Anyone able to tell the difference, in ABX of course, between the electrical signal and recording through condenser microphone from W18NX001 woofer? (the last 200Hz sine test)
http://pmacura.cz/200Hz_test.zip
In addition all microphones makes/models responded very favourably to my 'treatment', especially passive dynamic Shure models with internal matching transformer, but also all condensor types....sensitivity and clarity increases markedly.
Sensitivity is an easily measurable quantity, nothing magnetic in a condensor mic (most modern ones). I guarantee gooping a capsule will not improve it.
Definitely agreed. The D205TI's I replaced in the past were 2 inch dia and ffluid cooled.Maybe cheaper compression drivers are an option for testing because they are designed to have user-replacable diaphragm assemblies and everything is quite large in terms of dimensions.
But when I was getting materials for a line array setup, I purchased about 5 pieces of some tweet, don't remember what pedigree befor I committed to 200 units, so I've a few to waste in my feeble attempt.
Ed, thanks for the gum out hint, may try it. Was thinking heat on a flat exacto, and then bonding a blade to a handheld ultrasonic piezo stack feed horn. But was undecided as I couldn't be sure the hearing protection would protect my ears or that the acrylic goggles would prevent ultrasonic pass through from the eyes to my brain. No need to do a self imposed sonic attack thing.
He was so annoying, she on the other hand, wasn't.Is this OK?
RMMGA/RAP postings on mics for recording/amplifying acoustic guitars (2001)
I’m more certain about this one (jn)
YouTube
It’s the proper moment to use your pencil to sketch it for us, John
George
Will do.
John
Resources for mastering the art
rose.htm: Seekers' windrose
I guarantee this won’t work on Dan
Will do.
Thanks.
I have good reasons to have doubts about my ability to understand things properly.
So I make questions or I ask for confirmation (like in a cockpit)
George
Yeah, b sounds slightly louder (dirtier ?).Anyone able to tell the difference, in ABX of course, between the electrical signal and recording through condenser microphone from W18NX001 woofer? (the last 200Hz sine test)
Dan.
Sure. I'm commenting from subjective viewpoint using standard mixer/pre and headphones or speakers.Sensitivity is an easily measurable quantity
I think all the condensor mics I have dealt with run output coupling/matching transformer.nothing magnetic in a condensor mic (most modern ones)
Consensor capsules and dynamic pickups improved, ditto output transformers.I guarantee gooping a capsule will not improve it.
I'm not winding you up Scott, with real sounds these changes are strongly evident, with sinewave excitation probably not.
Dan.
Then Dan, a recording with/ without your goop would be a trivial thing for you to do from the line-out feed of the console, no?
George
One of the major differences is phase.
Dynamic mikes deliver max output at zero crossings, condensors at max excursion. Therefore, you cannot mix the two types when miking an instrument (book knowledge, don't know how it pans out in real life).
If I may, the most beautiful acoustic guitar I had recorded in a studio was taken with three microphones. I think a dynamic and two electrostatics.
As they were not placed in the same places/distances, the phases are doing their own thing: just give them something to smoke ;-)
nb: The owner of the mastering/cutting room asked-me if he could add the mix of this tune to his demo disk in project.
I was proud as a porn star receiving an Oscar.
Like Schoeps?
Like Schoeps?
The Rode's are mostly (all?) transformerless too. The Sennheiser RF mics have magnetics inside but not necessarily in the output.
Yes, I can always count on you.
Damn I started reading that paper and found a new to me artist I need to investigate. George always ends up making me buy more music
When I say 'condensor' mic, I mean HV supply polarised as opposed to permanently polarised 'electret', I believe this is industry parlance.Like Schoeps?
Dan.
Not according to Neumann
True Condenser Vs. Elektret Condenser - What's the Difference?
Here are both.It’s the proper moment to use your pencil to sketch it for us, John
George
The top is the normal diff drive. I have neglected to draw in the Ls/Rs, as we all know what is meant now by the circuit.
In the second one, the pickup coil is half the turns, so shows only half the dB/dt. So I double it at the summer, and subtract it from the vout. The net effect is the same, the output of the summer will be Rs of the drive coil. (was unable to easily find the greek symbol for summation in this version of visio..sigh)
John
You forgot your "emergency" resistor?
What the heck, live dangerously. I mean, how delicate is a #49 awg wire anyway?
jn
jn
Yeah, you could hang a lot of atoms off the end of that wire...
Yes, or with my soundcard at home would be better....the experiments I ran were at work on the fly when the boss wasn't looking .Then Dan, a recording with/ without your goop would be a trivial thing for you to do from the line-out feed of the console, no?
To this end I bought one of these CM-H8C Large Diaphram True Condensor Microphone the other week.....same mic but different nameplate (Bock BK-1100C) from a pawnshop $25.00 but have not listened to it yet.
View attachment CM-H8C-Data-Sheet.pdf
There are a bunch of AB loop recording experiments for me to run in the near future now that I am subjectively happy with the sounds of a range of 'goop' mixtures.
NYE experimental mixture was on a Jamaican DJ friend's decent DJ system in a marina large pub/beer garden venue running Reggae all night..... peace, love and happiness all round .
When I have sets of formal test recordings (ie when I extract the digit) Scott's band filtered signal noise floor modulation analysis ought to be useful.
Previous critical listening to AB difference signal residual is informative and correlates with subjective impressions/findings....the difference signal sounds truly 'nasty' and weirdly/wrongly dynamic in nature.
Dan.
Dan.
Ewrong again. Most modern codensers are fet amped not transformers. Did you reallt look inside any. And let AKG and Nuemann know about your goop, youll be rich. Not likely.
Yes, according to Neumann -Not according to Neumann
Ok so I didn't state 'true' condenser....if I meant electret I would have stated electret.As a reaction, the term “true condenser” was coined for externally polarized capsules to differentiate them from (presumably lower quality) electret condensers.
Dan.
- Member Areas
- The Lounge
- John Curl's Blowtorch preamplifier part III
