Which preamp for Amp Camp?
Elwood625, you said you are using two four-gang pots for input and two for output. But why two of each? It sounds to me as I’ve been reading that a single four-gang pot is good for a pair of balanced signals. Why not one 4-gang or, for help with balance and to match Nelson’s design, two 2-gang pots on each end?
And thank you, Dennis Hui. I had not seen that product.
elwood625: Well, I finally did the simple thing and went back to Digi-Key and entered N.P.’s original part numbers. Both listed as obsolete, but the 10K input and 5K output are single-gang pots; he specs two of them for each value. I don’t see how that would work since the XLR terminals have the two signal posts.
metalman, I’ll pass on that soldering job, thanks. I guess I’ve only got so much DIY in me.
Joined 2013
Here is what I'm using, one is 10K and the other is a 5K ohm 24 step pot. The red wires are input, which will connect to the output of the input selector switch. The blue wires are the output which will connect to the PC board L+, L-, R+, R-. The black wires are a shielded ground.
Joined 2013
The selector switch is a DACT CT-3/3,4,5 which is adjustable for 3 - 5 positions depending on where the stop pin is placed. I have it at 4 since I only need four inputs. The website has drawings of how to wire the selector switch for balanced and/or single ended. Google DACT, beware these are very pricey, I had one from when I was building a EL-34 tube amp. I ended up using only two inputs so I used a DPDT toggle switch instead.
Joined 2013
The one that Dennis Hui sent the link for is half the price of what I paid for each pot. Like I said, the 5K pot was custom made since i couldn't find one anywhere with four poles for balanced mode. I don't care about balance, if you are, then look for 2 10K dual pots, one for each channel. Since the 5K controls "gain" quality(?) I'm using a four gang pot.
Don't forget that no matter which pot you use, there is a resistor in series shown on the schematic that is not on the PC board as they go before P1 - P2 and again on P3 - P4.
Thanks for the info. I haven't bought a switch yet so I'll check out the DACT. I went ahead and ordered two ALPS 10K 2-gang pots and a couple of Parts-Express 5K pots. I don't know if I'll install the 5Ks or not. And yes, I just noticed the two resistors between the 10K and the PCB. I couldn't figure out why I had an R-18 and R19 without a place to stuff them!
I also just ordered the Y23 transformers from Avel Lindberg. Seem like nice folks. When I get all that big stuff I'll figure out what I need for a chassis.
Chassis option
So I've got all my major components and now looking for a chassis. I laid the two PCBs for my ZBLS plus the two transformers and here's what it looks like on paper that measures the inside dimensions of diyAudio Store's Galaxy case. (That's not my pot, just a piece i had for scale.) That looks like enough space to me. Is it? I'll be using two input pots on the front, plus a power switch and a select switch.
Also, my tallest component is just under 2 inches. I planned to use 10 mm standoffs, so with the PCB that gets me up to maybe 65mm. The 2U Galaxy is 80 mm inside height. Is that enough clearance? Do steel vs. aluminum covers make any difference? Any advice appreciated. Thanks.
Joined 2013
The case I'm using is only 70mm tall, so you should be good. I keep reading about how much heat the line stage makes, so I have a vented top cover to allow air flow and heat dissipation. I'm also using the silicone heat transfer paste between the MOSFETS and the heat sink, just a dab.
Joined 2013
Here is my completed power supply for BZLS. I added a pair of 110vac outlets which are switched by the front panel switch (left over from my ACA kits), One outlet is for the power strip for the ACA power supply's. The other is for a second power strip for my Wadia 170, Music Hall 25.3 DAC, Marantz 110 tuner and a Denon CD player/transport.
Joined 2013
No, they are 3 pin microphone connectors, identical to Radio Shack 4 pin microphone connectors. They use a 5/8" hole in the rear panel, and then have a slot in the plastic which aligns with a pin in the chassis connector so they only fit together one way.
You're way ahead of me! Just ordered the Galaxy 2U chassis from the store and am waiting for my XLR/RCA jacks and my pots to arrive. But as I lay out the transformers and PCBs on my workbench and try to visualize it, I realize I have no idea how to wire anything other than the power supply, for which N.P.'s directions are very clear. But as far as wires from the input jacks to, what, selector switch? Not a clue. If anyone can point me the right direction I'd appreciate it.
Is there a good preamp wiring article or graphic anyplace. I've searched a number of BOSOZ posts but never see anything as basic as what I'm going to need.
Joined 2013
The inputs (XLR and/or RCA's) go directly to the selector switch inputs. If you are going to have an input with BOTH XLR and RCA in parallel, then you wire the XLR to the selector switch and the RCA's are wired off the XLR connector. This is described on page 6 of the article. You will have to decide with XLR pin 2 or 3 is for the left or right channel. Wire them one at a time in regards to left and right.
XLR pin 1 goes to RCA grounds.
XLR pin 2 goes to "live" or the center pin of the positive RCA
XLR pin 3 goes to "live" or the center pin of the negative RCA
The selector switch outputs (there will be 4: L+, L-, R+, R-) will have R18 & R19 (times 2, 220 ohm) which will go to the 10K pot. with the variable or center lead.
The 10K pot then goes to the PC board.
The XLR output wiring will be the same pin assignments.
I have 24 awg wire in 6 colors which I will twist 3 together so I don't get confused wiring from the inputs to the selector switch.
Where I struggle is with which channel (left or right) is positive and which is negative in regards to the RCA's?
This is where I'm hoping someone smarter than me will chime in.
Does this help?
Yeah, I saw the explanation, and I don’t get it either. On our ACAs, the RCA jacks were just positive pin/negative collar. One was left channel and one was right channel. The whole balanced thing is confusing but I want to use it. Thanks for trying.
Hey, I have a Music Hall 25.3 DAC , too. I think I prefer it in balanced mode into the ACAs — opposite of what I assumed I’d like. I replaced the stock tube with a JJ chasing some more warmth, but didn’t really hear a change.
Joined 2013
I looked at the build guide for the ACA v1.6:
XLR pin 2 goes to Right RCA center pin
XLR pin 3 goes to Left RCA center pin
XLR pin 1 is ground
The RCA collar goes to ground for both channels, so "postive" is Red and Right, "negative" is Left and White.
So when wiring XLR and RCA in parallel, the Right channel XLR will have pin 2 to the Right RCA. Left channel XLR will have pin 3 to the Left RCA.
