So greedy boyz, what transformer will you be using?
I only have a pair of edcors so will probably start with them.
Dennis
I will use Cinemags
I also have Bud Purvine Onetics which I used with my F6s - they do need custom wiring however
Best
Bob
CMOQ-4LPC here.
Hey, if i wanted the option of driving headphones(Sennheiser HD58X, 150 ohms) with the SissySIT, i should be able to with maybe a suitable series resistor, right?
Using one of those sockets that disconnect the speakers when i plug headphones in i'm thinking.
Cinemag CMOQ-4H 80% nickel is on my need a try components list.
http://cinemag.biz/output/PDF/CMOQ-4.pdf
After what I see on datasheet CMOQ-4L is 50% nickel | 50 % steel
Do You agree with me ? Yes some confusion on the web page ?
Interesting how much is price difference and audio satisfaction performance ?
Hello everyone, in China, this THF-51S 2SK182ES has a wide range of work,
for elevators, and high-temperature copper smelters.
At the beginning, there were only old goods in China, which were brought from some countries to China, and later to DIY.....
At the beginning, for every quantity, I only have 1000pcs
I have only 500pcs left now (it needs to be sold for a long time, because the elevator is no longer needed, now only the copper factory, and DIY enthusiasts)
Passionate story Pras1170
Thanks and good luck for Your busine$$
Excellent Kris0603 !
so now we can build SissySIT "de luxe " with 80% nickel Cinemags.
Good for experiment on M2 etc.
Soldering iron must be very hot for Tokin source and gate pins wire connections btw.
My modern 80 watt´s WD -1 Weller soldering station can go up 450 °C max.
Have a good time
Have a good time
May you live a thousand years!
Does he have to age?...or can he remain as handsome and witty as he is now?
Dropped Cinemag an email. If they get back to me I’ll add the CMOQ-HPCs to my stockpile to compare with the Jensens.
Do You have stockpile with 80% nickel Jensen transformers ?..Dropped Cinemag an email. If they get back to me I’ll add the CMOQ-HPCs to my stockpile to compare with the Jensens.
After prices I see on the web page Cinemags is a good deal
Oh, Mighty ZM!
I suspect he has already accomplished that.
No just the standard Jensen JT-123-FLCPH with 50% nickel.
Yes the high nickel Cinemags seem like a real bargain. I already heard back from Cinemag via email. They’re going through some server based phone system conversion. That appears to be why I didn’t hear back from them when I left a message. Placed an order for the High Nick Cinemags. They’re gearing up for Pa’s big order. Hopefully they squeeze out a few for us small fish.
- SissySIT
