Current Feedback Amplifiers, not only a semantic problem?
The most general definition I know is 'using a sample of the plant output fed back to the plant input to modify the plant behavior'..
Not sure it clarifies anything 😎
Jan
Jan,
I also agree in case it is possible.
But suppose there is no direct connection between output and input like voltage out and current in, just as an example.
Then you have a conversion to make.
The voltage could well be be transformed into light, the light into a RF signal to a relay station, Rf back converted into heat and heat into current and there you are.
The last in the chain determines whether the Plant behaviour has to be modified, after a feedback chain in 5 steps.
Take one away and the loop is open.
Feel free to see this all together in one go as "Feedback", but it is completely hiding the actual road that was taken.
Hans
Yes, true, but the definition at the highest level says what is happening, not how to do it, not 'which road to take'. Early systems even had a man in the loop, and a fly-by-wire jetfighter has a man in the loop and actually is unstable without continuous feedback control of the flight characteristics.
The control systems people have been at this much longer than we audio types.
Jan
Jan
O.K. I can live with it.
Under this definition, a CFA has current feedback.
Hans
:whazzat:
Forr, We already told you many posts back that at LF the error current into a CFA -in is very low and you can calculate that. The Vbe deltas are concomitantly very small and a function of the DC loop gain and Ro. This compares somewhat to the Vbe deltas you would see in a a VFA.
I showed that in my damned indisputed simulations
However, as pointed out many times, the situation changes dramatically as you increase frequency.
What high frequencies ? Remember, this topic on CFA is oriented towards analogic audio.
There are so many proof points on CFA operation that I struggle to understand your dogged insistence that CFA = VFA,
Question of the day : is it not strange that the currents coming from the input stage to the next stage are very similar in both configurations, provided that the working conditions are the same of course ?
Please don’t come back
Sorry, I won't please you. I could ask you the same but I think such a request is perfectly incorrect. You do not personify the electronic science and I am free to express ideas which are not specifically mine (and cause, in other places, the same similar hostile reactions rather than indifference; this a very weak point of the CFA defenders).
and give your standard ‘the voltage at the inv input = the non inv input therefor it must be a VFA’. That doesn’t cut it. The onus is on you to show that you can completely describe CFA operation with VFA principles and you have yet to do that.
It is already done. Know that, until now, the arguments of CPaul and you are the best advocates to show that CFAs are VFA in disguise.
Here is the infographic about 'maths difficulty' I mentioned a few weeks ago.
Control theory is a little way up from the 'genius gap', but way deeper than tensor calculus.
This is not to say feedback in audio amplifiers is difficult, but simply to make the point that what we do in audio wrt control theory is extremely elementary.
Mathematics trench. - Imgur
Green's functions (Linear transformations) were my downfall, so I never even made it to "serious math". 😀 Goodness help me if I tried anything that in-depth now.
I also couldn't wrap my head around spatial Fourier transforms either (k-space), even though I could do the math(s); but that may have had more to do with condensed matter physics part of it.
Anyways, this whole thing has gone utterly circular. :/
Even if the feedback amp is ruler flat to 100kHz, still the error voltage or error current is a major indicator of what goes on inside it. Remember, the error voltage is really Vout/Aol (for a VFA at least) so that error voltage documents the complete amplifier open loop behaviour.
Most people are not consciously aware that the opamp in a feedback loop still works in open loop - it's just that the feedback manipulates the effective input level, but the opamp itself is not changed of course and ALWAYS works open loop...
Jan
Well DPH, you’re a whole lot further down the road than I am. I’ve pulled out my old math books and just bought s few new ones. I’m going to try to re-educate myself in 2019. But I’ll leave the k-space stuff for now 😀
My wife's PhD thesis was on Krylov subspace techniques and she ended up at an internship under Kevin Kundert at Cadence but she decided not to enter academia. It's all Greek to me.
