Working on Ksa 100 Mk 2 Clon. Enclosure 35 Kg. Front 10.5 Kg.
Can't wait to see this one!
Daniel, you did a good job but I'm afraid these heatsinks will not be big enough for 100W class A.
Max 40
Max 40
Hi There,
This is only one channel
(I did the calculations.)
Do youy think it is still not enough? The Math says it will be ok
Hi There,
Sorry then I thought it was stereo
Al good man, I should have posted this
In that case, that will be enough
How is yours going?
How is yours going?
My amps (ksa50) working for years now
Good to hear
Some more progress
Really nice case!
hi.
my amp is now up and running.
i had to change the capacitor from 20pF to 5pF over the feedback resistor.
now everything is working properly.
i reduced the bias to 0,25mA (=4A). makes about 80W class A.
thank you for this great amplifier. sounds great.
regards
s.
Hi Slavko,
I am having a similar issue....
With 7.5k and a 5k pot I have 0.6V to 1.7V.
With 10k and a 5k pot I have 0.9 V to over 2V
With 20k and 5k pot I can drive 5V to the base of the output stage but I still am not seeing any voltage drop on the 1Ohm resistors....
Any tips?
-Dan
- Krell KSA 100mkII Clone
