Listening Test Part II. Can you tell which......
Which file is the original and which do you prefer?
  • Nail is the original file
    Votes: 3 42.9%
  • Screw is the original file
    Votes: 4 57.1%
  • I prefer nail by listening
    Votes: 1 14.3%
  • I prefer screw by listening
    Votes: 6 85.7%
  • Total voters
    7
  • Poll closed .
...As always, please:
1) tell which file you prefer by listening,
2) try to guess which one is the original rip
3) as an option you might add an ABX report, appreciated but not necessary condition.
Again, it is an original rip vs. tube amp loop record of the same file. Opening part of the concert was chosen, with very high dynamics and both silent and loud passages.
Active diy speaker listening:
1) Screw
2) Screw
3) Maybe later
Based on clues from apricot/avocado test guess with this genre i changed my mind about preference but lets see :)
IIRC Mr. MM was very clear from the beginning with respect to "forum" ABX. I was hoping to get to a better option in physical reality.
If you read something like the ITU spec, it's simply not going to happen except by something like a well funded standards committee, then to what purpose?
BTW there is nothing in the spec about using SOTA electronics, speakers, etc.
At the risk of being accused of repeating myself (& trolling), the IT U spec states that controls are needed - that ensures that the equipment & listeners are capable of a certain level of differentiation of audible signals - nothing about SOTA, just basic capability to participate in an audibility 'test'
I've seen some here demanding that people should report their audiology results (done by a professional) before they post their listening impressions, if they want to be believed.
Good for goose, good for gander ?
Usually it helps if you tell the number of any "ITU spec" that you are referring to.....
It is a bit surprising that some members are still asking for "something other protocol", as is much simpler than you might have thought. Remember the mein requirements for any test/experiment are that it has to be objective, valid and reliable.
So obviously the solution is quite simple, use whatever you want to use, but you have to be able to show that it is/was objective, valid and reliable.
To show (internal) validity use positive and negative controls, specific proposals for sensory differences that could serve as positive controls were made in this thread and in the other (unfortunately closed) threads as well. Btw, these proposals were already mentioned back in 2009/2010 and you might guess which longterm members were already participating in the according threads in those years. ;)
Usage of negative controls was explained as well. And i´m quite confident that it was mentioned numerous times that any experimental attempt should start with a clearly expressed question/hypothesis that will be tested.
So, do you really know what you are asking for?
Though I understand your view, I would hope you were able of a bit detached view. This is a hobby forum and people come here for entertainment, at least this should be considered, IMO.
Yes, I was going to add that there's nothing wrong with having a bit of fun & I have said that numerous times already but feared I was repeating myself if I said it again.
Nothing wrong with these listening reports or sighted listening reports - they are both a bit of anecdotal fun.
Some people seem to interpret these results as more than that, however which I feel is incorrect & worth pointing out. Sorry about this.
Merrill, Jakob, I would appreciate if you came here with a suggestion of the test procedure, step by step. Otherwise I do not appreciate your inputs in this thread. It reminds me the situation as if I was chatting and giving suggestions in general about amplifiers and was unable to design and build one.
Pavel, I applaud you for your Sin wav test which followed the main test - that actually goes a long way to trying to make the 'test'more than a 'bit of fun'. Really, it's all about stepping beyond the haphazard, random nature of forum tests (& a bit of fun) into something that shows a bit more rigor.
If the source for Foobar ABX utility could be provided, I'm sure we could devise a somewhat better test?
But can I make the point that people don't seem to understand the significance of your Sine Wav test to the results reported in the main test so I'm not sure if the significance of any controls are or would be understood?
One last point: Jakob & my posts pointing out issues & errors concerning perceptual testing are no different from others pointing out issues & errors in electrical circuits & understanding - it's just that there's no easy engineering solution as there is in electrical schematics - perceptual testing relies on process rigor for useful (valid) results - that's just the hard facts of that branch of science.
1) Screw
2) Screw
3) Maybe later
Update to point three, best i could :D:
foo_abx 2.0.5 report
foobar2000 v1.4.1
2018-12-15 18:36:51
File A: nail.wav
SHA1: b67b06219b6dfa12c87c4a1cfd95ca1d489362f6
File B: screw.wav
SHA1: e012634713c70a44fc096404a65f4fdc3b397f5a
Output:
WASAPI (event) : JRiver Media Center 23 (JRiver Media Center 23), 24-bit
Crossfading: NO
18:36:51 : Test started.
18:39:08 : 00/01
18:40:51 : 00/02
18:42:58 : 01/03
18:44:53 : 02/04
18:47:22 : 02/05
18:49:09 : 02/06
18:58:37 : 02/07
19:02:00 : 03/08
19:02:00 : Test finished.
Total: 3/8
Probability that you were guessing: 85.5%
-- signature --
cc93f0b610b285e19ca972fa9e77c943cd1bbd8b
Administrator
Joined 2004
I keep reading about "controls" for this test, but what would they be? Trying to find out if the differences can actually be heard on random equipment or ears isn't going to be easy. A test like the 1K sine wave with distortion is not a good control.
Administrator
Joined 2007
I did three runs. Lol, you tell me :D I feel one has a softer feel and attack to it, a bit less glassy but as always I can't get Foobar to agree :)
(I've got the full version playing now ;))
Sorry https://www.itu.int/dms_pubrec/itu-r/rec/bs/R-REC-BS.1116-1-199710-S!!PDF-E.pdf
I'm asking you to DO IT, and it's obvious you are not interested so we shall move on.
Don't miss this:
The outcome of subjective tests of sound systems with small impairments utilizing a selected group of listeners is not
primarily intended for extrapolation to the general public.
Hence my "don't care" position which gets criticized, if you need to select a panel of 5 top mastering professionals to get positive results on a $3000 DAC vs a $250 one I truly don't care.
much harder to perceive any difference.
after an initial listen of both before ABX'ing i would have said "nail" was org rip and "screw" was through "toobs" (subjectively warmer) but i was wrong before...
foobar2000 v1.4.1
2018-12-15 18:36:51
File A: nail.wav
File B: screw.wav
Output:
Crossfading: NO
18:39:08 : 00/01
18:40:51 : 00/02
18:42:58 : 01/03
18:44:53 : 02/04
18:47:22 : 02/05
18:49:09 : 02/06
18:58:37 : 02/07
19:02:00 : 03/08
Total: 3/8
-- signature --
Thank you both for trying the new files and posting opinions and results.
