I see it as completely possible to mount A11ms (or P11) into a hole/rebate used by A10x. 5 screw holes vrs 6 so that should not be a real issue, and one needs a fat gasket. I did much the same mounting CHS70 into CHR rebate. Thick neoprene gasket material from Home Depot was all i needed.
dave
dave
Joined 2009
I have no concerns about using a fat gasket but I'm not convinced they're compatible. I noticed it's hard to find a datasheet with clear mechanical drawings - several of them have such poor resolution you can hardly read the dimensions off them. If anybody can post some half way decent data sheets showing the mechanical dimensions including screw holes, I'd love to have them.
Joined 2009
Up for sale, my prototype 7ms Pensils. These are a bit rough around the edges as were only made for testing, but its nice quality ply.
Happy to take 10% off the kit of parts and include the cabinet if anyone wants it.
From Stefan at KJF this includes, Alpair 7ms in gold, Jantzen gold binding posts, Van Den Hul Clearwater cable & crimped ends, with bracing, damping and stuffing. Also our special isolation base using well-nuts.
£190 for the lot plus shipping or free to collect from Bristol.
Joined 2009
Joined 2009
A11MS
Ordered a pair of A11MS earlier this week from Madisound. Looking forward to hearing them! They arrive the 27th.
To start I will stick them in the same boxes I have the Pluvia Elevens in now - roughly 9 liter ported. Then I'll check Dave's website for the optimal bookshelf-sized design (thanks in advance, Dave).
Spacer changes to 85mm. Probably close enuff as is to not be an issue.
Holey brace will be somewhat shy of bracing the magnet.
dave
dave
Shouldn’t be too difficult to determine dimension of small filler block for brace to gently kiss the rear of magnet on the shallower 11MS.
A 7 MS IN PENSIL WITH 7.3 'S
Would it be a fair comparison to swap out the drivers? My Pensils have a removable back so it could be an easy change.
Hey Dave, I would like to buy a pair of your enabled drivers if they aren't all sold already. Let me know.
- Full Range
- New Markaudio Drivers
