Selection is limited for R1.
I ordered an assortment that will get me 222mA, 250mA, 272mA, and 300mA.
The Katana opamp should draw no more than 167mA at +-15V, and probably much closer to 133mA according to the spec sheet.
Once it is all put together, I will swap in the correct resistor that gives me as close to 100mA headroom as is reasonable. I will also PM the other Katana guy and let him know what the correct value it should be since he is running way to hot by my reading of things.
Sinking on the chassis floor with some forced air aid should suffice at 5V. If the chassis floor is substantial or by using an aluminum bar interface you may escape forced air need even. In general don't allow more than 65C when measuring on the MOSFET plastic bodies and they will be long term reliable.
Try post a bigger image? If its only about the supply and the load, the Leds can go off when the CC limit is not set at high mA enough. Or when there's an output short. If its something's wrong with grounding its about analyzing the application.
Salas,
I believe it is not about the supply because the same system was working ...
What happens and when I turn on Dam1021 the power goes off even ... goes to 0v.
Salas,
If the PS shuts off when you turn on the load, that implies the load has a dead short.
Try removing the Dam1021 from the stand offs, and set it on some cardboard.
http://www.soekris.dk/download/dam1021/dam1021 user manual 20151005.pdf
I looked really closely at your images, it looks like it is hooked up properly, maybe double check that +15V is really going to pin 1, and not pin 4. Maybe the board won't be happy unless pins 2 and 3 are jumpered at the connector. I assume they are bridged beneath the connector.
I can't see an insulating washer on the left mosfet, but it get pretty grainy blown up big enough to see what looks like a washer on the right side.
Another thought is that maybe the 3rd power supply is hitting one of the mosfets.
From the Katana manual, I calculate:
Katana Board 5v 100mA
Controller board 5v 20mA (15V DC-DC converter disabled)
Opamp board +-15v 134mA
The RPi and Isolator will be powered with an iFi wall wart.
The above is correct
Ioan
Just got this reply from Allo.
so looks like I was correct.
Salas, joshua43214,
Thanks for the help!
Had the two mosfet in contact with the chassis ... replace the screws and ... I already have streaming!
Now only the arrival of a new toroidal for the 2 sources of 24v for the pre-amplifier.
Once again thank you !!!!
best regards
https://attachment.outlook.live.net...XW3dYbwdNuBMD73qKzOJTeclH_8aPQ&animation=true
best regards
It was only the Final result!
https://attachment.outlook.live.net...D4pZeOarA-GQIrj4KMYXY2_5V1L4ow&animation=true
It's difficult ... LOL
I just tried to order the LED, WP2773ID and they are obsolete on Mouser. What will the alternatives be?
What voltage are you shooting for? Only a worry for 5V operation. If so , I can offer you some different PNs from Kingbright.
Thanks Tea, I am shooting for 5V actually.What voltage are you shooting for? Only a worry for 5V operation. If so , I can offer you some different PNs from Kingbright.
- Power Supplies
- Salas SSLV1.3 UltraBiB shunt regulator
