Current Feedback Amplifiers, not only a semantic problem?
https://sound-au.com/tcaas/jlh1969letter.pdf
Initial circuit :
https://sound-au.com/tcaas/jlh1969.pdf
By the way, it is one of the first amplifiers for which better subjective
resultats were claimed.
Subjective ?? by shareholders (or designers)?
What a piece of garbage , designed by a college educated idiot ?
Even with "caveman" components , redneck could do better in the 70's (with
"outside the box thinking"). innovation is a fickle slow cluster (you know what). Mercury diodes in 1882 , stupid monkey's could not develop mercury
vapor lighting - patent 1901 .. 1930 before the monkeys got off their a$$ to
refine a real lighting source slightly perfected the 1950's.
Sort of like Microsoft regurgitating W2k -add malware/marketing , and claim
massive "innovation" (W8/10). The greedy market drives these retarded sluggish advances. War and destruction is a faster catalyst for advancement.
IOT is a subjective innovation ,, it will centralize and expose all , not benefit us at all. bubbles will burst , we will bail out "to big to fail" (again).
Truly bipolar innovation corrupted by greed and disinformation.
Mushrooms for all , unlearn the typical b$. Really.
If I sat in front of a mercury diode in 1883 , my back yard would be well lit in 1884.
MH in 1885 , I would dope the arc with everything and anything. 20 years to do blue/uv (+phosphor) white.
Present COB UV phosphorwhite streetlight would of been reality in 75'
led lighting - pathetic. Capitalism or a war economy seems to drive "innovation" at a snails pace.
blowin' up humans and cities advanced more in a decade than useful infrastructure advancements do in
a century. Instinct is the enemy.
OS
I refute that emitter degeneration implies feedback. The base and collector resistor are degenerating bias elements as well.
I was veiledly suggesting that the expression "local feedback" is nonsense. The topological terms "feedback, input, output" require the presence of active load.
The P-N junction diode makes up (almost) all transistors. It is downright reprehensible to consider the single transistor bias arrangement and interelectrode capacitances as feedback. What is, in that view, not feedback?
The base-emitter capacitance is not feedback, nor is the base-collector (Miller / Early) capacitance.
"...downright reprehensible to consider?..." I like it. Can "to consider" be interchanged with "to think"?. It seems like “Don't dig up in doubt (as reprehensible) what you planted in faith.”
An electric field precedes the movement of electrons in filling the gradient of the field. Try touching a high voltage near zero impedance voltage source to a discharged 1 Farad capacitor.
Resistors and capacitors cause higher correcting electron currents upon the initial application of an electric field, being subsequently reduced when electrons position themselves in matching the gradient. In the case of a near ideal capacitor the movement of electrons ultimately reduces to zero whereupon electron densities in the dielectric matches the field.
Although a constant current ultimately results in a resistor the electron density along its length is variant in accordance with the electric field. Hence it is by the timed movement of electrons in space that is the feedback element in neutralizing the imposition of the electric field. This is to state that corrections take place in time as a result of electron feedback. So the question becomes as you suggest. What is not feedback?
Current Feedback Arrow
CFA = Current Feedback Arrow, a current error
I noticed what it follows some time ago but forget to mention here. It was recalled to me by a nice email I received this morning.
Image from Post # 619
attachment.php
Image from Post #1112
The source of this image is Analog Devices, tutorial MT-034 figure 2 or "Op amp applications" figure 1-14
attachment.php
Image from Sergio Franco's article in EDN
post #1427 and #1248
the emitter is a voltage input, not a current input.
An arrow drawn by an angel ?
I'm speechless that somebody can be so persistent in his denial of facts.
All models show that V(out) = I(in-) * Z(s).
Thus whithout input current , no output voltage.
But for letting a current I(in-) flowing through the CFA's input impedance, there is no other way but to offer a certain Voltage at that point.
So the amount of volts are only used as the transport vehicle to facilitate Current I(in-).
There is no mathematical relation between output voltage and input voltage, nor is the input impedance showing up in the transfer function.
This makes the voltage to be offered at the -Input amongst others a function of the unknown and varying input impedance.
But this is not the case for the current, being directly related through V(out) = I(in-) *Z(s).
Thus a CFA is completely controlled by current I(in-), and therefore its current feedback, end of discussion.
Hans
AX tech editor
Joined 2002
I've heard referred to it as the pyramid effect. Image two people on the top of a pyramid, discussing something. They do not fully agree with each other, and thus each tries to make his position clearer with more and more specific, more and more extreme cases. Its like sliding down the pyramid, each on an opposite face. As the arguments heat up and the positions get more and more extreme, they slide down until they are at the foot, with the enormous barrier between them, both physical and in conviction, and no chance in hell to ever agree.
Yet, it started out as a simple difference of opinion.
I think that is how wars start.
Jan
I've heard referred to it as the pyramid effect. Jan
I had Hans' reaction to forr's latest post: he was confirming that a CFA employs c.f! How could the post be interpreted otherwise, I thought? But obviously, forr thinks it confirms his beliefs.
I wonder if there is some very basic thing that is the source of this disagreement. Start with the basics, move up the chain of logic and find out where the reasonings diverge.
A few posts ago, you posted a classic control theory definition of feedback. I wonder if forr agrees with that?
I just copied very basic circuits which all the readers of this thread know.
I show three images, with arrows representing current in the following electrode of the input device and in the feedback network.
Two are towards a direction, the third one towards the other direction.
Which is the good one ?
There is necessarily an error.
I interpreted nothing.
To verify,
- insert a very low value resistor in the connection between the inverting input and the junction between Rf and Rg.
- measure the AC voltages (referenced to ground) at both ends of the resistor. One is higher than the other. It is up to you to draw the arrow.
CFA = Current Feedback Arrow, [snip]
What is the problem ?
V=RI !
Common base configuration (CFA) has low impedance input while common emitter (VFA) has high one.
If you have understood the advantages and disadvantages of each topology, why continue this semantic debate and not move on to something more interesting? Like for example comparing both and listening to see if there is audible differences ?
Of course, if you have some incurable allergy to one of the configurations, like Wally AKA Reodor Felgen, you can submit a medical certificate or give a nickname of your choice to one or both of them ;-)
Disabled Account
Joined 2008
Professor where have you got this from? I have nothing against CFA amplifiers, I have designed some myself, but personally I prefer VFA amplifiers with H-bridge input stage.
For the last time I'm not Waly.
Scott knows who I am and he can confirm that I'm not Waly.
