Melbourne Daughterboard for M2X
You don’t need the lugs. Just insert directly into the holes/pads. The default gain is 15.6dB and is set by the (R118+R119)/R118 value of (5k6+33k)/5k6. If you want 30.6dB if gain use 1k for R118 etc. leave R119 at 33k.
Add some resistor lead clippings to the two test points to measure bias current though.
I think JP added feb lugs to allow easy de-soldering and exchanging of the gain resistor.
Hi batty, RS - Online here in OZ has the Fischer SK95-25-SA-220 heat sink in stock (their part number is 189-8319) and they are $3.77 AUD each incl. GST with 23 in stock for next day delivery. That is where I got mine from and are the same ones as shown in the original PCB build photo's.
