AZ OLED setup kits for Soekris dam1021/1121 control
If you wan't more bass then do the super regulator/follower mod in addition to the more capacitance mods. You might want to change the 7x05 regulators to something with much lower Zout too if you eliminate the stock series resistor config to instead a superreg.
Thanks for the reply, Spikestabber.
I will go for Salas Ultra BiB regulator later for comparison.
Also my friend clarified his experience with the polymer caps - he did not hear any difference before and after adding the 12 polymer caps. I will try 1000uf/16V or even higher for mine.(I bought the 331uF/16V)
It is dual dam1121. Now I am waiting for the new firmware of dam1121.The cost of this kit is too high, it will only share 10 pcs.
I would think it would be more economical at this point to go with the new dam1941 and the AZ-lite kit. Way more bang for your buck, just add +/-5V PSU for the dam1941. Soren mentioned in another thread that it is basically the advancement of the dam1121 and the 1941 will match the 1121.
You are right, so AZ kits for dam1121 has not been released. DAM1941 is a complete solution.
+1
IMO, in the long term the dam19x1 will replace both the dam1021 and dam1121.
Matt
Images of the finished DAC/Streamer/Headamp (current state:) ).
