Ian asynchronous I2S and S/PDIF FIFO KIT group buy
1. Iancanada -- EssController …
2. Crom 1 x FifoPi, 3xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT (and if you have any left: The RPi I2S adapter that enables the ESS controller to be used as an external controller)
3. Oyvind 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
4. Pistollero 1 x FifoPi, 2xLifePO4 power
5. MikeyFresh 2x FifoPi, 1x LiFePO4 power, 2x ESS Controller, 1x dual mono ES9038 DAC, 1x ES9028 DAC, 1x Transformer I/V PCB mini kit, 1x Std I/V stage
6. Randytsuch 1 x FifoPi, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1x transformer pwb, 1 x xo adapter, 1x opa adapter, 1x standoff kit, 2 x I/V STD standard I/V stage pwb, 4 x lt3042 pwb
7. necplusultra 1 x FifoPi, 1xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
8. szczemirek 1 x FifoPi, LifeO4 pure power supply, Transformer I/V PCB mini KIT, I/V STD standard I/V stage, CCHD957 XO adapter kit
9. casshan 1 x FifoPi, 1 x LifiPO4 power, 1 x Ess Controller
10. zapio : 2 x FifoPi , 4 x LifiPO4 power, 1 x Ess Controller, 1 x transformer I/V PCB mini KIT 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
11. trung224 : 1xLiFePO4 power
12. Sq225917 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
13. passive420: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
14. comickitkit: 19 xFiFopi, 5xLifepo Power Supply, 11xESS Controller, 7xDual Mono ES9038 Dac, 3xES9028 Dac, 5xI/V STD OPA Stage, 1x Trans I/V PCB mini KIT, 5xESS Controller KIT, 15xPackage of CCHD957 PCB KIT, 11x2’’ double-ended U.FL cable, 1x2.5mm metal standoffs, 8xLT3042 PCB, 15xI/V stage empty PCB, 1xMcfifo, 1xMcdualXO
15. crymen: 1 x Fifopi, 1 x LifePO4 power
16. ppap64: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
17. Greg Stewart: 3 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 DAC hat, 1 x 9028 DAC hat, 1 x ESS controller extension kit, 3 pks CCHD957 XO Adapters, 8 x 2" u.fl silver-plated extension cables, 5 x RPi metal standoff sets, 5 x LT3042 regulator boards
18. jacklee: 1 x FifoPi, 2xLifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x transformer I/V PCB mini KIT
19. kenlaumm: 1 x Fifopi, 1 x LifePO4 power
20.curryking: 1 x FIFOPi,1 x ES9038 dual mono DAC Hat, 2 x ESS Controller
21. Cerole: 1 x FifoPi, 3 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1*I2S FIFO 2 Kit, 1*Dual XO clock board, 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB, 1*ESS controller extension kit, 1*CCHD957 XO adapter kit, 4*6" double-ended silver plated U.FL coaxial cable, 1*Package of OPA1622 adapter PCB kit, 10*2.5mm metal standoffs for RPI, 8*2" u.fl silver-plated extension cables
22. Big bird: 1 x Fifopi, 1 x LifePO4 power, 1 x ES9038 dual mono DAC Hat,1 x I/V STD standard I/V stage, 1xLL1544A Transformer I/V KIT, $19.00, 1 x ESS Controller, CCHD957 XO adapter kit, ESS controller extension kit, 2” double-ended silver plated U.FL coaxial cable, 4x 6"double-ended silver plated U.FL coaxial cable
23. wealas: 2 x LiFePO4 power
24. ernesternest: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
25. nounouchet: 3 x LiFePO4 power
26. mjensen: 1 x FifoPi, 2 x LifePO4 power, 2 x ESS Controller, 1 x Dual Mono 9038 Dac Hat, 1 x I/V STD standard I/V stage, 1 x Transformer I/V PCB
27. janho12345: 1x FifoPi
28:Forane12: 2X FifoPi , 3X LifiPO4 pure power supply, 2X ESS controller, 2X Dual Mono ES9038Q2M , 2X ES9028Q2M DAC HAT, 2X I/V STD standard I/V stage, 2X Transformer I/V PCB, 2X ESS controller extension kit, 2XCCHD957 XO adapter kit lot of 2,1X OPA1622 adapter PCB kit lot of 5, 3X 2” double-ended silver plated U.FL coaxial cable, 3X LT3042 low noise regulator PCB, 2XI/V STD standard I/V stage empty PCB
29. Joseacm08: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
30. ccliu: 1X FifoPi , 2X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
31. e-yakovkev: 1 x FifoPi, 3 x LifePO4 power
32. minivan: 1xfifopi ,1x Lifepo4 pure power
33. StarLex: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
34. Akasaka: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
35. Yatsushiro: 1X ESS controller
36. luchoh:1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage,
37. nielsek:1xFifoPi, 1x LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage
38. emynet 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
39. cspirou: 1*I2S FIFO 2 Kit, 1*Dual XO clock board(no XO), 1*SPDIF interface, 1*I2S to PCM, 1*FIFO II isolator PCB, 1*RPi I2S PCB adapter, 6*LT3042/LT3045 PCB, 1*I/V STD stage, 1*transformer I/V PCB kit, 1*LifiPO4, 1*McDualXO, 6* U.FL coax (any length), 1*SMT XO adapter package, 1*I2S backdoor kit
40. Brumjam: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT
41. misterdog:1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
42. palmito: 1*FifoPi, 1*LifiPO4 power, 1*ESS controller, 1*Dual Mono ES9038Q2M, 1*I/V stage, 1*Transformer I/V PCB mini KIT
43. flowerpot: Withdrawn (After some consideration decide to withdraw from this GB)
44. _oxygen: 2x FifoPi, 2x ESS controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x ES9028Q2M DAC HAT, 2x I/V STD standard I/V stage, 1x Transformer I/V PCB mini KIT, 2x ESS controller extension kit, 2x CCHD957 XO Adapter kit, 2x OPA1622 Adapter kit, 2x 2" U.FL coaxial cable, 6x 2,5mm standoffs, 1x Buffalo I/V board adapter kit
45. SonofThor: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
46. Morde: 1x FifoPi, 2x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1x STD standard I/V stage, 1x Transformer I/V PCB mini kit
47. 1001meier: 1xFifoPi, 1xESS controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x CCHD957 XO adapter kit lot of 2, 1x ESS controller extension kit
48. deenoo: 1*FifoPi, 1*I/V STD standard I/V stage, 1*Package of dedicated CCHD957 XO adapter kit, 2*LT3042 low noise regulator PCB (free); 1*LifePo4 pure power supply
49. Rrbs : 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT
50. linh0983 : 1xLiFePO4 power , 1xDual Mono ES9038Q2M , 1x FifoPi
51. JoeyDD: 1*LifePO4 power, 1*ESS controller
52. pierantonio: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
53. xaled: 2x FifoPi, 2x LifePo4 power, 2x ESS controller, 2x Dual Mono ES9038Q2M, 2*Transformer I/V PCB mini KIT
54. Duanbui: 1xLiFePO4 power
55. maartn: 1x FifoPi, 1 x ESSController, 1 x ESS controller extension kit, 4 x double-ended silver plated U.FL 178 coaxial cable, 2 x LT3042 low noise regulator PCB (free)
56. syracuze: 1 X FifoPi , 3 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
57. Flyingsparks: 2X FifoPi , 2X LifiPO4 power , 2X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
58. number9, 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
59. duc985: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
60. Lucser: 1xIsolatorPi II, 2 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1xI/V trasformer board, 2x CCHD957 XO adapter kit, 4*LT3042 PCB, U.FL Ccables; and, if completed, 2 x I2S to LVDS HDMI Tx modules as per #2602 post.
61. Stokessd: 1x FIFO, 1x ESS Controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x Transformer I/V PCB mini KIT
62. tomcoppa 1*FifoPi, 1*LifiPO4 power, 1*EssController, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini KIT
63. Blitz: 2xLifePO4 Power, 1*transformer I/V, 1*I/V Standard
64. Chipno :1 x FifoPi , 1 x LifiPO4 power
65. simon dart: 1x FifoPi, 1x LifePo4 power, 1x ESS controller, 1x Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage,1X Transformer I/V PCB
66. kolossos4730: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
67. mksung: 1 x FifoPi, 1 x LL1544A Transformer I/V KIT, 2 x Package of OPA1622 adapter PCB kit lot of 5, 1 x IsolatorPi II RsapberryPi/ODROID I2S/DSD/DoP isolator
68. stavros61:1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
69. cjunkk: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
70. bartb: 1x McFIFO, 1x McDualXO, 1 x FifoPi
71.JimS::1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 2 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage
72.KenI:1*FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1*ESS controller, 1*Dual Mono ES9038Q2M DAC HAT, 1*I/V STD standard I/V stage
73.kvl: 1*FifoPi, 1* LifePo4 power, 1*ESS controller, 1*Dual Mono ES9038Q2M ,1*I/V STD standard I/V stage, 1*Transformer I/V PCB mini KIT, 1* ESS controller extension kit, 1* Package of OPA1622 adapter PCB kit lot of 5, 4* LT3042 low noise regulator PCB, 1* I/V STD standard I/V stage empty PCB.
74 secanbj 1*FifoPi, 1*ESS controller, 1xDual Mono ES9038Q2M ,1*I/V STD standard I/V stage
75.deanoUK :1 x FifoPi 768KHz 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M
76. cubano: 1X FifoPi , 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage
77. Hellokitty123: 1X LifiPO4 pure power supply / 1X I/V STD standard I/V stage 1X / Transformer I/V PCB mini KIT
78. nori1000: 1 x FifoPi 768KHz I2S/DSD/DoP FIFO for RPi with built in isolator, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1x ESS controller extension kit, 1 x Dual Mono ES9038Q2M DAC HAT, 1x I/V STD standard OPA I/V stage, 1x I/V STD standard I/V stage empty PCB, free, 4x 4” double-ended silver plated U.FL coaxial cable, 1x 2” double-ended silver plated coaxial cable, 1x Package of dedicated CCHD957 XO adapter kit
79. Rowli: 2 x LifiPO4
80. Sidiropa: 1*LifePo4 power
81. stephengrenfell 1*FifoPi, 1*LifiPO4 power
82. Mindfunk: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
83. tanelip: 1*FifoPi, 1*CCHD957 XO adapter kit
84. sbiswas-1: 1 x McFIFO, 1x McDualXO,1x LifiPO4 pure power supply
85. Jjazz: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
86. s666foto: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
87. niner: 2 x LifiPO4
88. maui: 1 * FifoPi, 1 * LifePO4, 1 * I/V STD standard I/V stage, 1 * I/V STD standard I/V stage emty PCB, 4 * 2" U.Fl wire double ended, 1 * CCDH957 XO adapter kit lot of 2, 1 * ESS Controller, 1 * ESS controller extension kit, 1 * dual mono ES9038Q2 dac, 1 * LT3042 low noise regulator PCB
89. ofswitched: 1X FifoPi, 1x Dual Mono 9038 DAC HAT, 1x I/V STD standard I/V stage, 1x Buffalo I/V Adaptor, 2x CCHD957 XO Adapter kit, 1 X ESS controller
90. neslo: 1 X FifoPi , 1 X LifePO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini kit.
91 AlanElsdon: cancelled
92 cv: 2 x FifoPI
93. chi0001: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x Package of dedicated CCHD957 XO adapter kit , 1 x dual mono 9038 dac hat, 1X I/V STD standard I/V stage, 1 x transformer I/V PCB minit kit, 4 x LT3042 low noise regulator PCB
94. cps3113:1 X LifePO4 pure power supply.
95. ilgavro 1x fifopi 2x lifepo4 power 1xesscontroller 1x dual mono 9038 da hat 1 x std standard I/V stage
96. ykharlamov: 1 x LifePO4 power, 1 x McFIFO, 1 x McDualXO
97. M_Balou: 1*FifoPi
98. yaboin: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage, 1*transformer I/V PCB mini kit
99. stenachio: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*I/V STD standard I/V stage
100. ilraffa 1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 da hat 1 x std standard I/V stage
101. ermine22. 2X FifoPi , 1X LifiPO4 power , 2X ESS controller, 2X Dual Mono ES9038Q2M, 2X I/V STD standard I/V stage
102. cesare2K. 1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 da hat 1 x std standard I/V stage
103. artmic: 1*FifoPi, 1*LifePO4 power, 1*ESS Controller, 1*dual mono 9038 dac hat, 1*transformer I/V PCB mini kit
104. lugo689:1x fifopi 1x lifepo4 power 1 x esscontroller 1 x dual mono 9038 dac hat 1 x std standard I/V stage
105. tods:2x fifopi, 1x lifepo4 power, 1 x esscontroller, 1 x dual mono 9038 dac hat, 1 x std standard I/V stage
106. copper31: 1 x FifoPi, 1 x LifePO4 power
107. plsm: 1*FifoPi, 1*ESS Controller, 1*dual mono 9038 dac hat
108. Gabry63: 1x fifopi 2x lifepo4 power 1xesscontroller 1x dual mono 9038 da hat 1 x std standard I/V stage
109. dynpro100: 1 x I2S to PCM converter board, 1 x Finished TPS7A4700 low noise regulator board, 1 x RaspberryPi I2S adapter PCB/connector package
110. sp502: 1 x McFIFO, 1 x McDualXO, 1 x Finished TPS7A4700, 9x U.FL. coax cable (4",7",12"), 10x U.FL. sockets, 1x SMT XO Adapters KIT, 4x 767KE-ND
111. Pinnocchio: 1x FifoPi, 2x LifePO4 power, 1x ESS Controller, 1x Dual Mono 9038 DAC HAT, 1x I/V STD standard I/V stage, 1x Buffalo I/V Adaptor, 1x ESS controller extension kit, 3 pks CCHD957 XO Adapters, 1x 2” double-ended silver plated U.FL, 1x 4” double-ended silver plated U.FL
112. hiroyuki.t: 1X FifoPi , 1X LifiPO4 power , 2X ESS controller, 1X Dual Mono ES9038Q2M , 1X ES9028Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB
113. rudra: 1 x FifoPi, 1xLifePO4 power, 1 x RaspberryPi I2S adapter(transmitter)
114. jp2017: 1 x i2stopcm
115. stones: 2 x FifoPi, 1 x LifePO4 power, 2 x Ess Controller, 1 x ESS controller extension kit, 2 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage, 1 x I/V STD standard I/V stage empty PCB, 1 x transformer I/V PCB mini KIT, 2 x LT3042 low noise regulator PCB, 1 x I2S to PCM, add UFL cables if needed
116. adelias 1 x FifoPi, 1 pkg CCHD957 XO adapter kit, 3 x 2” double-ended silver plated U.FL coaxial cable
117. ngocpham: 1xLifePO4 power
118. marcus1: 1xLifePO4 power
119. vanofmonks 1x FifoPI, 1x Es9028 Hat, 1x I/V, 1x ESS
120. Val33 : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
121. cristianr: 1xLifePO4 power
122. triodehunter: 1x McFiFo, 1x McDualXO
123. TirNaOg: 2 x LifePO4 power
124. Dave S: Nothing
125 spm FifoPi, LifiPO4, ESS controller, Dual Mono ES9038 HAT, I/V STD and Transformer
126. quick16 2 x FifoPi
127. mige0: none
128. fm804: 1 x FifoPi, 1 x LifiPO4 pure power supply, 1 x ESS controller, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard OPA I/V stage, 1 x Transformer I/V PCB mini KIT, 1 x ESS controller extension kit, 3 x CCHD957 XO adapter kit, 1 x OPA1622 adapter PCB kit, 5 x 2" double-ended silver plated U.FL coaxial cable, 1 x Buffalo I/V Board I/V adapter KIT, 1 x I2S to PCM converter board V2.0, 5 x 4" double-ended silver plated U.FL coaxial cable, 5 x 6" double-ended silver plated U.FL coaxial cable
129.AcDcMan1: 1 x FifoPi, 1 x LifePO4 power, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1 x I/V STD standard I/V stage
130. APK : 1 x FifoPi , 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x Dual Mono ES9038Q2M DAC HAT
131. miklau: 1*FifoPi, 1*CCHD957 XO adapter kit, 2*LT3042 low noise regulator PCB, 1* I/V STD standard I/V stage empty PCB.
132. Aronier : 2*FifoPi, 2*LifiPO4 power
133.JimmyThinker: 2* FifoPi , 1* ESS controller, 1* ES9028Q2M DAC HAT, 1* I/V STD standard I/V stage, 1* ESS controller extension kit, 2* Package of dedicated CCHD957 XO adapter kit lot of 2, 1* I/V STD standard I/V stage empty PCB, 1* RaspberryPi I2S adapter PCB/connector package, 3* U.FL coax (4”)
134. BachAudioDK: 1 x I2S to PCM, 2 x OPA861 I/V converter
135. Jorgen E : 1 x LifiPO4 pure power supply
136. Patjr : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
137. markhw4: 1 x McFifo, 1x McDualXO, SMD XO adapter kit, 4* ADM715X ultra-low noise LDO PCB (free)
138 ollux: 1*FifoPi, 1*LifiPO4 power
139 TioFrancotirador 1*FifoPi
140 Tml: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
141 iggy111: 1x McFiFo, 1x McDualXO, 6x 4” double-ended silver plated U.FL coaxial cable, 10x SMT U.FL socket
142 kirks: 1 x FifoPi , 1 x LifiPO4 power, 1 x ESS Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
143 prohvesor: 1 x LifiPO4 power
144. derekv: 1 x FifoPi, 1x Dual Mono ES9038Q2M DAC HAT, 1 x Transformer I/V PCB mini KIT
145. aguaazul: 1x FifoPi, 1X LifiPO4 pure power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT, 1X ESS controller extension kit, 2X CCHD957 XO adapter kit lot of 2, 1X OPA1622 adapter PCB kit, 4X 2” double-ended silver plated U.FL coaxial cable, 2X LT3042 low noise regulator PCB, 2X I/V STD standard I/V stage empty PCB, 3X RaspberryPi I2S adapter PCB/connector package,
146. Supersurfer: 3*FifoPi, 2*LifiPO4 power, 1*EssController, 1* Dual Mono ES9038Q2M DAC HAT, 6* 4" double-ended silver plated U.FL coaxial cable, 4* 7" double-ended silver plated U.FL 178 coaxial cable, 12* SMT U.FL socket, 2* RaspberryPi I2S adapter PCB/connector package, 4* ADM715X ultra-low noise LDO PCB (free), 1* I/V STD standard I/V stage, 1* CCHD957 XO adapter kit lot of 2, 1* ESS controller extension kit, 1* Package of OPA1622 adapter PCB kit lot of 5, 1* 2” double-ended silver plated U.FL coaxial cable, 3* 2.5mm metal standoffs for RPI lot of 4 sets, 2* LT3042 low noise regulator PCB, 2* I/V STD standard I/V stage empty PCB
147. CAAD: 1* FifoPi, 4* ADM715X ultra-low noise LDO PCB (free)
148. atom6422 : 1 x FifoPi, 2 x LifiPO4 power, 1 x EssController, 1 x ES9028Q2M DAC HAT, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage, 2 x transformer I/V PCB mini KIT, 1 x OPA861 I/V converter, 1 x I2S FIFO II (I2S) KIT, 2 x Dual XO II Clock Board without XO and socket, 1 x FIFO II isolator board mini KIT (finished), 1 x FIFO II isolator board mini KIT (unfinished), 1 x S/PDIF Interface Board for FIFO II, 1 x I2S backdoor KIT for S/PDIF board, 5 x Battery Management board PCB, 2 x Package of Universal SMT XO Adapters KIT lot of 5, 3 x Anti-vibration screw grommet set(767KE-ND), 4 x ADM715X ultra-low noise LDO PCB (free)
149. johnyn: 1xFifoPi, 8 x 4" double-ended silver plated U.FL coaxial cable
150. acg 8 x LifePO4 power
151. RonR: 1*FifoPi, 1*I2S to PCM, 1*ESS controller, 1*CCHD957 XO adapter kit, 4*U.FL coax (4”), 4*U.FL coax(6”)
152. Raj1: 2 x LifePO4 power
153. alazira1: 3 x LifePO4 power, 1 x FifoPi, 1x ESS controller, 1x dual mono ES9038, 1x IV STD, 1x ESS extension, 1x CCHD957 adaptor, 1x 1622 OPA adaptor, 1x LT3042 pcb
154. malcox11 1*FifoPi, 1*LifiPO4 power
155. Emi90: 1xLifePO4 power
156. 1x FifoPi, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT
157. diyiggy : 1*FifoPi
158. AndyN: 1x FifoPi, 1x ESS Controller, 1x Dual Mono ES9038Q2M DAC HAT, I/V stage board, 1x (or 2 for dual mono?)Transformer I/V PCB mini KIT
159. Dadbeh : 1 x FifoPi, 2 x 1 x EssController, 1 x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 3 x Anti-vibration screw grommet set(767KE-ND), 4 x ADM715X ultra-low noise LDO PCB (free) 1 x Package of dedicated CCHD957 XO adapter kit lot of 2, 1XPackage of OPA1622 adapter PCB kit lot of 5, 1X 2” double-ended silver plated U.FL coaxial cable, 1X 2.5mm metal standoffs for RPI lot of 4 sets 1x LT3042 low noise regulator PCB, 1x I/V STD standard I/V stage empty PCB
160. homing1974 1 x FifoPi
161. malarkey : 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
162. Daniel Lin: 1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
163 fergas: 1 x FifoPi, 1x Dual Mono ES9038Q2M, 2 x LT3042 PCB, 1 x I/V STD standard I/V stage empty PCB, 1x ESS Controller
164 Murdoc: 1x LiFePO4 power
165. Paul Hirst: 1x FifoPi, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage
166. 808EENGR: 1x FifoPi, 1xLifiPO4 power, 2x Package of dedicated CCHD957 XO adapter kit lot of 2, 4x 4" U.FL cables, 2xADM715X pcbs, 2x LT3042 pcb
167. NicMac: 1 x FifoPi , 1 x Ess Controller
168. Prakit: 1 x FifoPi, 1 x ESS Controller
169. jsyu: 1X FifoPi, 1X LifiPO4 power supply, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT, 1X ESS controller extension kit, 1X CCHD957 XO adapter kit lot of 2, 1X OPA1622 adapter PCB kit lot of 5, 2X LT3042 low noise regulator PCB, 2X I/V STD standard I/V stage empty PCB
170. Heathkit: 1 x LiFePO4 power, 1 x FifoPi, 2 x ADM715X ultra-low noise LDO PCB (free)
171. chih: 1X FifoPi, 1X ESS controller, 1X Dual Mono ES9038Q2M DAC HAT, 1X I/V STD standard I/V stage, 1X Transformer I/V PCB mini KIT, 1X ESS controller extension kit, 1X CCHD957 XO adapter kit lot of 2, 1X OPA1622 adapter PCB kit lot of 5, 4X LT3042 low noise regulator PCB, 1X I/V STD standard I/V stage empty PCB, 4X ADM715X ultra-low noise LDO PCB
172. adrian311: 1x FifoPi, 1x ESS Controller, 1x ESS Controller extension kit, 1x Dual Mono ES9038Q2M DAC HAT, 1 x I/V STD standard I/V stage,
173. andrea_mori 4 x FIFO II isolator board
174. wcwc: 1 x FiFoPi
175. redjr 1 x FifoPi, 1x ESS controller, 1x Dual Mono ES9038Q2M DAC HAT, 1x I/V STD standard I/V stage, 1x ESS controller extension kit, 4x LT3042 low noise regulator PCB, 10P 1.0mm FFC/FPC cables combo (3 cables)
176. sampsonite:1 x FifoPi; 1 x LifeO4; 1 x ESS controller; 1 x ESS controller extension kit; 1 x Dual Mono ES9038Q2M 1 x I/V STD standard OPA I/V stage; 1 x CCHD957 XO; Package of OPA1622 adapter PCB kit
177. AudioDac:1 x FifoPi; 1 x ESS controller; 1 x ESS controller extension kit; 1 x Dual Mono ES9038Q2M 1 x I/V STD standard OPA I/V stage; 1 x CCHD957 XO;
178. Lindamar : 1 x FifoPi ; 1 x LifiPO4 ; 1 x ESS controller ; 1 x I/V STD standard I/V stage ; 1 x Transformer I/V PCB mini KIT
179 : myint 67 1x Fifopi ,1x LifiPO4
180 : ICHIBAN Lenmeld : 1 x ESS controller
181. sfleming : 1*FifoPi; 1*LifePO4; 1*ESS controller; 1*I/V STD standard I/V stage, 1* Dual Mono ES9038Q2M DAC HAT
182. stockwolf3 1* FifoPi, 1*LifiPO4 power supply, 1* ESS controller, 1* Dual Mono ES9038Q2M DAC HAT, 1* I/V STD standard I/V stage, 1* Transformer I/V PCB mini KIT, 1* ESS controller extension kit, 1* CCHD957 XO adapter kit lot of 2, 1* OPA1622 adapter PCB kit lot of 5, 2* LT3042 low noise regulator PCB, 2* I/V STD standard I/V stage empty PCB,9. 2* I2S to PCM converter board V2.0, 8* grommet set(767KE-ND), 2* 4"SMT U.FL socket
183. Jogi: 1* FifoPi, 1*LifePO4 power supply, 1* ESS controller, 1* Dual Mono ES9038Q2M DAC HAT, 1* Transformer I/V PCB mini Kit, 1* ESS controller extension kit, 1X 2” double-ended silver plated U.FL coaxial cable,10P 1.0mm FFC/FPC cables combo (3 cables) $3.95.
184.thefirstdj: 1*FifoPi; 1*ESS controller; 1*I/V STD standard I/V stage, 1* Dual Mono ES9038Q2M DAC HAT, 1* CCHD957 XO adapter kit lot of 2, 1* ESS controller extension kit, 4* 2” double-ended silver plated U.FL coaxial cable
185. Studley:1 x FifoPi , 1 x LifiPO4 power, 1 x Ess Controller, 1 x I/V STD standard I/V stage, 1 x transformer I/V PCB mini KIT, 1 x Dual Mono ES9038Q2M DAC HAT
186. jasontsai38: 1 * FifoPi, 1 * LifiPO4 power, 1 * ESS controller, 1 * Dual Mono ES9038Q2M DAC HAT, 1 * I/V STD standard I/V stage, 1 * Transformer I/V PCB mini KIT, 2 * CCHD957 XO Adapter kit
187. edek44: 1 * FifoPi , 1 * LifiPO4, 1 * ESS controller, 1 * Dual Mono ES9038Q2M, 1 * I/V STD standard I/V stage, 1 pkg CCHD957 XO adapter kit, 3 * 2” double-ended silver plated U.FL coaxial cable, 3 * U.FL coax (4”), 3 * U.FL coax(6”), 4 * Anti-vibration screw grommet set(767KE-ND), 1* OPA1622 adapter PCB kit lot of 5
188. delfimmarues: 1 * FifoPi, 1 * CCHD957daapterKIT, 1 * RpiI2SAdapter, 4 * 2inchU.FLcable
189. Slazi 2 x LifePo4 power, 2 x finished TPS7A4700 regulator, 1 x 10P 1.0mm FFC/FPC cables combo (3 cables), 1x ADM715X ultra-low noise LDO PCB (free)
Added 189
92 cv: 2 x FifoPI
127. mige0: none
190. 1 x FifoPi Ultimate with CCHD957
Added 190
92 cv: 2 x FifoPI
127. mige0: none
190. ffeg2008: 1 x FifoPi Ultimate with CCHD957
Corrected 190
92 cv: 2 x FifoPI
127. mige0: none
191. batkalo: 1x FifoPi Ultimate 768KHz PCM/DSD/DoP FIFO, 1xLifePO4 pure battery power supply, 1xESS controller, 1x9038Q2MPi Dual Mono DAC HAT, 1xI/V STD, 1xTransformer I/V PCB mini KIT, 1xESS controller extension kit
Added 191
5. MikeyFresh 2x FifoPi, 1x LiFePO4 power, 2x ESS Controller, 1x dual mono ES9038 DAC, 1x ES9028 DAC, 1x Transformer I/V PCB mini kit, 1x Std I/V stage, 2x CCHD957 XO Adapter kits
92 cv: 2 x FifoPI
127. mige0: none
Edited Line #5
89. ofswitched: 1X FifoPi, 2x CCHD957 XO Adapter kit
92 cv: 2 x FifoPI
127. mige0: none
Edited Line #89
92 cv: 2 x FifoPI
127. mige0: none
192. microzyma: 1 x FifoPi, 1 x Ess Controller, 1 x dual mono 9038 dac hat, 1x transformer pwb, 1 x CCHD957 adapter, 1x opa adapter, 1x standoff kit, 2 x I/V STD standard I/V stage pwb, 4 x lt3042 pwb, 1 x spdif board
92 cv: 2 x FifoPI
127. mige0: none
133.JimmyThinker: 2* FifoPi , 1* ESS controller, 1* ES9028Q2M DAC HAT, 1* I/V STD standard I/V stage, 1* ESS controller extension kit, 2* Package of dedicated CCHD957 XO adapter kit lot of 2, 1* I/V STD standard I/V stage empty PCB, 1* RaspberryPi I2S adapter PCB/connector package, 3* U.FL coax (4&#148😉
151. RonR: 1*FifoPi, 1*I2S to PCM, 1*ESS controller, 1*CCHD957 XO adapter kit, 4*U.FL coax (4&#148😉, 4*U.FL coax(6&#148😉
187. edek44: 1 * FifoPi , 1 * LifiPO4, 1 * ESS controller, 1 * Dual Mono ES9038Q2M, 1 * I/V STD standard I/V stage, 1 pkg CCHD957 XO adapter kit, 3 * 2” double-ended silver plated U.FL coaxial cable, 3 * U.FL coax (4&#148😉, 3 * U.FL coax(6&#148😉, 4 * Anti-vibration screw grommet set(767KE-ND), 1* OPA1622 adapter PCB kit lot of 5
193. mnichols30030: 1 x FifoPi with isolator and dual XO; 1 x ESS Controller; 1 x dual mono ES9038Q2M DAC hat, 1x I/V STD standard OPA I/V output board; 1x Transformer I/V PCB mini kit; 1x ESS controller extension kit; 1 x CCHD957 adapter; 2x LT3402 low noise regulator empty PCB; 2x I/V STD standard empty PCB; 1x Pair Neutrik XLR connectors, NC3MAAH.
92 cv: 2 x FifoPI
127. mige0: none
Ian GB2019: FifoPi, LifePO4Power, ESS DAC , ESS controller and many more
Ian GB2019 has finally been launched today. I’m sorry to have kept you waiting for such a long time. I thank you for your patience and your interest in my projects.
In the past two years, I’ve been working very hard on developing new projects. To get perfect, each project had gone through prototype stages for more than three times. They were also careful tested to ensure best possible sound quality. In production, quality has been and will always be my highest priority rather than the lead time.
List of items of Ian GB2019 (All prices are in USD)
For more details, please find the list of products, user’s manuals and pictures at my gitHub.
GitHub - iancanada/DocumentDownload: Download documents of Ian's products
GB2019 new products:
1A FifoPi Ultimate 768KHz I2S/DSD/DoP FIFO with isolator and dual XO (regular $135) $99.00
2A LifeO4 pure power supply (no battery) $189.99
3A ESS controller $39.00
4A Dual Mono ES9038Q2M DAC HAT $85.00
5A ES9028Q2M DAC HAT $49.00
6A I/V STD standard OPA I/V output board $35.00
7A Transformer I/V PCB mini KIT $19.00
8A ESS controller extension kit $12.00
9A CCHD957 XO adapter KIT lot of 2 $9.50
10A OPA1622 adapter PCB KIT lot of 5 $5.00
11A 2.5" double-ended silver plated U.FL coaxial cable $2.80
12A 2.5mm metal standoffs for RPI lot of 4 sets $2.90
13A LT3042 low noise regulator empty PCB (free, max 4 ) $0.00
14A I/V STD standard empty PCB (free, max 2 ) $0.00
15A Buffalo I/V board Adapter KIT $7.50
16A Pair of Neutrik XLR connector, NC3MAAH $2.75
Old products:
1 McFIFO (I2S/DSD) KIT with cables/connectors $189.00
2 McDualXO clock board with 45/49 XOs and sockets $85.00
3 IsolatorPi RPi/ODROID I2S/DSD/DoP isolator $49.00
4 DoP to DSD decoder daught board $39.00
5 I2S FIFO II (I2S) KIT $139.00
6 Dual XO II Clock Board with 45/49 XOs and sockets $75.00
7 Dual XO II Clock Board without XO and socket $65.00
8 S/PDIF Interface Board for FIFO II $89.00
9 I2S to PCM converter board V2.0 $79.00
10 FIFO II isolator board mini KIT (unfinished) $9.30
11 Finished TPS7A4700 low noise regulator board V2.5 $23.00
12 Battery Management board PCB $3.90
13 4" double-ended silver plated U.FL coaxial cable $3.00
14 6" double-ended silver plated U.FL coaxial cable $4.00
15 7" double-ended silver plated U.FL 178 coaxial cable $5.00
16 12"double-ended U.FL coaxial cable $5.00
17 SMT U.FL socket $1.00
18 10P 1.0mm FFC/FPC cables combo (3 cables) $3.95
19 Package of Universal SMT XO Adapters KIT lot of 5 $9.99
20 RaspberryPi I2S adapter PCB/connector package $6.90
21 Anti-vibration screw grommet set(767KE-ND) $1.08
22 Standoffs/screws set (M3,15mm&8mm) $1.10
23 Additional BIII adapters PCB $3.98
24 SMT connector package for BIII adapters $3.96
25 I2S backdoor KIT for S/PDIF board $3.99
Note: To thank you for your support, LT3042 low noise regulator empty PCB and I/V STD standard empty PCB will be supplied for free. Limited 4 and 2 for each order. I have 400 and 200 of them which should be more than enough. But any way, first come first served.
How to buy
1. Download the empty GB2019 order (Excel format) at bottom of this post or from my gitHub;
2. Fill in the blue sections with quantities, shipping address and other information. Please don’t forget the country to ship to.
3. Rename it (adding your ID is preferred) and send it back to me at iancanada.mail@gmail.com .
I’ll follow up with Paypal invoice to your paypal account in 2 to 5 days.
***Please do not make any payment until you receive my PayPal invoice.
Shipping and Delivery
Items will be shipped by Canada Post. The default shipping will be in bubbled envelope with tracking number and $50 insurance. Please put a note on the order form if you need additional shipping service or you really don’t want the tracking number and insurance (for orders less than $100 only). Please note that packages greater than 500g have to be shipped in a mailing box, thus the shipping will be increased, especially for international shipment. I’ll try the best way of to save your shipping.
GB2019shipping
by Ian, on Flickr
Notes:
1. Weight of package will be calculated automatically at right bottom corner on the order form (in gram).
2. Please note that I’m not responsible for any lost of packages. If you select the shipping without tracking number and insurance, you will take the risk by yourself. Package over $100 cannot be shipped without a tracking number.
3. Please put your correct shipping address on your order form so that I can confirm it’s the best shipping option for you to save your time and money.
4. If your PayPal shipping address is different from the one on your order form, I’ll ship to the PayPal address except if you put a note on your PayPal payment form.
5. For Canada Post, the package will only be registered mail if it has a tracking number. No tracking number means it is not a registered mail.
6. If you know your address had problems such as customs clearance or frequent package losses, please give me a safe address in Canada or USA to ship to.
7. KIT will be shipped within 7 days after I receive the payment.
Payment
I’ll send a PayPal invoice to your email box of your PayPal account after your order is processed. Please follow the invoice for the payment. I accept payment in PayPal only. Please make the payment within 7 days after your receive my invoice. I cannot reserve items for you if you don’t pay in time, unless you let me know in advance.
Please also let me know if you don’t receive my invoice 5 days after sending the order form.
I’m afraid I have to ask for you kindly share the PayPal fee half and half with me which would be 1/2*3.9%=1.95%.
Terms and conditions
One year warranty for all finished PCB assembly. That means repairing service is free within 1 year from date of purchase.
If the damage is caused by your DIY activities, please kindly donate some money to my PayPal account to cover my labor of service. Fixing a board usually takes me 1 hour to trouble shoot, rework the SMT, test and repackage. Buyers pay round-trip shipping and parts in either case. Please list them as PCB for repair with value of less than $30 to avoid any delay and additional cost.
I cannot 100% guarantee a fixed if it is badly damaged, for example, by short circuit or other critical failure.
I will also provide firmware upgrades service for free within 1 year from purchases; Buyers only need to pay shipping for upgrade.
Please also note that I’m not responsible for debugging user’s system, I only guarantee my products are functional. If you have any problem with your system, please post the issue on the thread, other community members and I will try our best to support.
Some useful resource
All most updated documents, pictures and list:
* To download the whole package: click “Clone or download” then “Download ZIP”
Gallery:
https://www.flickr.com/photos/135181977@N06/albums
FifoPi, FIFO and clock board thread:
http://www.diyaudio.com/forums/digi...ifo-project-ultimate-weapon-fight-jitter.html
Develop ultra capacitor power supply and LiFePO4 battery power supply
ESS DACs and controller:
ES9018K2M, ES9028Q2M, 9038Q2M DSD/I2S DAC HATs for Raspberry Pi
IsolatorPi
http://www.diyaudio.com/forums/pc-b...-i2s-dsd-isolator-hat-native-dsd-decoder.html
I2S to PCM board R&D thread:
http://www.diyaudio.com/forums/digi...1541-fifo-universal-i2s-pcm-driver-board.html
GB2017 for old products
https://www.diyaudio.com/forums/gro...us-i2s-pdif-fifo-kit-buy-243.html#post5111232
Have fun with your DIY audio project!
Ian
10 Mar, 2019
GB2019 new items pictures 1-2
Please find the picture name for P/N of each item.
GB2019 new items pictures 2-2
Please find picture name for P/N of each item.
So, for RPi III full featured I need:
1. 1A FifoPi Ultimate 768KHz I2S/DSD/DoP FIFO with isolator and dual XO (regular $135) $99.00
2. 3A ESS controller $39.00
3. 4A Dual Mono ES9038Q2M DAC HAT $85.00
4. 6A I/V STD standard OPA I/V output board $35.00
and optional:
5. 8A ESS controller extension kit $12.00
6. 9A CCHD957 XO adapter KIT lot of 2 $9.50
7. 10A OPA1622 adapter PCB KIT lot of 5 $5.00
8. 2A LifeO4 pure power supply (no battery) $189.99
and optional:
you have to email Ian with the form.
