I don't understand what you are trying to say. A log plot is hard to interpret for things like distortion. The multitone plot can be useful except many of the HD and IM products fall on other source tones making it all harder to interpret.
I would only get meaning if it starts with a reference plot showing what you would see without the DUT. Digital in and analog out make that more difficult. You also need to know what the noise floor looks like to be sure you aren't attributing artifacts to the DUT that are in the noise floor of the analyzer.
Also without knowledge of the sample rate, FFT resolution, the windowing etc. its really hard to make comparisons. The FFT of a 1 KHz tone on a modern opamp will usually be limited by even the best analyzer. All the chip vendors use a technique increasing the noise gain to get meaningful distortion plots. The plots you showed were definitely not opamp limitations. Virtually all analyzers have their best performance at 1 KHz and 3V in. Compromises in the design of analyzers will degrade above and below that frequency. Its not necessarily a reflection on the opamp if you get different results at other frequencies. I would expect harmonics of -130 dB or less for a closed loop gain of 10 for any premium opamp designed for this application. The high harmonics in the FFT are from some other source (the DAC?).
There is nothing complicated here. As far as you have consistent setup across the board, you can still figure out the differences among different multi-tone tests. This is exactly where ASR shows its value. All tests are done by the same person based on the same config. You can always go to FFTs at different frequencies for details later.
As for the choice of 1KHz test, it's a chicken-egg scenario. In the past, for tape decks, 400Hz was the one to use. Later it was moved to 1KHz for CDs to show a bit more on the LPF's impact. Now for some high speed OPs such as OPA1612, they work the best above 1KHz. People start to get the impression that 1KHz is the sweet spot for OPs.
I agree with you on the AKM sound signature. To me it's simply smooth and silky. My primary listening is done using a RaspPi HAT DAC based on an older AKM4490EQ chip. I love the sound of it - at least in my system. My only 'upgrade' is I'm using an external linear PSU.
I also bought the Topping DX3 Pro for the latest dual-mono chip design, so I'm watching/following this thread with interest. While I like the ESS chips, I keep coming back around to the AKM44xx series DACs.
The Khadas Tone Board has some promise as well, and I'm waiting for their host SBC board for testing and possibly building an all-in-one, network based streamer using roon.
I have found there's a big jump on SQ from AK4490 to AK4493. Do have a big concern on the coming AK4499 though. The new I/V stage may change everything.
For the past few months I have checked most AK4497 and AK4493 DAC designs available on the market. So far DX3 Pro is one of the very few which are both simple yet can demonstrate how good AK4493/4497 really is after mod.
Dont look down on AK4493 as the new Estoric top machine has four 4493s inside.
Just got a decent linear power supply for DX3 Pro. the new PSU has removed the very last bit of roughness from its sound. Now it's such a sweet, mellow yet dynamic little monster!
I try to consolidate your mod within this spreadsheet, it seems the lpf part is not consistent between two of your post, also I cannot find some parts to change in bom, could you please help us to correct it? Thanks.
Very sorry for the late reply as I have been super busy with work.
The photo shots were taken at different mod stages. The close-up one is the one to follow.
The BOM looks good to me. Please let me know if you have any questions with it.
Hi finneybear ,
I do not find the 100uF capacitor on your BOM ?
Thanks,
Paul
The 100uf is way too small. It kills the bass of 4493.
Based on the datasheet, the cap should be at least 470uf.
I am using 470uf solid polymer here.
from Finneybear's Mouser BOM:
Mouser Electronics
Isn't this the cap?
HZA107M025X16T-F Cornell Dubilier - CDE | Mouser
Nope. you need to use 470uf/6.3v solid polymer here. 100uf is too small.
Hi, is there any way to tap out balanced out that could connect I/V for XLR front end?
This mean major surgery here. Another concern is whether you want to use coupling caps or not.
No I/V for 4493. It's a voltage output chip.
Is it possible to remove all those 8 caps completely? If use the original OPA1612..
Not sure which 8 caps you were referring to?
If you want to remove 4493's coupling caps, you will have to modify the LPF as the way I did. 4493's positive and negative outputs have different DC bias hence the asymmetric cap/resister values at LPF.
One dumb question does have DX3 PRO DC protection circuit for Headphone output? Thanks.
Nope. The headphone amp is an OP driving a buffer.
Thanks finneybear,
I get the BOM, the hex 2mm key, a solder station for smd.
I will practice first on an old graphic card !
Do you think a dual lt3045 (1 A) has enough power for the dx3pro ?
Where do you come up with this stuff? The datasheet for the part shows you are wrong. Distortion is markedly worse at 10 kHz than 1 kHz, as you would expect from the open loop gain plot. Please, explain with facts not anecdotes.
You’re right that there is nothing complicated here. I’m happy to change my stance when provided explanations that make sense.
Are you aware that Samuel Groner did very detailed measurements of OPA1611 (rebranded OPA211). His measurements, which go beyond the datasheet, disprove every single statement you have made about it in this thread.
AK4493 is on a new process it shares with AK4497 (and presumably 4499) according to what I saw on the website somewhere. The AK4499 is going to have the same stupidly high output current like ES9038. Other than the digital section, this DAC is going to be more like the Sabre than the 4493 it seems.
An old graphics card could work but you might find it easier to purchase an SMD practice kit off ebay. They are very cheap and include various sizes of smd and the PCB to solder and desolder on.
You may not need it, but if money is no issue it might be nice to have a cheap hot air SMD rework station. They are cheap and I have found many uses for mine. 858D works well.
Hi All, Thank you for sharing all you knowledge here.
@finneybear, is your mod - especially LPF part safe also if I leave original OPA1612 in place? Also I noticed that you are using only two lines instead of four as in original setup between each AKM4493 and OP what is the reason?
Thanks.
David
Thanks.
David
CS43198 is the first high end all in one design DAC chip. It is built mainly for portable audio devices/cell phones, etc. It has everything inside, even headphone detection. It has PLL based jitter removal, configurable digital filter, and only needs 1.8V power supply, etc.
The charge pump allows it to output 5V signal, and since its output is H-calss based, the LPF is given hence no need for external LPF. A CS43198 with output buffer, that's all what you need.
Is the H class output bad? Not really. Remember that DSD itself is PWM as well. If DSD could sound good, H class can sound good, too, as far as the switching frequency is high enough. The beauty of this architecture is that, the H class output will remove the need of external LPF hence there will be no active I/V, no active LPF involved. No active LPF means no NFB, the whole signal chain now has no NFB. The only NFB happens in the digital filter inside CS43198, in the digital domain. In the analog domain, it's a simple straight path, no NFB. Definitely this will give a very unique sound to CS43198, and I am not surprised it can sound good now. What a brilliant design idea!
At least you are an optimist, if only life were so simple 🙂
I think you might want to re study what is actually inside the 43198, read, a whole bunch of Cmos opamps, and reconsider a lot of that reply.
HaHa - that's a pretty funny post by any measure - at least you are an optimist, (sadly needed around here), if only life were so simple 🙂
I do think the CS43198 is a nice part, but you're right. There is approximately zero chance it doesn't have NFB in the internal output. Drives 600 ohms with -115 dB THD but doesn't use NFB... riiight.
I'm not sure he knows what Class H is, either. It's also completely optional and can run in normal Class A/B with a register setting.
You have to be fast around here, I edited that (Haha bit) out 10 sec after posted- so you don't need to reiterate it.
Yes, agreed on all counts. Maybe the real story here is how good they have made such an integrated device with obviously some constraints, perform.
In mono, fully balanced mode, this part would be pretty darn good.
T
T
Someone ought to find out😉
T
Sorry, didn't realize it was edited after. I can't edit mine now 🙁.
Guerilla said:Someone ought to find out😉
I might if I can get some free time over the next few months - looking unlikely though.
I know the feeling😉
- Digital Line Level
- [Modding] Topping DX3 Pro
