Oops - Juntuin sorry, I had not enough sleep last night, so I misspelled your nickname
No probs, and thanks! Nice work there also
OINK !!!!
I'm guessing you used a power washer
What I also found interesting was the 'carver' name on a board at the back of the bose labelled device.
I never knew there was any sort of collaboration between them.
Can you share more pics and info about this device ?
The Bose/Carver thingy struck me as well There's a little more on that story on Audiokarma here: BOSE 1800, the saga goes on | Audiokarma Home Audio Stereo Discussion Forums
Hello Valery
greetings whats value of the volume control very impressive build
warm regards
Andrew
Hi Andrew,
This is a 100K ALPS pot, however I don't use it now - it's reserved for a possible future "upgrade"
Very well done Valery!
Secured by Jeff's-Valery "21 century protection circuit"!
Thank you Thimios. This one has got a "full option" 21-st century board, including the SS relays on the power rails and the speakers protection
Hi Valery, Jeff,
It is a nice looking build. I would love to hear that at some point ...
-Chris
Thank you Chris - you are more than welcome, although this particular one is in Moscow right now
Never mind, Jeff may have it assembled as well at some point
Aksa Lender P-mos Hybrid Aleph (ALPHA) Amplifier
Revisiting class A.
Revisiting class A.
Joined 2009
Thanks Bigun,yes i know,mosfets soldered after they screwed and hasn't cleaned.looking nice ! (with photos that large you needs some flux cleaning still)
Apex HV12 x 6, CQ4 and pot selector in 6x300W amp.
Nice. What process do you use for the lettering?
Nice PRO device
- Post your Solid State pics here
