The New Hypex Fusion Plate amps
To my knowledge that is not possible.
1. It is the coaxial spdif that is used for communication for master/slave and volume and so., Not the AES.
2. Master slave config means the slave follows the master settings in volume and preset etc.
If you want each amp to control their own presets you must use both amps as master.
Configure the slave as master! This is a brilliant idea!
Since I am using analogue XLR daisy chain, my pre amp is the only limitation, and i don't need two additional long spdif cables, for each left and right channels.
Moreover, I will have 3 presets by 3 presets configurations, total of nine configurations, in stead of three.
Thanks for your wonderful enlightenment! And all ours fusion users can understand the features better!
Installed two FA253 - worked perfectly fine for days but today suddenly one plate amp goes to protection (even without signal or after a reboot, or after USB reconfig, changing preset). The red leds blinks very fast, sound still goes through but completely distorted. Nothing was done, it came by it's own. The plate amp is neither hot nor was it shocked by anything.
I will call support tomorrow but my studio production is now set to offline ;-(
Anybody with a similar problem?
Otherwise they are great amps!
Thanks.
Thanks.
Have you power it down, remove the power cable, and retry after few mins?
Afterall it was a computer with special feature!
cant get any sound out of my sub.
i have a FA252
i have forced indput to S/pdif
make a filter with lowpass at 70hz
uploadet filter.
turn off my sub
connectet indput cable and turn it on.
tried to get some sound with aome test on youtube. but no sound a all.
so what have i done wrong?? :)
mabye there is some one that will make a totural for noobs like me ;)
i have a FA252
uploadet filter.
turn off my sub
could be the start up volume set too low, especially for low frequency.
I've experienced this many times!
You may temporary set to 300Hz, e.g.
Check the volume setting at the top bar in the filter. What is the value?
Mine was set to -6dB and gain set to 13dB in the filter. And start up volume to -6dB under device setting, If I set it too low, e.g. -40dB, barely heard anything.
The volume at the main page was -6dB, I suspect it was corresponding to top bar of the filter and device setting(???), for every presets.
You may refer to the link for the start up: Hypex-PSC2.400d
Btw, good to test analogue RCA or XLR before digital. Easier this way.
Here i a pic of My filter so far.
Here is a pic of My filter so far.
I will Try your advice when i come home from work 😁.
Thanks fore the replye
The gain of the filter is 0dB ;) According to the given link and my setting, it should be at least 10dB, depending on the gain of your amp.
I tired to do as the guide, and still No sound.
Tried to turn the volumen op to max, and still No sound or wibration from My sub.
Any suggestion fore what to try next? 😊
And set volume start up to -3dB from device settings screen. Watch up your source volume when play.
i only have digital output on my marantz sr7012
i have a remote control to hypex so are turning up wile i test on youtube.
just tried with a low pass at 200hz and 300 hz
gain at 13db and gain at 20db
still no sound.
when i power my sub of it wake a small clik, so there are okay connection to the subs..
is there some one than will make some screen shot of theres filter and upload it here, :)
still no sound.
Have you checked the SPDIF LFE/SUB settings in the reciver? You might have to turn it on?
still no sound.
use the any of the front rca under pre out section.
what is the value of "volume at start" under device setting?
i set the volume to 0dB at the main screen. "volume at start" under device setting" to no configured". 13dB for gain under filter preset.
Marantz SR7012 Enthusiast Multiroom AV Receiver with HEOS & Dolby Atmos/DTS:X 7.1.4 Surround Sound Processing | Digital Cinema
The volumen is - 40 but can turn i up With the remote Controller.
Im not sure where to find the Any of the front. But wil look into it later to day 😊
