Photo Gallery
A couple of my amp builds...
Maggy-Moto,,, Magnavox 175,, built on a Motorola 3channel chassis, using Moto PT and a pair of Moto Bass channel OPTs, which are full range(finally found a 2nd one!)
6BG6SE w/0C3 screen regulators,,, built on Heath W?? chassis,,, Edcor OPTs...
6AS7PP/6N7/6SN7,,,, built on Hamfest aluminum chassis,,, Pioneer OPTs...
811SET,,, homemade chassis,,, Edcor OPTs
6AQ5/6SL7 cigar box amp,,, Schumaker OPTs
I'm fan of all your amps !!
Finally fixed a 24VDC supply for my, just assembled, headphone amp, adjusted the bias andhooked up a pair of (no so good) headphones.
It playes pretty well.
Tube is Korg Nutube 6P1, of which I ended up with too many, so I got this PCB from Peter Millett and ordered the components according to Milletts BOM, from Mouser. (I could write a long story about this order, that was placed last Summer and where the last pieces ended up just a few weeks ago).
Joined 2013
Just finished my Audio Note 12AX7 MM/MC phono preamplifier and separate power supply. I bought both kits years ago, I decided it was time to build it when I found 12AX7a low noise tubes at a Ham Fest a month ago. I'm surprised at how quiet it is when there is no input signal or between songs.
13EM7 spud
From my humble budget and hands to the basement of good sounds...
13EM7 spud mono blocks using ideas from many and all the best parts I had laying around :)
In the background are Frugel Horn XLs...the Preamp is an Aikido, the DCP is vintage Magnavox :tongue:
That transistor with its large heatsink, what type is it and what is its collector dissipation?
Is it a regulated power supply?
Joined 2016
I guess you have make a living from managing Solaris servers, right ? Myself I worked with Sun gear for long enough as well :)
