear Power Supply Design
Power Supply Wiring Guidelines
Short notes:
* AC voltage != DC voltage. DC voltage is AC voltage * 1.414.
* You need capacitors after your rectifier, or your DC voltage will be full of 100Hz buzz which will be useless for an amplifier.
* Amplifiers generally require a symmetrical supply. You have a 0v "centre tap" and then +V and -V around this tap.
* Make sure you have your transformer primary wired correctly for your country. If you have a transformer with 2x115V windings, you need to connect them in series for a 230V country such as the UK.
* Be careful. Power supplies are not forgiving. Get the connections wrong and you can expect smoke. Verify everything thoroughly before you switch on. Consider making a "dim bulb tester".
You could also buy a variable power supply that uses LM317 and LM377 with your current transformer which will have input caps (small ones) already on the board. Just adjust down to +/-28 VDC on the output and you are ready to go. Should be less than a new transformer.
Just the bare transformer I get 62V or 2 x 31v. The transformer is only suppose to be 25V. But I have read it can go down when load is attached.
Your transformer has dual secondaries with a center tap. The center tap should be grounded, then you have 2 x 25 (or 33) on each side. That should go into a full wave rectifier, feeding some serious capacitance as noted. Google full wave rectifier with center-tapped secondary.
If, like you have done, you rectify the entire secondary you end up with double the intended voltage.
Jan
Jaycee pointed out earlier that my voltage is too high! I need to order 20v to get 28V.
My 25V AC will produce 35V DC which is too high. I have made a sketch for myself based on what he sent in last few posts.
I plan to use 2x 2200uf Capacitors.
Do you have a picture of the downside, backside of the board?
I am looking for a way to adjust the current. By swapping 2 resistors per channel. You could adjust the current, to get optimal power dissipation of these small heat sinks, at voltages 10 - 40 V for example.
Reactions: Sensation45
