Semi-Le_Calc: Calculator for Advanced Inductance Model Incorporating Semi-Inductance
This thread was started to break off the Semi-Inductance (AKA Lossy Inductance) calculator from the behemoth Hornresp thread.
Purpose of the spreadsheet:
Import free-air impedance data files and determine the parameter values for the advanced semi-inductance model to accurately define the blocked impedance of the driver. Once the blocked impedance model has been properly defined the driver mechanical and electrical Qs are then calculated, taking into account this blocked impedance. If Vas is not already known, a second impedance file can be loaded in to calculate it. The second impedance file should have the driver either loaded in an undamped closed box, or with mass added to the driver cone. Once Vas has been entered or calculated, the remainder of the TSP(Thiele/Small Parameters) can be determined. However, it is not required to know Vas if all that is desired is to determine the parameter values for the advanced semi-inductance model.
Software Requirements:
The spreadsheet was developed for use with Microsoft Excel 2007 or newer.
The following Add-Ins must be installed and active:
- Analysis TookPak
- Solver Add-in
Supported impedance data file formats:
- Tab delimited
- Comma delimited
- Space delimited
- ARTA's binary impedance data file format used by the LIMP module, *.lim
Modeling software that supports the Semi-Inductance model:
- Hornresp
- VituixCad
- SoundEasy
Calculated Semi-Inductance parameter data for some woofers:
Thread for Drivers with Semi Inductance
Data-Bass-v2-Drivers (see individual driver pages)
Data-Bass-Forum (Semi-Le_Calc discussion and download)
Version 1 of the spreadsheet calculator was posted here: Hornresp Post#8506
Version 2 is attached below.
- Added capability to import 2nd impedance file to calculate Vas
- Supplemental parameters now calculated (BL, SPL, Mms, Cms, Rms)
- Added blocked and motional impedance plots
- Added driver parameter export file
- Updated name of the FDD model in the Hornresp driver data export
- Corrected bug in Hornresp driver data export for Xmax
- Added Links TAB
- Added Notes TAB which includes list of references
- Expanded content of the Directions TAB
Version 3 posted here: Semi-Le_Calc Post#30
- Added capability to calculate and export FDD model parameters if using added-mass method
- If measured data does not extend at least 2 octaves below Fs, pop-up window provides recommendation for achieving good convergence with the model
- Directions added for installing required Add-ins along with checking and auto-activation features for English installations of Excel
- Fix for VAS Calc issues with some versions of Excel
- ASCII file import improved to handle leading spaces
- Le(1kHz) calc now uses model data, if measured data does not contain phase
Brian Steele has added a page on his website concerning use of the semi-inductance impedance model.
The latest version of the spreadsheet calculator is also hosted on his website.
The Subwoofer DIY Page
Claus Futtrup, co-author of the Semi-Inductance AES papers, has a personal webpage with additional background information and timeline on the development of the Semi-Inductance and FDD models.
Scientific papers
Related links:
Inductance Cancellation Techniques
Hornresp Post#8228
Hornresp Post#8252
  • Semi-Le_Calc_V2.zip
Excellent work my man. :cool:
This spreadsheet has turned into something quite useful. I've used it quite a bit. One trick I've been messing with this spreadsheet is, using the derived parameters from an added mass method, loading in an impedance measurement of the driver in a sealed box and using the driver specs from the added mass measurements to derive the volume of the airspace in the sealed cab. This actually seems to be a bit more precise than a rough calculation of the effects of driver displacement, bracing, stuffing, wiring, etc. Of course this takes repeatable good impedance measurements first...I know this is not at all what this was made to do. :D
For those who may not be sure what this is or why you may want to use it...All that is needed is a text file of the impedance measurement from a driver and this spreadsheet will provide you with the calculated complex inductance specs for entry into HR / or other simulation program with the capability to model using these parameters. You can also import a secondary impedance measurement using the added mass or closed air volume methods and it will calculate the full set of driver parameters.
If you are designing and simulating bass and midbass systems and you care about accuracy you should be interested in this. Especially if you are working with higher order systems like horns, TL's and bandpasses. These are much more sensitive to changes in driver performance than a sealed or IB system. Mid and high frequency devices are also affected by complex inductance but not as dramatically as woofers and subwoofers in most cases.
Reactions: 1 user
...This spreadsheet has turned into something quite useful. I've used it quite a bit. I've been messing with this spreadsheet is, using the derived parameters from an added mass method, loading in an impedance measurement of the driver in a sealed box and using the driver specs from the added mass measurements to derive the volume of the airspace in the sealed cab...
Interesting! Glad to hear you are finding the spreadsheet useful. I have done something similar where I used a pair of added-mass and close-box measurements to back out what the effective piston area was. In most cases the result was pretty darn close to the 1/3rd of surround diameter...a good rule of thumb.
Sometimes you have to get crafty with the tools you have. :)
BTW I will be posting the complex inductance specs for all of the drivers I have tested for DB. They will be on the version 2 site which I'm slowly migrating the data over to. I'm not going to bother posting them on the old one since I hope to be obsoleting it in the next 6 months.
Nice! :D
I almost never saved the data, but I do have one record with everything and I can't get it to work after stripping it down to just the needed data. Is it possible to get to the import working for the woofer tester data format?
Code:
; Woofer Tester Log File:  295-036_1ascii.log
Calibration completed: Mon Dec 13 23:21:08 2010
Drive level 100.00% [3181.82 uA]
Calibration R    =   10.000 ohms
KResist          = 1.004235 ohms/ohm (Rset= 220.932 ohms)
KPhaseLo         = -0.300340 microrads/Hz
LoZP port R      =    0.090 ohms
LoZP port L      =    0.683 uH
Load Side Cable and Amp Impedance
Resistance       =    0.001 ohms
Inductance       =    0.014 uH
Skin Resistance  =   -0.001 ohms  @20kHz
Z inductive      =    0.002 johms @ 20 kHz
Z total          =    0.002 ohms @ 20 kHz
Q,Fs completed: Tue Dec 14 21:50:46 2010
Re      5.558 ohms
Fs     26.702 Hz
Zmax  240.921 ohms
Ro     36.573 ohms
F0     21.073 Hz
F1     34.868 Hz
Fmin  139.014 Hz
Qes    0.3010
Qms   12.7440
Qts    0.2940
Le      2.738 mH @1k
XLe    23.413 ohms @1k
PLe    47.290 Degrees @1kHz
; Approximate Impedance Fitting Constants        ;
; (Improved with Completion of Vas Test)         ;
Krm    685.427E-06 ohms     Freq dependent resistance
Erm      1.098E+00          Rem=Krm*(2*pi*f)^Erm
Kxm     36.388E-03 Henries  Freq dependent reactance
Exm    707.171E-03          Xem=Kxm*(2*pi*f)^Exm,  Lem=Kxm*(2*pi*f)^(Exm-1)
;    Freq     Impedance         Phase          Real          Imag        Series
;      Hz    Z=mag(R,I)       Degrees      Z*cos(P)      Z*sin(P)        L or C
      0.0|   5.558  ohm|   0.000  deg|   5.558  ohm|   0.000  ohm|   0.000  |H
      1.0|   5.639  ohm|   7.813  deg|   5.586  ohm| 766.489 mohm| 121.990 m|H
      2.0|   5.814  ohm|  15.088  deg|   5.614  ohm|   1.514  ohm| 120.441 m|H
     10.0|  10.233  ohm|  53.858  deg|   6.035  ohm|   8.264  ohm| 131.523 m|H
     10.0|  10.234  ohm|  53.767  deg|   6.049  ohm|   8.255  ohm| 131.380 m|H
     10.1|  10.339  ohm|  54.163  deg|   6.053  ohm|   8.381  ohm| 131.866 m|H
     10.2|  10.446  ohm|  54.547  deg|   6.059  ohm|   8.509  ohm| 132.342 m|H
     10.4|  10.556  ohm|  54.889  deg|   6.072  ohm|   8.636  ohm| 132.774 m|H
     10.5|  10.665  ohm|  55.182  deg|   6.090  ohm|   8.756  ohm| 133.085 m|H
     10.6|  10.791  ohm|  55.572  deg|   6.101  ohm|   8.901  ohm| 133.737 m|H
     10.7|  10.905  ohm|  55.937  deg|   6.108  ohm|   9.034  ohm| 134.182 m|H
     10.8|  11.024  ohm|  56.293  deg|   6.118  ohm|   9.171  ohm| 134.658 m|H
     11.0|  11.152  ohm|  56.640  deg|   6.132  ohm|   9.314  ohm| 135.198 m|H
     11.1|  11.275  ohm|  57.000  deg|   6.141  ohm|   9.456  ohm| 135.687 m|H
     11.2|  11.421  ohm|  57.365  deg|   6.159  ohm|   9.617  ohm| 136.421 m|H
     11.4|  11.553  ohm|  57.702  deg|   6.173  ohm|   9.766  ohm| 136.937 m|H
     11.5|  11.695  ohm|  58.024  deg|   6.193  ohm|   9.921  ohm| 137.516 m|H
     11.6|  11.822  ohm|  58.397  deg|   6.195  ohm|  10.069  ohm| 137.972 m|H
     11.7|  11.976  ohm|  58.778  deg|   6.208  ohm|  10.242  ohm| 138.739 m|H
     11.9|  12.132  ohm|  59.132  deg|   6.224  ohm|  10.413  ohm| 139.447 m|H
     12.0|  12.280  ohm|  59.498  deg|   6.233  ohm|  10.580  ohm| 140.062 m|H
     12.2|  12.446  ohm|  59.775  deg|   6.265  ohm|  10.754  ohm| 140.732 m|H
     12.3|  12.608  ohm|  60.122  deg|   6.281  ohm|  10.932  ohm| 141.424 m|H
     12.4|  12.777  ohm|  60.397  deg|   6.312  ohm|  11.110  ohm| 142.074 m|H
     12.6|  12.972  ohm|  60.830  deg|   6.323  ohm|  11.327  ohm| 143.199 m|H
     12.7|  13.143  ohm|  61.119  deg|   6.348  ohm|  11.508  ohm| 143.823 m|H
     12.9|  13.312  ohm|  61.520  deg|   6.348  ohm|  11.701  ohm| 144.560 m|H
     13.0|  13.536  ohm|  61.862  deg|   6.383  ohm|  11.936  ohm| 145.776 m|H
     13.2|  13.715  ohm|  62.184  deg|   6.400  ohm|  12.130  ohm| 146.445 m|H
     13.3|  13.924  ohm|  62.506  deg|   6.428  ohm|  12.352  ohm| 147.416 m|H
     13.5|  14.133  ohm|  62.824  deg|   6.455  ohm|  12.573  ohm| 148.335 m|H
     13.6|  14.359  ohm|  63.224  deg|   6.469  ohm|  12.819  ohm| 149.512 m|H
     13.8|  14.566  ohm|  63.539  deg|   6.490  ohm|  13.040  ohm| 150.347 m|H
     14.0|  14.816  ohm|  63.895  deg|   6.519  ohm|  13.304  ohm| 151.639 m|H
     14.1|  15.069  ohm|  64.166  deg|   6.566  ohm|  13.563  ohm| 152.817 m|H
     14.3|  15.289  ohm|  64.491  deg|   6.584  ohm|  13.798  ohm| 153.688 m|H
     14.5|  15.552  ohm|  64.856  deg|   6.608  ohm|  14.078  ohm| 155.013 m|H
     14.6|  15.822  ohm|  65.175  deg|   6.643  ohm|  14.360  ohm| 156.301 m|H
     14.8|  16.129  ohm|  65.520  deg|   6.684  ohm|  14.679  ohm| 157.953 m|H
     15.0|  16.403  ohm|  65.914  deg|   6.694  ohm|  14.975  ohm| 159.291 m|H
     15.1|  16.706  ohm|  66.156  deg|   6.753  ohm|  15.280  ohm| 160.677 m|H
     15.3|  17.031  ohm|  66.496  deg|   6.792  ohm|  15.618  ohm| 162.344 m|H
     15.5|  17.374  ohm|  66.675  deg|   6.879  ohm|  15.954  ohm| 163.940 m|H
     15.7|  17.723  ohm|  67.085  deg|   6.901  ohm|  16.324  ohm| 165.825 m|H
     15.8|  18.077  ohm|  67.436  deg|   6.936  ohm|  16.693  ohm| 167.629 m|H
     16.0|  18.437  ohm|  67.696  deg|   6.997  ohm|  17.057  ohm| 169.329 m|H
     16.2|  18.833  ohm|  68.002  deg|   7.054  ohm|  17.462  ohm| 171.357 m|H
     16.4|  19.261  ohm|  68.216  deg|   7.148  ohm|  17.886  ohm| 173.509 m|H
     16.6|  19.672  ohm|  68.495  deg|   7.211  ohm|  18.302  ohm| 175.518 m|H
     16.8|  20.115  ohm|  68.947  deg|   7.226  ohm|  18.773  ohm| 177.970 m|H
     17.0|  20.534  ohm|  69.072  deg|   7.334  ohm|  19.179  ohm| 179.739 m|H
     17.2|  21.040  ohm|  69.380  deg|   7.410  ohm|  19.692  ohm| 182.436 m|H
     17.4|  21.619  ohm|  69.750  deg|   7.483  ohm|  20.283  ohm| 185.756 m|H
     17.6|  22.132  ohm|  69.998  deg|   7.570  ohm|  20.797  ohm| 188.288 m|H
     17.8|  22.741  ohm|  70.224  deg|   7.695  ohm|  21.400  ohm| 191.529 m|H
     18.0|  23.264  ohm|  70.411  deg|   7.800  ohm|  21.917  ohm| 193.910 m|H
     18.2|  24.099  ohm|  70.613  deg|   8.000  ohm|  22.732  ohm| 198.821 m|H
     18.4|  24.781  ohm|  70.717  deg|   8.183  ohm|  23.390  ohm| 202.235 m|H
     18.6|  25.418  ohm|  70.791  deg|   8.363  ohm|  24.003  ohm| 205.154 m|H
     18.8|  26.122  ohm|  70.727  deg|   8.622  ohm|  24.658  ohm| 208.339 m|H
     19.1|  26.893  ohm|  71.014  deg|   8.749  ohm|  25.430  ohm| 212.404 m|H
     19.3|  27.432  ohm|  71.327  deg|   8.783  ohm|  25.988  ohm| 214.582 m|H
     19.5|  28.617  ohm|  71.501  deg|   9.080  ohm|  27.139  ohm| 221.517 m|H
     19.7|  29.569  ohm|  71.883  deg|   9.195  ohm|  28.103  ohm| 226.766 m|H
     20.0|  30.440  ohm|  72.233  deg|   9.288  ohm|  28.988  ohm| 231.226 m|H
     20.2|  31.589  ohm|  72.371  deg|   9.567  ohm|  30.106  ohm| 237.394 m|H
     20.4|  32.811  ohm|  72.553  deg|   9.837  ohm|  31.302  ohm| 243.997 m|H
     20.7|  34.038  ohm|  72.745  deg|  10.097  ohm|  32.506  ohm| 250.482 m|H
     20.9|  35.431  ohm|  72.891  deg|  10.423  ohm|  33.863  ohm| 257.957 m|H
     21.0|  36.007  ohm|  72.927  deg|  10.571  ohm|  34.420  ohm| 261.275 m|H
     21.0|  36.433  ohm|  73.064  deg|  10.613  ohm|  34.853  ohm| 263.794 m|H
     21.1|  36.603  ohm|  72.985  deg|  10.711  ohm|  35.001  ohm| 264.538 m|H
     21.1|  36.681  ohm|  73.022  deg|  10.711  ohm|  35.082  ohm| 264.960 m|H
     21.1|  36.856  ohm|  72.991  deg|  10.781  ohm|  35.244  ohm| 265.989 m|H
     21.1|  36.805  ohm|  73.015  deg|  10.751  ohm|  35.199  ohm| 265.650 m|H
     21.1|  37.066  ohm|  73.078  deg|  10.789  ohm|  35.461  ohm| 267.039 m|H
     21.2|  37.813  ohm|  73.051  deg|  11.023  ohm|  36.170  ohm| 271.408 m|H
     21.3|  38.558  ohm|  73.025  deg|  11.257  ohm|  36.878  ohm| 275.124 m|H
     21.4|  38.792  ohm|  73.068  deg|  11.297  ohm|  37.111  ohm| 276.259 m|H
     21.5|  39.397  ohm|  73.091  deg|  11.459  ohm|  37.694  ohm| 279.596 m|H
     21.6|  40.378  ohm|  73.150  deg|  11.704  ohm|  38.645  ohm| 284.995 m|H
     21.6|  40.716  ohm|  73.065  deg|  11.860  ohm|  38.950  ohm| 286.635 m|H
     21.7|  41.385  ohm|  73.081  deg|  12.044  ohm|  39.594  ohm| 290.314 m|H
     21.8|  42.492  ohm|  73.038  deg|  12.397  ohm|  40.643  ohm| 296.294 m|H
     21.9|  42.735  ohm|  73.076  deg|  12.440  ohm|  40.884  ohm| 297.420 m|H
     22.0|  43.544  ohm|  73.048  deg|  12.696  ohm|  41.652  ohm| 301.896 m|H
     22.1|  44.763  ohm|  73.049  deg|  13.051  ohm|  42.818  ohm| 308.566 m|H
     22.1|  45.083  ohm|  72.910  deg|  13.248  ohm|  43.093  ohm| 309.899 m|H
     22.2|  46.038  ohm|  72.962  deg|  13.489  ohm|  44.017  ohm| 315.379 m|H
     22.3|  47.328  ohm|  72.841  deg|  13.963  ohm|  45.222  ohm| 322.145 m|H
     22.4|  47.687  ohm|  72.808  deg|  14.095  ohm|  45.557  ohm| 323.871 m|H
     22.5|  48.778  ohm|  72.699  deg|  14.506  ohm|  46.571  ohm| 329.845 m|H
     22.6|  50.241  ohm|  72.618  deg|  15.009  ohm|  47.947  ohm| 337.637 m|H
     22.6|  50.678  ohm|  72.540  deg|  15.206  ohm|  48.343  ohm| 339.746 m|H
     22.7|  51.866  ohm|  72.497  deg|  15.599  ohm|  49.464  ohm| 346.318 m|H
     22.9|  53.518  ohm|  72.337  deg|  16.238  ohm|  50.995  ohm| 354.980 m|H
     22.9|  54.024  ohm|  72.151  deg|  16.559  ohm|  51.424  ohm| 357.260 m|H
     23.0|  55.344  ohm|  72.039  deg|  17.066  ohm|  52.647  ohm| 364.370 m|H
     23.1|  57.312  ohm|  71.873  deg|  17.832  ohm|  54.468  ohm| 374.800 m|H
     23.2|  57.760  ohm|  71.702  deg|  18.134  ohm|  54.840  ohm| 376.629 m|H
     23.3|  59.450  ohm|  71.560  deg|  18.805  ohm|  56.397  ohm| 385.844 m|H
     23.4|  61.674  ohm|  71.225  deg|  19.850  ohm|  58.393  ohm| 397.195 m|H
     23.4|  62.189  ohm|  71.026  deg|  20.219  ohm|  58.810  ohm| 399.271 m|H
     23.5|  64.069  ohm|  70.877  deg|  20.989  ohm|  60.533  ohm| 409.383 m|H
     23.7|  66.615  ohm|  70.447  deg|  22.295  ohm|  62.773  ohm| 422.090 m|H
     23.7|  67.276  ohm|  70.184  deg|  22.807  ohm|  63.292  ohm| 424.784 m|H
     23.8|  69.482  ohm|  69.968  deg|  23.800  ohm|  65.278  ohm| 436.408 m|H
     23.9|  72.571  ohm|  69.450  deg|  25.474  ohm|  67.953  ohm| 451.673 m|H
     24.0|  73.325  ohm|  69.124  deg|  26.129  ohm|  68.511  ohm| 454.547 m|H
     24.1|  75.968  ohm|  68.870  deg|  27.386  ohm|  70.860  ohm| 468.287 m|H
     24.2|  79.677  ohm|  68.126  deg|  29.685  ohm|  73.941  ohm| 485.831 m|H
     24.3|  80.541  ohm|  67.771  deg|  30.469  ohm|  74.556  ohm| 488.989 m|H
     24.4|  83.938  ohm|  67.403  deg|  32.253  ohm|  77.494  ohm| 506.250 m|H
     24.5|  88.636  ohm|  66.393  deg|  35.495  ohm|  81.218  ohm| 527.525 m|H
     24.5|  89.537  ohm|  66.010  deg|  36.404  ohm|  81.803  ohm| 530.377 m|H
     24.6|  93.718  ohm|  65.378  deg|  39.045  ohm|  85.197  ohm| 550.183 m|H
     24.8|  99.548  ohm|  64.081  deg|  43.512  ohm|  89.535  ohm| 574.864 m|H
     24.8| 100.719  ohm|  63.531  deg|  44.891  ohm|  90.161  ohm| 577.880 m|H
     24.9| 106.429  ohm|  62.503  deg|  49.139  ohm|  94.406  ohm| 602.654 m|H
     25.1| 114.231  ohm|  60.590  deg|  56.094  ohm|  99.509  ohm| 631.573 m|H
     25.1| 115.203  ohm|  60.101  deg|  57.425  ohm|  99.870  ohm| 632.780 m|H
     25.2| 123.512  ohm|  58.205  deg|  65.077  ohm| 104.977  ohm| 662.440 m|H
     25.4| 134.529  ohm|  54.829  deg|  77.490  ohm| 109.969  ohm| 689.946 m|H
     25.4| 134.200  ohm|  55.084  deg|  76.814  ohm| 110.043  ohm| 689.254 m|H
     25.7| 159.665  ohm|  47.534  deg| 107.797  ohm| 117.782  ohm| 729.284 m|H
     26.0| 190.561  ohm|  36.329  deg| 153.521  ohm| 112.893  ohm| 691.011 m|H
     26.3| 219.989  ohm|  21.284  deg| 204.984  ohm|  79.855  ohm| 483.194 m|H
     26.6| 238.439  ohm|   4.214  deg| 237.794  ohm|  17.521  ohm| 104.809 m|H
     26.6| 236.611  ohm|   4.552  deg| 235.865  ohm|  18.780  ohm| 112.334 m|H
     26.7| 240.702  ohm| 119.883 mdeg| 240.701  ohm| 503.632 mohm|   3.004 m|H
     26.7| 239.777  ohm| 173.941 mdeg| 239.776  ohm| 727.924 mohm|   4.342 m|H
     26.7| 240.921  ohm|-869.102 mdeg| 240.893  ohm|   3.654  ohm|   1.631 m|C
     26.7| 240.622  ohm|  -1.833  deg| 240.499  ohm|   7.697  ohm| 773.789 u|C
     26.8| 239.882  ohm|  -3.753  deg| 239.368  ohm|  15.701  ohm| 378.804 u|C
     26.8| 238.991  ohm|  -3.658  deg| 238.504  ohm|  15.249  ohm| 390.023 u|C
     26.9| 234.976  ohm| -11.146  deg| 230.544  ohm|  45.424  ohm| 130.176 u|C
     28.0| 171.351  ohm| -47.190  deg| 116.446  ohm| 125.704  ohm|  45.157 u|C
     28.4| 151.901  ohm| -53.418  deg|  90.529  ohm| 121.976  ohm|  46.005 u|C
     28.7| 134.188  ohm| -58.135  deg|  70.840  ohm| 113.966  ohm|  48.675 u|C
     29.0| 119.283  ohm| -61.919  deg|  56.149  ohm| 105.241  ohm|  52.107 u|C
     29.4| 106.556  ohm| -64.879  deg|  45.237  ohm|  96.477  ohm|  56.189 u|C
     29.7|  95.847  ohm| -67.156  deg|  37.210  ohm|  88.329  ohm|  60.670 u|C
     30.0|  86.788  ohm| -68.806  deg|  31.376  ohm|  80.918  ohm|  65.469 u|C
     30.4|  79.037  ohm| -70.239  deg|  26.722  ohm|  74.382  ohm|  70.406 u|C
     30.7|  72.439  ohm| -71.283  deg|  23.245  ohm|  68.608  ohm|  75.458 u|C
     31.1|  66.680  ohm| -72.089  deg|  20.507  ohm|  63.449  ohm|  80.660 u|C
     31.5|  61.778  ohm| -72.661  deg|  18.412  ohm|  58.971  ohm|  85.791 u|C
     31.8|  57.430  ohm| -73.129  deg|  16.667  ohm|  54.959  ohm|  91.000 u|C
     32.2|  53.595  ohm| -73.478  deg|  15.242  ohm|  51.382  ohm|  96.221 u|C
     32.6|  50.335  ohm| -73.754  deg|  14.082  ohm|  48.326  ohm| 101.135 u|C
     32.9|  47.312  ohm| -73.892  deg|  13.127  ohm|  45.454  ohm| 106.293 u|C
     33.3|  44.656  ohm| -73.979  deg|  12.325  ohm|  42.922  ohm| 111.276 u|C
     33.7|  42.246  ohm| -74.000  deg|  11.644  ohm|  40.609  ohm| 116.266 u|C
     34.1|  40.156  ohm| -73.851  deg|  11.169  ohm|  38.572  ohm| 121.007 u|C
     34.5|  38.230  ohm| -73.811  deg|  10.659  ohm|  36.714  ohm| 125.674 u|C
     34.7|  37.330  ohm| -73.818  deg|  10.403  ohm|  35.851  ohm| 127.962 u|C
     34.8|  36.900  ohm| -73.778  deg|  10.308  ohm|  35.431  ohm| 129.108 u|C
     34.8|  36.696  ohm| -73.774  deg|  10.254  ohm|  35.234  ohm| 129.643 u|C
     34.9|  36.601  ohm| -73.780  deg|  10.224  ohm|  35.144  ohm| 129.880 u|C
     34.9|  36.598  ohm| -73.792  deg|  10.215  ohm|  35.143  ohm| 129.883 u|C
     34.9|  36.496  ohm| -73.771  deg|  10.200  ohm|  35.042  ohm| 130.165 u|C
     34.9|  36.474  ohm| -73.770  deg|  10.194  ohm|  35.021  ohm| 130.243 u|C
     35.3|  34.960  ohm| -73.705  deg|   9.809  ohm|  33.556  ohm| 134.472 u|C
     35.7|  33.465  ohm| -73.661  deg|   9.414  ohm|  32.114  ohm| 138.900 u|C
     36.1|  32.020  ohm| -73.591  deg|   9.045  ohm|  30.715  ohm| 143.562 u|C
     36.5|  30.681  ohm| -73.462  deg|   8.733  ohm|  29.412  ohm| 148.210 u|C
     36.9|  29.443  ohm| -73.268  deg|   8.476  ohm|  28.197  ohm| 152.826 u|C
     37.4|  28.309  ohm| -73.034  deg|   8.261  ohm|  27.077  ohm| 157.323 u|C
     37.8|  27.224  ohm| -72.742  deg|   8.077  ohm|  25.998  ohm| 161.977 u|C
     38.2|  26.224  ohm| -72.473  deg|   7.898  ohm|  25.007  ohm| 166.469 u|C
     38.7|  25.320  ohm| -72.143  deg|   7.764  ohm|  24.100  ohm| 170.757 u|C
     39.1|  24.440  ohm| -71.839  deg|   7.618  ohm|  23.223  ohm| 175.179 u|C
     39.6|  23.628  ohm| -71.519  deg|   7.490  ohm|  22.409  ohm| 179.461 u|C
     40.0|  22.852  ohm| -71.128  deg|   7.392  ohm|  21.623  ohm| 183.853 u|C
     40.5|  22.129  ohm| -70.756  deg|   7.293  ohm|  20.892  ohm| 188.109 u|C
     41.0|  21.454  ohm| -70.341  deg|   7.217  ohm|  20.203  ohm| 192.300 u|C
     41.4|  20.798  ohm| -69.926  deg|   7.139  ohm|  19.535  ohm| 196.602 u|C
     41.9|  20.193  ohm| -69.495  deg|   7.073  ohm|  18.913  ohm| 200.738 u|C
     42.4|  19.621  ohm| -69.036  deg|   7.020  ohm|  18.322  ohm| 204.843 u|C
     42.9|  19.072  ohm| -68.567  deg|   6.969  ohm|  17.753  ohm| 208.992 u|C
     43.4|  18.556  ohm| -68.072  deg|   6.930  ohm|  17.214  ohm| 213.066 u|C
     43.9|  18.067  ohm| -67.602  deg|   6.884  ohm|  16.704  ohm| 217.062 u|C
     44.4|  17.603  ohm| -67.099  deg|   6.850  ohm|  16.216  ohm| 221.032 u|C
     44.9|  17.167  ohm| -66.579  deg|   6.824  ohm|  15.753  ohm| 224.924 u|C
     45.4|  16.750  ohm| -66.086  deg|   6.790  ohm|  15.312  ohm| 228.746 u|C
     46.0|  16.357  ohm| -65.576  deg|   6.764  ohm|  14.893  ohm| 232.487 u|C
     46.5|  15.982  ohm| -65.077  deg|   6.735  ohm|  14.493  ohm| 236.171 u|C
     47.0|  15.619  ohm| -64.598  deg|   6.700  ohm|  14.108  ohm| 239.836 u|C
     47.6|  15.264  ohm| -64.091  deg|   6.669  ohm|  13.730  ohm| 243.631 u|C
     48.1|  14.928  ohm| -63.578  deg|   6.642  ohm|  13.368  ohm| 247.354 u|C
     48.7|  14.608  ohm| -63.077  deg|   6.615  ohm|  13.025  ohm| 250.966 u|C
     49.3|  14.293  ohm| -62.605  deg|   6.576  ohm|  12.690  ohm| 254.649 u|C
     49.8|  13.978  ohm| -62.096  deg|   6.541  ohm|  12.353  ohm| 258.604 u|C
     50.4|  13.674  ohm| -61.542  deg|   6.516  ohm|  12.022  ohm| 262.683 u|C
     51.0|  13.382  ohm| -60.955  deg|   6.497  ohm|  11.699  ohm| 266.829 u|C
     51.6|  13.105  ohm| -60.342  deg|   6.484  ohm|  11.388  ohm| 270.987 u|C
     52.2|  12.839  ohm| -59.716  deg|   6.475  ohm|  11.087  ohm| 275.158 u|C
     52.8|  12.585  ohm| -59.069  deg|   6.469  ohm|  10.796  ohm| 279.349 u|C
     53.4|  12.344  ohm| -58.402  deg|   6.468  ohm|  10.514  ohm| 283.551 u|C
     54.0|  12.113  ohm| -57.728  deg|   6.467  ohm|  10.241  ohm| 287.761 u|C
     54.6|  11.891  ohm| -57.041  deg|   6.469  ohm|   9.978  ohm| 291.989 u|C
     55.3|  11.680  ohm| -56.327  deg|   6.476  ohm|   9.720  ohm| 296.299 u|C
     55.9|  11.477  ohm| -55.570  deg|   6.489  ohm|   9.466  ohm| 300.765 u|C
     56.5|  11.289  ohm| -54.787  deg|   6.510  ohm|   9.224  ohm| 305.139 u|C
     57.2|  11.129  ohm| -54.037  deg|   6.536  ohm|   9.008  ohm| 308.876 u|C
     57.9|  10.984  ohm| -53.274  deg|   6.569  ohm|   8.804  ohm| 312.404 u|C
     58.5|  10.851  ohm| -52.619  deg|   6.588  ohm|   8.622  ohm| 315.344 u|C
     59.2|  10.724  ohm| -52.093  deg|   6.588  ohm|   8.461  ohm| 317.665 u|C
     59.9|  10.581  ohm| -51.500  deg|   6.587  ohm|   8.281  ohm| 320.869 u|C
     60.6|  10.442  ohm| -51.150  deg|   6.550  ohm|   8.132  ohm| 323.001 u|C
     61.3|  10.279  ohm| -50.611  deg|   6.523  ohm|   7.944  ohm| 326.844 u|C
     62.0|  10.116  ohm| -50.066  deg|   6.493  ohm|   7.757  ohm| 330.914 u|C
     62.7|   9.955  ohm| -49.489  deg|   6.467  ohm|   7.568  ohm| 335.267 u|C
     63.4|   9.799  ohm| -48.845  deg|   6.449  ohm|   7.378  ohm| 339.996 u|C
     64.2|   9.655  ohm| -48.206  deg|   6.435  ohm|   7.198  ohm| 344.483 u|C
     64.9|   9.508  ohm| -47.536  deg|   6.419  ohm|   7.014  ohm| 349.496 u|C
     65.7|   9.366  ohm| -46.822  deg|   6.409  ohm|   6.830  ohm| 354.774 u|C
     66.4|   9.231  ohm| -46.076  deg|   6.404  ohm|   6.649  ohm| 360.281 u|C
     67.2|   9.107  ohm| -45.307  deg|   6.405  ohm|   6.474  ohm| 365.793 u|C
     68.0|   8.989  ohm| -44.539  deg|   6.407  ohm|   6.305  ohm| 371.281 u|C
     68.8|   8.878  ohm| -43.786  deg|   6.409  ohm|   6.143  ohm| 376.715 u|C
     69.6|   8.768  ohm| -43.028  deg|   6.410  ohm|   5.983  ohm| 382.358 u|C
     70.4|   8.664  ohm| -42.266  deg|   6.411  ohm|   5.827  ohm| 388.106 u|C
     71.2|   8.564  ohm| -41.487  deg|   6.416  ohm|   5.673  ohm| 394.050 u|C
     72.0|   8.467  ohm| -40.725  deg|   6.417  ohm|   5.524  ohm| 400.051 u|C
     72.8|   8.375  ohm| -39.942  deg|   6.421  ohm|   5.377  ohm| 406.317 u|C
     73.7|   8.285  ohm| -39.162  deg|   6.424  ohm|   5.232  ohm| 412.771 u|C
     74.5|   8.198  ohm| -38.388  deg|   6.425  ohm|   5.091  ohm| 419.401 u|C
     75.4|   8.112  ohm| -37.600  deg|   6.427  ohm|   4.949  ohm| 426.421 u|C
     76.3|   8.030  ohm| -36.804  deg|   6.429  ohm|   4.810  ohm| 433.733 u|C
     77.2|   7.951  ohm| -36.000  deg|   6.433  ohm|   4.674  ohm| 441.312 u|C
     78.1|   7.876  ohm| -35.174  deg|   6.438  ohm|   4.537  ohm| 449.359 u|C
     79.0|   7.805  ohm| -34.349  deg|   6.444  ohm|   4.404  ohm| 457.652 u|C
     79.9|   7.740  ohm| -33.538  deg|   6.451  ohm|   4.276  ohm| 465.955 u|C
     80.8|   7.677  ohm| -32.734  deg|   6.457  ohm|   4.151  ohm| 474.509 u|C
     81.7|   7.614  ohm| -31.930  deg|   6.462  ohm|   4.027  ohm| 483.503 u|C
     82.7|   7.553  ohm| -31.128  deg|   6.465  ohm|   3.904  ohm| 493.002 u|C
     83.6|   7.493  ohm| -30.319  deg|   6.468  ohm|   3.783  ohm| 503.044 u|C
     84.6|   7.439  ohm| -29.550  deg|   6.471  ohm|   3.669  ohm| 512.718 u|C
     85.6|   7.380  ohm| -28.721  deg|   6.472  ohm|   3.547  ohm| 524.301 u|C
     86.6|   7.325  ohm| -27.888  deg|   6.475  ohm|   3.426  ohm| 536.482 u|C
     87.6|   7.273  ohm| -27.042  deg|   6.478  ohm|   3.307  ohm| 549.526 u|C
     88.6|   7.224  ohm| -26.190  deg|   6.482  ohm|   3.188  ohm| 563.452 u|C
     89.6|   7.178  ohm| -25.320  deg|   6.488  ohm|   3.070  ohm| 578.462 u|C
     90.7|   7.137  ohm| -24.458  deg|   6.497  ohm|   2.955  ohm| 594.076 u|C
     91.7|   7.098  ohm| -23.626  deg|   6.503  ohm|   2.845  ohm| 610.066 u|C
     92.8|   7.058  ohm| -22.764  deg|   6.508  ohm|   2.731  ohm| 628.180 u|C
     93.8|   7.022  ohm| -21.907  deg|   6.515  ohm|   2.620  ohm| 647.287 u|C
     94.9|   6.985  ohm| -21.043  deg|   6.520  ohm|   2.508  ohm| 668.362 u|C
     96.0|   6.953  ohm| -20.164  deg|   6.527  ohm|   2.397  ohm| 691.490 u|C
     97.1|   6.925  ohm| -19.298  deg|   6.536  ohm|   2.289  ohm| 715.869 u|C
     98.3|   6.897  ohm| -18.413  deg|   6.544  ohm|   2.179  ohm| 743.359 u|C
     99.4|   6.873  ohm| -17.537  deg|   6.554  ohm|   2.071  ohm| 773.056 u|C
    100.6|   6.852  ohm| -16.670  deg|   6.564  ohm|   1.966  ohm| 805.173 u|C
    101.7|   6.834  ohm| -15.803  deg|   6.575  ohm|   1.861  ohm| 840.728 u|C
    102.9|   6.817  ohm| -14.935  deg|   6.587  ohm|   1.757  ohm| 880.334 u|C
    104.1|   6.803  ohm| -14.075  deg|   6.598  ohm|   1.654  ohm| 924.230 u|C
    105.3|   6.791  ohm| -13.222  deg|   6.611  ohm|   1.553  ohm| 972.993 u|C
    106.5|   6.780  ohm| -12.398  deg|   6.622  ohm|   1.456  ohm|   1.026 m|C
    107.8|   6.771  ohm| -11.569  deg|   6.633  ohm|   1.358  ohm|   1.088 m|C
    109.0|   6.761  ohm| -10.742  deg|   6.643  ohm|   1.260  ohm|   1.159 m|C
    110.3|   6.753  ohm|  -9.913  deg|   6.652  ohm|   1.163  ohm|   1.242 m|C
    111.5|   6.749  ohm|  -9.079  deg|   6.664  ohm|   1.065  ohm|   1.340 m|C
    112.8|   6.741  ohm|  -8.255  deg|   6.671  ohm| 967.813 mohm|   1.457 m|C
    114.1|   6.737  ohm|  -7.421  deg|   6.681  ohm| 870.087 mohm|   1.603 m|C
    115.5|   6.735  ohm|  -6.576  deg|   6.691  ohm| 771.342 mohm|   1.787 m|C
    116.8|   6.737  ohm|  -5.723  deg|   6.703  ohm| 671.730 mohm|   2.029 m|C
    118.1|   6.742  ohm|  -4.868  deg|   6.718  ohm| 572.201 mohm|   2.354 m|C
    119.5|   6.755  ohm|  -4.049  deg|   6.738  ohm| 477.008 mohm|   2.792 m|C
    120.9|   6.765  ohm|  -3.280  deg|   6.754  ohm| 387.087 mohm|   3.401 m|C
    122.3|   6.771  ohm|  -2.493  deg|   6.765  ohm| 294.567 mohm|   4.418 m|C
    123.7|   6.782  ohm|  -1.665  deg|   6.779  ohm| 197.093 mohm|   6.527 m|C
    125.1|   6.801  ohm|-855.665 mdeg|   6.800  ohm| 101.563 mohm|  12.522 m|C
    126.6|   6.824  ohm|-125.978 mdeg|   6.824  ohm|  15.003 mohm|  83.793 m|C
    128.1|   6.839  ohm| 549.757 mdeg|   6.839  ohm|  65.619 mohm|  81.550 u|H
    129.5|   6.847  ohm|   1.277  deg|   6.845  ohm| 152.577 mohm| 187.448 u|H
    131.0|   6.860  ohm|   2.061  deg|   6.855  ohm| 246.675 mohm| 299.584 u|H
    132.6|   6.880  ohm|   2.855  deg|   6.871  ohm| 342.621 mohm| 411.345 u|H
    134.1|   6.907  ohm|   3.606  deg|   6.893  ohm| 434.387 mohm| 515.548 u|H
    135.7|   6.933  ohm|   4.285  deg|   6.914  ohm| 518.040 mohm| 607.794 u|H
    137.2|   6.952  ohm|   4.972  deg|   6.926  ohm| 602.564 mohm| 698.869 u|H
    138.8|   6.973  ohm|   5.696  deg|   6.939  ohm| 692.124 mohm| 793.554 u|H
    139.0|   6.975  ohm|   5.783  deg|   6.939  ohm| 702.851 mohm| 804.685 u|H
    140.4|   6.997  ohm|   6.428  deg|   6.953  ohm| 783.355 mohm| 887.874 u|H
    142.0|   7.025  ohm|   7.170  deg|   6.970  ohm| 876.750 mohm| 982.354 u|H
    143.7|   7.057  ohm|   7.913  deg|   6.990  ohm| 971.611 mohm|   1.076 m|H
    145.4|   7.096  ohm|   8.623  deg|   7.016  ohm|   1.064  ohm|   1.165 m|H
    147.0|   7.136  ohm|   9.286  deg|   7.043  ohm|   1.152  ohm|   1.246 m|H
    148.7|   7.177  ohm|   9.920  deg|   7.070  ohm|   1.236  ohm|   1.323 m|H
    150.0|   7.249  ohm|  10.177  deg|   7.135  ohm|   1.281  ohm|   1.359 m|H
    150.5|   7.219  ohm|  10.513  deg|   7.098  ohm|   1.317  ohm|   1.393 m|H
    152.2|   7.259  ohm|  11.087  deg|   7.123  ohm|   1.396  ohm|   1.460 m|H
    154.0|   7.297  ohm|  11.638  deg|   7.147  ohm|   1.472  ohm|   1.522 m|H
    155.7|   7.334  ohm|  12.194  deg|   7.169  ohm|   1.549  ohm|   1.583 m|H
    157.6|   7.371  ohm|  12.726  deg|   7.190  ohm|   1.624  ohm|   1.640 m|H
    159.4|   7.407  ohm|  13.259  deg|   7.210  ohm|   1.699  ohm|   1.697 m|H
    161.2|   7.441  ohm|  13.769  deg|   7.227  ohm|   1.771  ohm|   1.748 m|H
    163.1|   7.468  ohm|  14.271  deg|   7.237  ohm|   1.841  ohm|   1.796 m|H
    165.0|   7.489  ohm|  14.817  deg|   7.240  ohm|   1.915  ohm|   1.848 m|H
    166.9|   7.511  ohm|  15.447  deg|   7.240  ohm|   2.001  ohm|   1.908 m|H
    168.8|   7.541  ohm|  16.125  deg|   7.244  ohm|   2.094  ohm|   1.974 m|H
    170.8|   7.578  ohm|  16.810  deg|   7.254  ohm|   2.192  ohm|   2.042 m|H
    172.8|   7.621  ohm|  17.485  deg|   7.269  ohm|   2.290  ohm|   2.109 m|H
    174.8|   7.669  ohm|  18.167  deg|   7.287  ohm|   2.391  ohm|   2.178 m|H
    176.8|   7.725  ohm|  18.835  deg|   7.312  ohm|   2.494  ohm|   2.245 m|H
    178.8|   7.781  ohm|  19.417  deg|   7.338  ohm|   2.587  ohm|   2.302 m|H
    180.9|   7.834  ohm|  20.089  deg|   7.358  ohm|   2.691  ohm|   2.368 m|H
    183.0|   7.903  ohm|  20.772  deg|   7.389  ohm|   2.803  ohm|   2.438 m|H
    185.1|   7.985  ohm|  21.449  deg|   7.432  ohm|   2.920  ohm|   2.511 m|H
    187.3|   8.092  ohm|  22.089  deg|   7.498  ohm|   3.043  ohm|   2.586 m|H
    189.4|   8.226  ohm|  22.505  deg|   7.600  ohm|   3.149  ohm|   2.646 m|H
    191.6|   8.354  ohm|  22.542  deg|   7.716  ohm|   3.203  ohm|   2.660 m|H
    193.8|   8.446  ohm|  22.395  deg|   7.809  ohm|   3.218  ohm|   2.642 m|H
    196.1|   8.494  ohm|  22.194  deg|   7.865  ohm|   3.209  ohm|   2.604 m|H
    198.3|   8.512  ohm|  22.170  deg|   7.883  ohm|   3.212  ohm|   2.577 m|H
    200.0|   8.266  ohm|  21.942  deg|   7.668  ohm|   3.089  ohm|   2.458 m|H
    200.0|   8.529  ohm|  22.191  deg|   7.897  ohm|   3.221  ohm|   2.563 m|H
   1000.0|  23.413  ohm|  47.290  deg|  15.881  ohm|  17.204  ohm|   2.738 m|H
Vas Delta Mass completed: Tue Dec 14 22:04:44 2010
Re         =    5.5583 ohms
Fs         =   26.7025 Hz
Zmax       =  240.9208 ohms
Qes        =    0.3010
Qms        =   12.7440
Qts        =    0.2940
Le         =    2.7381 mH  (at 1 kHz)
Diam       =  397.9997 mm  ( 15.6693 in  )
Sd         =124410.0034 mm^2(192.8359 in^2)
Vas        =  443.4291 L   ( 15.6596 ft^3)
BL         =   23.3629 N/A
Mms        =  176.1521 g
Cms        =  201.6736 uM/N
Kms        = 4958.5073 N/M
Rms        =    2.3191 R mechanical
Efficiency =    2.6359 %
Sensitivity=   96.2272 dB @1W/1m
Sensitivity=   97.8087 dB @2.83Vrms/1m
Krm        = 685.427E-06 ohms     Freq dependent resistance
Erm        =   1.098E+00          Rem=Krm*(2*pi*f)^Erm
Kxm        =  36.388E-03 Henries  Freq dependent reactance
Exm        = 707.171E-03          Xem=Kxm*(2*pi*f)^Exm
Ftest                   =    19.995 Hz
Ftest/Fms               =    0.7488
Test Mass used          =  138.0000 g (Equal to 27.6 nickels)
Test Mass (Ft=Fms*0.90) =    41.320 g (Add -96.680g for Ft=24.032)
Test Mass (Ft=Fms*0.75) =   137.007 g (Add -0.993g for Ft=20.027)
      1.0|   5.558  ohm|   0.000  deg|   5.558  ohm|   0.000  ohm|   0.000  |H
     10.0|  11.142  ohm|  56.389  deg|   6.168  ohm|   9.279  ohm| 147.686 m|H
     10.1|  11.277  ohm|  56.689  deg|   6.193  ohm|   9.424  ohm| 148.273 m|H
     10.2|  11.426  ohm|  57.402  deg|   6.156  ohm|   9.626  ohm| 149.722 m|H
     10.4|  11.595  ohm|  57.510  deg|   6.228  ohm|   9.780  ohm| 150.374 m|H
     10.5|  11.727  ohm|  58.184  deg|   6.182  ohm|   9.965  ohm| 151.461 m|H
     10.6|  11.921  ohm|  58.324  deg|   6.260  ohm|  10.145  ohm| 152.435 m|H
     10.7|  12.125  ohm|  58.695  deg|   6.300  ohm|  10.360  ohm| 153.874 m|H
     10.8|  12.293  ohm|  59.193  deg|   6.296  ohm|  10.558  ohm| 155.028 m|H
     11.0|  12.511  ohm|  59.589  deg|   6.333  ohm|  10.790  ohm| 156.612 m|H
     11.1|  12.700  ohm|  59.937  deg|   6.362  ohm|  10.991  ohm| 157.716 m|H
     11.2|  12.914  ohm|  60.369  deg|   6.385  ohm|  11.225  ohm| 159.225 m|H
     11.4|  13.103  ohm|  60.764  deg|   6.400  ohm|  11.434  ohm| 160.327 m|H
     11.5|  13.361  ohm|  61.274  deg|   6.422  ohm|  11.717  ohm| 162.414 m|H
     11.6|  13.603  ohm|  61.593  deg|   6.471  ohm|  11.965  ohm| 163.959 m|H
     11.7|  13.838  ohm|  61.947  deg|   6.508  ohm|  12.212  ohm| 165.432 m|H
     11.9|  14.082  ohm|  62.436  deg|   6.516  ohm|  12.484  ohm| 167.171 m|H
     12.0|  14.354  ohm|  62.791  deg|   6.563  ohm|  12.766  ohm| 168.990 m|H
     12.2|  14.651  ohm|  63.217  deg|   6.602  ohm|  13.079  ohm| 171.163 m|H
     12.3|  14.967  ohm|  63.621  deg|   6.650  ohm|  13.408  ohm| 173.458 m|H
     12.4|  15.250  ohm|  64.030  deg|   6.678  ohm|  13.710  ohm| 175.328 m|H
     12.6|  15.574  ohm|  64.346  deg|   6.743  ohm|  14.039  ohm| 177.481 m|H
     12.7|  15.937  ohm|  64.977  deg|   6.741  ohm|  14.441  ohm| 180.475 m|H
     12.9|  16.310  ohm|  65.298  deg|   6.816  ohm|  14.817  ohm| 183.057 m|H
     13.0|  16.656  ohm|  65.617  deg|   6.876  ohm|  15.170  ohm| 185.276 m|H
     13.2|  17.081  ohm|  66.060  deg|   6.931  ohm|  15.611  ohm| 188.475 m|H
     13.3|  17.493  ohm|  66.389  deg|   7.006  ohm|  16.028  ohm| 191.297 m|H
     13.5|  17.951  ohm|  66.756  deg|   7.084  ohm|  16.494  ohm| 194.602 m|H
     13.6|  18.418  ohm|  67.069  deg|   7.176  ohm|  16.963  ohm| 197.841 m|H
     13.8|  18.957  ohm|  67.516  deg|   7.250  ohm|  17.516  ohm| 201.952 m|H
     14.0|  19.491  ohm|  67.821  deg|   7.358  ohm|  18.049  ohm| 205.720 m|H
     14.1|  20.051  ohm|  68.142  deg|   7.465  ohm|  18.610  ohm| 209.684 m|H
     14.3|  20.659  ohm|  68.447  deg|   7.589  ohm|  19.214  ohm| 214.017 m|H
     14.5|  21.327  ohm|  68.837  deg|   7.700  ohm|  19.889  ohm| 218.992 m|H
     14.6|  22.029  ohm|  69.133  deg|   7.847  ohm|  20.584  ohm| 224.051 m|H
     14.8|  22.783  ohm|  69.415  deg|   8.011  ohm|  21.329  ohm| 229.500 m|H
     15.0|  23.587  ohm|  69.650  deg|   8.202  ohm|  22.115  ohm| 235.233 m|H
     15.1|  24.428  ohm|  69.960  deg|   8.371  ohm|  22.949  ohm| 241.312 m|H
     15.3|  25.429  ohm|  70.241  deg|   8.597  ohm|  23.932  ohm| 248.773 m|H
     15.5|  26.448  ohm|  70.468  deg|   8.842  ohm|  24.926  ohm| 256.140 m|H
     15.7|  27.615  ohm|  70.650  deg|   9.150  ohm|  26.055  ohm| 264.677 m|H
     15.8|  28.895  ohm|  70.800  deg|   9.502  ohm|  27.288  ohm| 274.023 m|H
     16.0|  30.226  ohm|  70.882  deg|   9.900  ohm|  28.559  ohm| 283.507 m|H
     16.2|  31.759  ohm|  71.020  deg|  10.329  ohm|  30.032  ohm| 294.715 m|H
     16.4|  33.446  ohm|  70.985  deg|  10.897  ohm|  31.621  ohm| 306.757 m|H
     16.6|  35.305  ohm|  70.913  deg|  11.545  ohm|  33.364  ohm| 319.959 m|H
     16.8|  37.467  ohm|  70.750  deg|  12.352  ohm|  35.372  ohm| 335.337 m|H
     17.0|  39.936  ohm|  70.590  deg|  13.272  ohm|  37.666  ohm| 352.999 m|H
     17.2|  42.773  ohm|  70.189  deg|  14.497  ohm|  40.241  ohm| 372.814 m|H
     17.4|  45.998  ohm|  69.524  deg|  16.090  ohm|  43.092  ohm| 394.650 m|H
     17.6|  49.691  ohm|  68.670  deg|  18.075  ohm|  46.287  ohm| 419.062 m|H
     17.8|  53.870  ohm|  67.348  deg|  20.747  ohm|  49.715  ohm| 444.941 m|H
     18.0|  58.857  ohm|  65.856  deg|  24.074  ohm|  53.708  ohm| 475.184 m|H
     18.2|  64.559  ohm|  63.972  deg|  28.329  ohm|  58.011  ohm| 507.377 m|H
     18.4|  71.431  ohm|  61.714  deg|  33.850  ohm|  62.901  ohm| 543.850 m|H
     18.6|  80.344  ohm|  58.701  deg|  41.739  ohm|  68.651  ohm| 586.768 m|H
     18.8|  91.019  ohm|  54.249  deg|  53.179  ohm|  73.868  ohm| 624.128 m|H
     19.1| 103.665  ohm|  48.545  deg|  68.630  ohm|  77.694  ohm| 648.940 m|H
     19.3| 118.017  ohm|  40.957  deg|  89.127  ohm|  77.359  ohm| 638.745 m|H
     19.5| 134.450  ohm|  30.786  deg| 115.504  ohm|  68.815  ohm| 561.699 m|H
     19.7| 150.207  ohm|  18.163  deg| 142.723  ohm|  46.822  ohm| 377.809 m|H
     20.0| 163.057  ohm|   3.276  deg| 162.790  ohm|   9.318  ohm|  74.325 m|H
     20.0| 161.247  ohm|   3.809  deg| 160.890  ohm|  10.713  ohm|  85.451 m|H
     20.0| 164.196  ohm|   1.675  deg| 164.126  ohm|   4.800  ohm|  38.237 m|H
     20.0| 164.577  ohm| 780.038 mdeg| 164.561  ohm|   2.241  ohm|  17.834 m|H
     20.0| 164.106  ohm|-168.801 mdeg| 164.106  ohm| 483.478 mohm|  16.451 m|C
     20.1| 164.369  ohm|  -4.087  deg| 163.950  ohm|  11.716  ohm| 676.935 u|C
     20.2| 163.438  ohm| -10.867  deg| 160.507  ohm|  30.813  ohm| 255.910 u|C
Box Measurement NOT complete
Drive level 100.00% [0.00 uA]
Re    =    6.9891 (box test)
flo   =    0.0000, Zlo  =    0.0000
fhi   =    0.0000, Zhi  =    0.0000
fm    =    0.0000, Zmid =    0.0000
Fsb   =    0.0000
Ha    =    0.0000
Alpha =    1.0000
; Sealed Box Data
Re    =    0.0000
Fbox  =    0.0000
Flo   =    0.0000
Fhi   =    0.0000
Qbox  =    0.0000
Qleak =    0.0000
Qmss  =    0.0000 - Qms in sealed box
Qess  =    0.0000 - Qes in sealed box
Qtss  =    0.0000 - Qts in sealed box
Qtc   =    0.0000 = Qts*Fbox/Fs
Arbitrary Sweep [1] NOT complete
Simulator Z/P data completed: Sun Jun 21 11:35:18 2009
Drive level 100.00% [1000.00 uA]
;    Freq      Response         Phase          Real          Imag
;      Hz       db(A/B)       Degrees      Z*cos(P)      Z*sin(P)
; Power Compression Test:  Date:Wed Dec 31 19:00:00 1969
; Constants from baseline low level test
; Re  =      5.5583 ohms   Mms =    176.1521 grams
; Diam=    397.9997 mm     Sd  = 124410.0034 m^2
;  High power [ 0: 0]        ;
;     Idrive       Vdrive        Fs     Qes     Qms     Qts      Vas      BL        Cms       Kms     Rms  PctEff     Zmax          Xmm ;
;  Low power [ 0: 0]        ;
I am not familiar with the Woofer Tester ASCII export format, but if it is something commonly used and you can point me to a definition of the format I can add it to the next version. Looking at the Woofer Tester user’s guide, it can export in ZMA format which should work just fine.
However, there may be an issue with the data itself. I grabbed the first section of data from the example file you posted, created a space delimited data file(attached), and plotted it. You can see that it only contains high resolution data between about 10 Hz and 200Hz. To work properly, the Semi-Le spreadsheet really needs data defined over a broader range, especially the upper range which should extend to 10kHz. I’m not sure if this would generally be included in the ZMA export file, or if there are options to have it export higher resolution data over the whole frequency range.
  • NEO_Dan_Wtester_Data.txt
Yes, I have chosen unwisely in not at least saving the native .woo files for my measurements. I can generate space delimited FRD's for any new measurements. :rolleyes:
Go ahead and make real progress and force me to adapt!
I do what I can :D
I have been in touch with Claus Futtrup, co-author of the AES papers on Semi-inductance model. He has a nice personal web page with some background and history of the development of the Semi-inductance model as well as the FDD(Frequency Dependent Damping) model. Scientific papers
Speaking of the FDD model, I hope to have V3 of the spreadsheet released by the end of the year which will add the FDD parameter calculations and Hornresp export. So if anybody has noticed any bugs or has suggestions for improvements, let me know and I will try and roll them in at the same time.
Also, it was brought to my attention that VituixCAD and the latest version of SoundEasy both support the Semi-inductance model for enclosure design.
Thanks for sharing the link.
That paper is Reference [3] on the notes tab of the spreadsheet.
There may be some people interested in learning more about the Semi-Inductance and/or Frequency Dependent Damping model but don't have the software required to open the spreadsheet. Here is *.pdf file containing the books and papers I referred to when developing the spreadsheet. Links are included and many are available for free download.
  • References_Semi-Le_FDD_TSP.pdf
The Dayton Audio DATS V2 has option to export as *.zma file which can be read into the semi-Le calc workbook as a space delimited data file.
The workbook includes a [Directions] tab which has step by step instructions as well as descriptions of the different parameters and plots. Once you have acquired your impedance data, let me know if you have any issues reading the files in or using the spreadsheet to determine the semi-Le model parameters.
Real men use Smith and Larson Woofer Tester :D
