B1 with Korg Triode
Ok.....I was trying to understand how a common mode choke works and what signals will generate a magnetic flux etc. The DC current flowing through it will not generate a flux as it will be zeroed out defined by the way the windings are of the two chokes. I think I understand it a bit better after thinking a bit more...…..
Or you can employ a FET CxMx and get rid of all the HF noise.
Very elegant and very simple.
I use a SMPS for a Pearl phono pre, followed by a CxMx and it's dead quiet, with no sharp edges and all that, just silent.
You will want to have the 24V coming out of the filter unless you want to
adjust the Nutube yourself, as the performance is voltage dependent.
I have not heard any microphonics from the Nutube in this B1 build. I haven’t gone around tapping or anything, but in normal application it seems to be a dead quiet tube. I did apply foam tape under the nutube on the board before soldering — definitely recommend that, as it actually sits better with a little elevation underneath.
If you tap on the Nutube you will hear a decaying tone at about 5 KHz,
which appear to be mechanical. Apart from that, I haven't seen what I
would call significant microphonics.
I wouldn't put the circuit on top of a loudspeaker though...
It the voltage drop over the 10 ohm resistors in the filter insignificant? …..so it is ok just to have 24,00 V at the input or is it better with 24,20 V or so? …..it seems the preamp only consumes a few mA's? you want to have 24,00 V at +F in the schematic?
Nice knobs, can I ask your source? They go well with the Galaxy chassis. Also, for the Bulgin switch (also nice) couldn't one just add some more external series resistance to the resistor built into the switch? 5K - 10K? Amazon only sells the sub-$2 buck converters as a 6 pack.
Thanks! Knobs are from Parts Express — very nice quality:
Large Aluminum Receiver / Amplifier Knob 1.58" - Matte
I couldn’t find LED specific specs in the Bulgin data sheet for that switch, but Bulgin sells panel mount indicators with blue LED. Fwd voltage is 3.8v; fwd current is 25ma. Not sure what’s already in the switch for resistance, but even adding 1k at .5w could be enough at 24v. I would imagine the indicator vs switch LEDs are pretty close in spec, if not identical.
https://www.bulgin.com/products/pub/media/bulgin/data/Indicators.pdf
It's been figured in. I think you're OK with 250 mV volt tolerance.
Draw is about 65 mA, so you can figure a .6V drop across each of the
10 ohms resistors, resulting in about 22.8V at F+.
If you are capable of measuring distortion as described above, you can
put up with a several volt supply tolerance.
It doesn't necessarily get better with more or less supply voltage.
Yes, I use a SMPS with 48V out, dropping a lot of voltage through a RCRC filter before the CxMx.
The output of the filter is 28V and then 24V out of the FET CxMx.
It's not the only way to do it, simply one way of using what one has on hand.
Passive with chokes is a valid option too but way more expensive.
Thanks to Papa for his generosity this Christmas!
Thanks to soundhappy for taking the initiative with list organization!
Finally, thanks to the 38 USA participants, who collectively scraped together $177.06 to donate back to diyA, and also paid for shipping to 6L6 as a token of appreciation for his build guides!!
Wonderful acts, and an example of what a great place this is.
BK
For all who want to see the phase of the second harmonic use Diana distortion software, discussed here
DiAna, a software Distortion Analyzer
I used it the last months to measure the k2 phase of F4 beast, DEFSIT, SIT-2, Aleph 3 and, and...
works like glue....!
Any recommendation for a cheap USB sound card to use for Diana measurements? Behringer UCA202 or UCA222 okay or something higher spec? I know these work with ASIO.
22.8v is exactly what I’m getting at F+ with the Meanwell 24v SMPS.
:cheers:
Thanks again for all of this Nelson, the Oz /NZ kits were delivered here this morning - only took 8 days, so quite quick. To the 3 forum members in Oz and NZ, I will post these out to you tomorrow and get back to you by email, thanks.
Once again a big thanks to Nelson!!
Christmas in January
The parts have arrived in Canada. Thank you Papa!
:cheers:
