I was looking for the same thing as thinking about using this for the 52w SE Class A Big Boy Alpha amp.
Very nice F6 PSU boards - thanks JP!
JP, do you still have ACA boards? I'd like boards with the transistors on one side, instead of the current ones from the store. Tks!
Hello JP
Its been a long time since the previous post. Is the GB still active? If it is still active, I'm interested in 2 pairs of DIY-NR003 & 2 pairs of DIY-NR004 - shipment to address in Germany.
Thank You- MM
Thank You- MM
The BOM doesn’t have rectifier or heat sink part numbers.
Any recommendations??
+1. JPS, can you disclose the heatsink PN used for the design?
BK
Hello BK,
for the power supply I´ve used Fischer Elektronik SK492-100mm.
But you could use drilled 12mm thick alu rail?!
JP
JP
Hello BK,
JP
Thanks, JP! I have not been able to source this in the USA, or without a large minimum order quantity via europe. Seems like an aluminum piece is the way to go. If anyone has a USA source for SK492 please let me know - still the most elegant solution.
BK
Hi JPS64,
Do you have schematics for your MoFo board? Getting ready to populate it 9will pair with SLB SR PSU and Melbourne SMT preamp board) - probably simple enough to guess but... better if there is already a schematic. I think others may be interested in your MoFo board as well...
Thanks,
X
Thanks,
X
Hi JPS
Hope you’re are well.
I’ve been distracted on other things for quite some time.
Do you have any of these boards left?
- Group Buys
- My first GB
