Build log : DIY Beolab 18
I originally printed them on my 3D printer to get a feel and tweak the design and dimensions.
Looks incredible in Al. Very impressive that you pulled it from a solid block.
Did you have a chance to try the PLA version? It would probably be sufficient to test the shape and driver combination.
Hi folks, one of the reason I posted this project here - beside sharing the fun - is to ask for some advise on the crossover design.
With the mechanical part of the build almost done, I'll be turning my attention to the cross-over design and realization.
IMO you should measure how your drivers perform in this cabinet. Nothing wrong in starting with a stock $30 XO as a protection device for your expensive $300 tweeters but it probably won't be optimal for your final design. Using Xsim (or asking here) after measurements is a good idea. Measuring your drivers in this cabinet with something like REW + a UMIK mic would let you know how complex the XO + compensation is going to be and to realize its full potential. It will also help you decide on active/passive and amplifiers as well.
Last burning question, the original design from B&O is vented with a port in the front of the speaker (there is a funnel connecting the opening below the bottom mid range and the front of the speaker - see first post for picture). Do you think this is a good idea - I have a larger volume to start with but I can easily 3D print a port as well.
Based on the driver and it's chamber volume you could use (or ask here) for a simulation (Hornresp) to at least get an idea of the expected performance then make your choice of whether to port it.
P.S. I can't stop looking at it. 😀
I'm surprised I never saw this thread.
I hate to be That Guy, but I'm afraid that tweeter won't work: when the diameter of the tweeter exceeds about 3/4", you get a dip in the high frequency response.
I've posted an embarrassing amount of threads on how to build these things, and even put myself in the hospital trying to make one :O (Cut my thumb in half trying to make these out of wood.)
Here's the Beolab 18 specs - note the use of a 3/4" tweeter, for the reasons I describe : Beolab 18 Speakers - Iconic & Exceptional wireless sound | B&O | Bang & Olufsen
Here's the Beolab 50 specs - despite being a larger and more powerful speaker than the 18, it also uses a 3/4" tweeter:
BeoLab 50 - High End Floor Loudspeaker | Bang & Olufsen
On the upside, you MAY be able to use the lenses, but with a different tweeter. Try an SB19, I've used it on many lenses, with no issues.
Thanks for the info Patrick, I'd like to learn more about the frequency dip for diameters > 3/4".
I always thought that the dimensions should scale but I guess there is a dependency to the wavelength.
I did "reverse engineer" the speakers form the BeoLab18 and did notice that the tweeter was 3/4" and the midrange 4".
If you could share some documentation on this I'd be very grateful
Happy Holidays !
Pierre
Yes I used the ABS version to test the geometry but I always felt like the lack of mass didn't give the acoustic lens a fair chance - I honestly can't wait to try them now 🙂
I'll be asking around for someone who can help me measure these drivers and I agree I ultimately want to build my own crossover but I felt like I should have something to start with
Thanks a lot for the info - another great resource I need to look into, you guys are awesome !
Happy Holidays !
Pierre
It DOES scale: basically the larger the diaphragm is, the lower in frequency the dip is. A 3/4" tweeter will have a dip, but it's above 20khz.
I make my lenses with a 1" throat. That way, I can use them with a 3/4" tweeter, a 1" compression driver, a 7/8" tweeter, etc...
First attempt at CrossOver design - inputs welcome
So I have tried my hand at a crossover design, I started by studying the specs of the drivers I bought:
https://www.parts-express.com/pedocs/specs/287-032-morel-em-428-specifications.pdf
and
https://www.parts-express.com/pedocs/specs/277-070-morel-et-338-specifications.pdf
I'm going to start with a simple Linkwitz & Riley 4th order and then added a resistor network to bring the sensitivity to the same level (had to lower the tweeters by 5dB (Bummer)
Finally I added a series notch on the tweeters.
You can see the transmission response of the low pass and high pass branches of the crossover. I'm pretty happy with the gain flatness and crossover point right around 3kHz but not so much about the return loss on each branch, I plotted the low pass (mid-range/woofer) in DC-3KHz freq range and the tweeter in the 3kHz-20KHz range and I was surprised to see so much impedance variation.
Does anyone knows a way to find and load the actual speaker impedance ? The smith charts are actually normalized to 8 and 4 Ohms respectively.
  • Specs Sheets Midrange.xls - 287-032-morel-em-428-specifications.pdf - Mozilla Firefox.png
and
What program is that ? Spice? Why do you need a Smith chart?
If you use Xsim (free, easy to drive, and purpose specific) you can right click the driver symbol and add "FRD" and "ZMA" files to the driver to reflect its actual output and impedance. The manufacturer usually supplies them, or use 3rd party published measurements, or you could extract from graphs using trace program, or you could measure them using REW + simple resistor fixture.
Cross Over update
First of all I want to thank everyone who helped me find the right resources. I played a bit with Xsim but ultimately used VirtuixCAD.
I used the SPL trace tool to digitize the frequency and impedance responses but found the result not so accurate. I reverted to my trusty Engauge Digitizer to digitize these curves (I have attached them for reference if anyone is interested)
Then I proceeded to designing the crossover - ended up with a 4th order L&R like before but no sensitivity adaptation or series notch.
I look forward to your comments - I do like the flatness of the directivity but the crossover itself looks a bit lossy to my taste
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
jlAAAAAElFTkSuQmCC
  • CrossOver.zip
    CrossOver.zip
I remember my first loudspeaker project:
I purchased a software program called CALSOD, invested weeks in learning it, then carefully designed the crossover based on the principles described in Dickason's book. (https://www.amazon.com/Loudspeaker-Design-Cookbook-Vance-Dickason/dp/1882580338)
Then I invested about $150 in quality parts from Madisound, and dutifully waited for them to arrive.
This was a lot of money and effort, I was a teenager making $7000 per year.
And it sounded AWFUL.
Basically I didn't understand that the response of the loudspeaker will depend on the distance between the elements, and the shape of the baffle.
@pagirgard, I hate to be That Guy (again) but you can't design a crossover based on response curves from a spec sheet. It won't work. You have to measure the drivers with a microphone in their enclosure.
Understood - I'm just looking for a starting point - I have yet to find someone who can help me measure properly the speakers once the enclosure is done (almost now) and more importantly there are still several parameters one could tweak on the enclosure (volume for the mid, vent port length and geometry,...) so ultimately this is an optimization loop and one has to start somewhere...
I purchased a software program called CALSOD, invested weeks in learning it, then carefully designed the crossover based on the principles described in Dickason's book. (Loudspeaker Design Cookbook: Vance Dickason: 9781882580330: Amazon.com: Books)
You have the driver FRD+ZMA files and VituixCAD has a box and baffle modeler for the LF / MF. Whats left is that HF acoustic lense that would require measurement and possibly more elaborate compensation. As you say, it is an iterative process, some decisions need to be made before you can even start measuring. You could characterize that HF lense using a simple cheap stock XO or even a series cap (to protect your driver) and a measurement mic. There will be plenty of people on this site that can offer measurement help and REW is very popular.
I also think you can get close on iteration#1 with VituixCAD and I'm sure you're aware of the authors thread VituixCAD where you can get some answers.
There is also the hybrid option of getting the electrical XO working as best you can on iteration#1 using Vituix. Then using active EQ to do the remaining speaker and room corrections on iteration#2+ using actual measurements. Once you see what corrections are required you can decide if/how they can be finally implemented. Typically its saggy bass (BSC miscalc) and a few mystery resonant bumps (notch filters).
Beautiful! This is what DIY is all about, for someone to learn all the aspects of making your own speakers. Not just everyday run of the mill speakers, but some very unique and modern art masterpieces.
It makes me motivated to work on all my projects, so thank you!
