I would like to thank everyone who contributed to my connecting wire inquiry. I don't at this time have any excessive need for a new hookup wire. I have plenty in my lab, but I like to know what is available. Gothom (sp) looks like a good bet, if I wanted something from Switzerland, but it does not seem better than any good hook-up wire.
Litz wire was experimented with over the decades and mostly discarded, because it tends to sound 'bright' when made into cables. We started out in this direction, 40 years ago.
As far as the Forwood book is concerned, I would have posted most of the pages of interest, as I have done several times on this website over the decade(s) if I could find it on my computer, but Gpapag you are going to see a book that is above and beyond what it normally discussed here, and it should be enlightening.
Does it? Is that a fact? You state it as if it is, is it a well know fact, i.e. there is proof?Also considering that wire drawing deforms the wire directionally,
A top quality wire is properly annealed after cold drawing, not the case with el cheapos we usually have. You can get studies for change in mechanical properties such as ductility, sadly studies on change in electrical properties are not readily available. As I mentioned, who will benefit?... Also considering that wire drawing deforms the wire directionally, I think it is safe to assume that discontinuities and dislocations will have a mechanical directional bias or asymmetry....
The ZenWave would never be considered bright.
Thick wire gets drawn down to thinner wire and it gets longer, caspice ?.Does it? Is that a fact? You state it as if it is, is it a well know fact, i.e. there is proof?
Dan.
Gotcha, directionally as in diameter and length, of course, silly me.Thick wire gets drawn down to thinner wire and it gets longer, caspice ?.
Hi-fi (high fidelity) in sound replaying electronics, the degree of output's faithfulness to input is what determines the performance quality. Higher the better. I never said anything about Per-fi (perfect fidelity).The problem, obvious when we read your posits, is you are chasing something that do not exists.
Nothing, in my knowledge, accurately reproduce sounds. No mike, no sound engineer that highly manipulate near every instrument you will listen to, in a totally artificial and subjective way, no speaker, and even, no electronic gear.
There is the difference between people that believe in a world of utopia, "accurately reproduced sound", and people living in a real world of "Nicely (re)produced music".
Let-me add that, for nothing in the world, I would like to live in your world: When the production of a record is successful, it sound hundred time better than the "real thing" (that had never existed in studios, because, most of the time, even the musicians were not playing in the same time and even, often, the same place). And the subjective way most of these records are produced offers hundred times more pleasure to the listeners.
As I say often, hifi is a make believe game, and designing an illusion show with the methodology of rocket science will not produce a success on Broadway. Although the same laws of physics apply in both cases.
And, as I presume that even Von Braun had to appreciate the Broadway shows, I will never understand the aggressiveness of the pseudo-scientific fundamentalists of this forum.
You are totally free to prefer the gears that measure the best, let the others choose the ones that sound the best.
Bon voyage.
I suspect this is due to skin effect and surface micro-fractures.
Hypothesis, evidence? Remember the "charge" and the electrons are not the same. Skin effect is an EM phenomena the touchy feely electrons flow like water on the rocky shore analogy does not apply.
And does charge or waves flow the same when there is no conductor?
The original version everything was soldered in for testing. As mentioned the tests were on cables being directional, not wires. Although some testing suggested there may be an issue with wires, particularly at frequencies getting to be around a few hundred kilohertz. I suspect this is due to skin effect and surface micro-fractures.
The conclusion in my article was that most folks testing cables would notice a difference as they would be cleaning the connectors as they inserted and removed them.
Now the critics keep assuming things that ain't so. I drive the shield of the cables under test with the same signal as the center conductor from a different resistor divider. The ground link has changed from a copper wire to a copper ribbon to silver.
Today's picture of a cable under test forward and reversed.
And if I show you a picture of the building where I work, it will be evident to all that the wires are done correctly without confounders or loops???
The devil is in the details.. I recall JC also had issues with loops and ground.
You say you drive shield and core with the same signal from a different resistor divider, does that mean you keep the voltage the same, differential, what? And, all that internal electronics, how did you isolate drive and receive?
full schematic, build pictures, performance evaluation.....nothing less can do..
jn
jn
Pretty much what was in the article. The shield and the core see the same signal but isolated as the signal driver is fed into two different resistor dividers to get down to the target signal voltage.
How do you have a skin effect with no conductor? The analogies don't hold water. You still have not answered, are you making this up as you go along or are there some references we can read?
Dan.
So what. Try stretching a wire by pulling only one end. The force has to be in both directions, so how does the cable become "directional?
Jn is almost certainly correct.indra1 said:Also do you have any opinion or comment on what JN said?
Getting a reading on a meter is easy; making a measurement is hard.
Yes, too many confounders for amateurs like me....Getting a reading on a meter is easy; making a measurement is hard.
Pavel, you might like these measurements of mine ;-)
Klaus, thank you so much! Did you try different RCA (white) cables? Shielded twisted pairs?
I found that the biggest difference is created by connectors. Change from well crimped BNC to RCA makes bigger difference than several meters of a coaxial cable. 1-2cm of shield that is soldered in one point to RCA body is worse than 2m of a standard coaxial cable, re added interference voltage. Even a very short cable does not help if it is terminated by RCA's. Same inside the instruments.
I would like to pose a few questions to the cable specialists:
1 - Any known very directional wires/cables one can buy or easily build from scratch?
3 - Would directionality (the direction A vs B difference) typically be an error closely correlated to the signal, that is, not random enough to be reduced considerably by precise time-domain averaging which is used as a method to dig down deep in the uncorrelated noise?
Note that correlated noise signatures (like excess current noise from mediocre resistors) still appear in spite of the heavy averaging (on the order of 10,000 blocks of sample data, typically).
2 - Would directionality appear in cable loopback with an integrated single DAC/ADC device, that is, when freed from many typical other noise/error sources like RF ingress and balancing currents?
I'm asking because I'm in a process of constantly refining my measurement strategies and time-domain averaging techniques enabling a view down at least some 40dB below the analog noise floor in the signal and especially in diff test residuals, having a virtual analog resolution of around 30bits. With a fully arbitrary test signal, actually.
So if (at least come) cable directionality effect is real and fulfils the above criteria (and maybe others?) it should be possible to measure and quantify under very real working conditions with "real" signals (to avoid any potential pitfalls of steady-state type of measurements), should't it?
Point is, it's an almost ideal candidate to exploit the power of differential testing because "standard" linear/nonlinear phenomena should remain unchanged. No trimming or post-processing needed to empirically match gross changes (like from different cables) which greatly increases robustness of the method. Some special care is needed though, for the automatic switching matrix that is required to implement this (still under construction).
I'm on it as much as time allows and hope to do more real measurements (the shown one was more like a demonstrating example with no additional characterization of the current, the shield impedance, lots of unknown from the several adapters used, etc).Klaus, thank you so much! Did you try different RCA (white) cables? Shielded twisted pairs?
Hi all,
In order to keep from wasting a lot of time, we need only to investigate wire directionality, not cable system directionality. A complete patch cable assy (as we find out quickly at RF frequencies) is a system consisting of the connector, shield and center conductor(s), or launcher and waveguide at higher frequencies. You cannot properly quantify any one part while it is assembled into a complete cable assy.
There is no doubt regarding cable system directionality. Having the shield terminated at the driven end only is an essential characteristic of shielded, balanced signal transfer in some uses. Hybrid coax assys of different impedances combined to form matching sections show directional impedance characteristics. Sweeping cables for shield integrity will show up poor shield terminations on one end compared to the other.
This is why I suggested only soldering wires, to get the connectors out of the picture and just test the bulk wire. Yes, much more of a PITA, but to do anything else is to confound the situation.
Test wires, not cable assys.
Howie
Howie
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
