bubble and squeak forever.
Even copied all episodes to MicroSD (HDD recorder with USB slot as intermedium)
OCD quirk that started with Keith Floyd (on Food) in the early 80s, on VCR (later also transferred to MicroSD) I have close to all of Floyd's books, original edition
Same for Antonio Carluccio, Rick Stein, Raymond Blanc, Jamie Oliver (1999-2001), bunch of others.
In the 70s and 80s I taped just about everything cooking on TV, from every available tv channel.
Single one that didn't even came close to make the recording list is GR
Happy new year. . . and towards the emancipation of women.
havent looked at the book yet, but the model could be further expanded to check the sign of the voltage before allowing current flow, but that would also require one to set the '0' voltage point, problem is there’s only so much understood about the circuits
Are you referring to AC, DC or a combination of the two?. . . check the sign of the voltage before allowing current flow
To keep things simple lets think in terms of DC for now although the point of attachment/coupling even in DC may also affect
Mechanically speaking, my preference is for a pin and bush type coupling.. . . the point of attachment/coupling even in DC may also affect
Did you try the Cullen skink?TFL is the name of a very nice restaurant in Glasgow
I've eaten here.
Very nice looking lady but spectacular photo!!
Engineering Excellence of the type II male
The multirole assignable node (M.A.N) has many roles including the fully extended male (F.E.MALE), which is an extension of the male class. As such she is first male and second female. Many a daddy has
had a scan done catching their baby half way through transition indicating that its a baby boy. But on delivery the midwife informs the happy father that their type I male finally specialized into a type II male aka female.
And so the midwife congratulates the daddy 'its a girl, isnt she cute?' and indeed she is
Disclaimer: The above scenario is related to a parallel world possibly not like ours, any similarity to events , places or people is accidental
The most preferred coupling is normally dual stroke single piston engines, once you get that running, you can cruise wherever you like for a couple of minutesMechanically speaking, my preference is for a pin and bush type coupling.
Two-stroke engine - Wikipedia
You mean like this?Is it just me, or is there some double entendre going on here?
well done dancing scene
- Member Areas
- The Lounge
- The most beautiful woman in the world
