Currenty I’m looking for a simple diagram for SET VT25, I already have a pair of Tango FW20 14S OPT for the project. I’ve seen the Aki Ichiro VT25 Amp design already, but it looks so difficult for a newbie like me. Thank You
@ Norelco
What about this one ?
MJ0006_(11)special-feature-9th_10Y-VT25-single-power-amp.pdf - Google Drive
MJ1608_(04)SunAudio-SV-VT25-Limited_YanagisawaM.pdf - Google Drive
In my humble opinion VT25 triode is great to use in a preamplifier for example :
http://www.bartola.co.uk/valves/2017/03/12/vt-25-dht-preamplifer/
Amplifier power stage is better to build with 300B triode ~ 8 watt´s or 211, 845 ~ 20 watt's
update Part 1 B 🙂 Enjoy
update Part 2 B 🙂 Thanks to Distant Past Old Radio Boy in Japan
Nice update 🙂 DIY articles 2019-2020
Photo of VT-25 DIY finish amplifier is superb quality work 🙂
r-tec1710_(03)VT25-single-stereo-power-amp(3)_AkiI.pdf - Google Drive
Can you translate this article?
Best Regards
Have a look at the first two pics. The 6C33S's are fed directly (without insulation) from the mains 😱😱😱!
Best regards!
What's the big deal with that? If, for some reason, there is an internal short between heater and cathode you will definitely know it 🙂
Best Regards
@ Dady amigo
You have possibility translate text from image or file with this specialized software :
Yandex Translator
Have a great time 🙂
- Tubes / Valves
- Gold mine of DI¥ audio tubes schematics from Japan
